I used to think so.......
Done With The Sunroom
I'm done my part. The interior guys now sand and stain for a month (it seems).
Before During After Kudos go out to PK and G Diddy for finishing up the siding and the deck railing for me. |
Re: Done With The Sunroom
man....you have surely increased the value of that place!
I have a few perplexing questions. Like wtf is the chimney FLOATING for!?!? And "did you hear banjos every day?" ![]() How about "are those FJ's going through the rim, like cantilevered?" do I see DeWalt power tools hanging in the tree? OK....I'll stop for now.
Trade: Carpentry & Remodeling
Nice work Maxx!!
Whats next for ya??
Do what you would do, as if i won't Do anything after you Did It! |
#4 | |
Yeah. When I was going to demo the existing structure I was trying to figure a way to brace all that brick up.
Then I actually got up there and found out it was painted brick pattern on some kind of tin. The whole thing is just a plywood chase. It is optically cool though. Yeah...out in the sticks huh? It is very damp and mossy. We did a little trig and determined that the HOs have a bunch of 180' tall cedars and DF. Quote:
I hope not...I will go check my truck to see what I am missing. OK....I'll stop for now. [/quote]
Maker of fine kindling
Very nice work!
I only have one question though Did you ever see a bear relieving himself while you were there?
Trade: Frame to Finish and Concrete
[quote=framerman;605432]man....you have surely increased the value of that place! [quote]
Wallmaxx, is that house in as rough of shape as it appears from the photos? ![]() Are those hog panels on the deck railing? Looks nice.
A smart guy won't say anything and a dumb guy don't know the difference! Last edited by seifconst; 02-11-2009 at 10:35 PM. Reason: nuder ? |
Trade: Construction
That is cool, man! The blocking makes the roof look like is a buncha stacked Lego pieces!
Talk to me for a second about the gable wall, would ya? Glu-Lam beams blind fastened to built up 2x lams? What was the process? Good lookin' addition, though. Perfect framing, always nice to see your projects... Mac |
More here
This is another Lindal Cedar Home project. This time a sunroom. They design and send out everything precut to fit whatever the sales guy measures in his initial visit. The main room had a span of 16'-2". Every post was notched 1/2" to allow the header beams to sit in them. The headers had angled holes predrilled with a 1/4" hole and a 1"hole so a lag and washer could be impacted in from the top. Everything was hidden lagged from all kinds of factory drilled angles. Once the post and beam system was in place...the rest was traditional nailing / screwing. I almost cut a header to "make it fit"...but I checked the popped lines one final time and found that I had made the smaller deck outer wall...parallel to the un-square original home rather than truly square. Once I fixed that...the piece fit without cutting. Of all the post and beams pieces...I did not cut a single one. It was actually cool how well it went together. You just have to make sure your framing is dead on for what they are sending to sit on it. |
| The Following User Says Thank You to wallmaxx For This Useful Post: | BuiltByMAC (02-12-2009) |
#9 | |
[quote=seifconst;606128][quote=framerman;605432]man....you have surely increased the value of that place!
Back in Houston I called it cattle guard...but I hear hog fencing here in WA state. The house is over 80 years old...I think it has a cedar log foundation on the original part. Then the first addition is HO poured concrete. He's quite a versatile guy. The siding is 24" long pieces of cedar - we couldn't find anyone who makes the stuff anymore...so the HO just removed what he needed from his barn. Just for the record. I was only deeply involved in the structural framing through dry-in, set the windows / doors, deck framing and planks and the initial siding from the street side. I must give credit to another contractor / remodeler who has a knack with matching up new with old. He tied the rest of the siding in and built the deck railing. I don't have the eye to do that kind of remodel like other do. We call him PIE eater. Last edited by wallmaxx; 02-12-2009 at 01:33 AM. |
| The Following User Says Thank You to wallmaxx For This Useful Post: | seifconst (02-14-2009) |
| leak under sunroom exterior wall on slab | jrcuts | Framing | 7 | 01-09-2009 06:17 PM |
| New sunroom addition - Acid stained floor | AAPaint | Painting & Finish Work Picture Post | 12 | 09-22-2008 02:15 PM |
| Sunroom Remodel and Repair | orson | Remodeling Picture Post | 7 | 08-07-2008 07:01 PM |
| Sunroom problem - need advice | AtlRemodeling | Decks & Fencing | 5 | 05-16-2008 08:31 PM |
| Getting ready to build a sunroom need help on practical window sizes | TurnkeyConst | Windows, Siding and Doors | 3 | 11-08-2007 11:22 PM |
