Do You Overcut?
Old 02-12-2009, 05:26 AM   #61
PA woodbutcher's Avatar
Rewards Points: 1,000
Re: Do You Overcut?
If one notches a joist, or makes
a ledger cut in a joist, it is against
common practice and codes to
over cut.....at all.
I learned to cut stairs watching Dad,
and he never over cut them, so
I have always just put 2 and 2
together.....
Not condemning any of my
betters here though.
I also learned from my father who never overcut
Using the old tools some times
will give you a whole new appreciation
for the guys who came before you.
I still have my dads old rip and crosscut saw and a set tool for the teeth. Not sure where they are right now. I do keep a stanley short cut sa in the truck, but rarely use it.
Originally Posted by BuiltByMAC View Post
I don't overcut, but I don't use hand saws either. Jigsaw works just fine by me. Toss a 6" jigsaw blade in and it doesn't want to wander as easily. I usually use the jig saw also. I have a cordless dewalt that works great. Just as handy as the recip saw, but less wander
Liked the thought of drilling the hole at the corner - softer transition means less likelihood for future splits and failure. Might have ta try that on the next set...Not real sure about that one..I mean the less chance of split.
I've heard of stacked dado blades in the same manner - neither method appeals to me. Too much open spinning metal for a chance of binding/kickback...I've stacked blades in order to cut a channel for flashing. Very careful as there is more bite for kickback.
I'll second Wallmaxx's stair test, good way to test 'em out. I weigh 150 # so this method doesn't seem to work for me very well. Usually stand in the middle of he stairs and have someone else walk up and down them to see how much I feel as they're walking.
I will also bow to Wall's proffesionalism and his overcuts
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
Old 02-12-2009, 05:28 AM   #62
Deicide1's Avatar
Rewards Points: 75
Re: Do You Overcut?
Originally Posted by Cole View Post
Like I have stated before, I do overcut, when I am in a rush. 90% of the time, I dont, but I have a question for you guys that dont overcut ever.
Are the guys who overcut hacks in your eyes?
Interesting thread here.
Yes, overcutting is very hack-like. Take the time to do the job properly.
I finish the cut with either a jap saw or jigsaw, depending on the amount needed to be done.
Deicide1 is offline
Old 02-12-2009, 07:42 AM   #63
SNC's Avatar
Trade: SE Carpenter
Rewards Points: 75
Re: Do You Overcut?
NO! I run two short cords at the end of a 100'er, one for my Skil saw and one for my jig saw. Flipping the board takes to long and i usually have a lot of stringers to cut.
SNC is offline
Old 02-12-2009, 07:57 AM   #64
Joe Carola's Avatar
Trade: Framing Contractor
Rewards Points: 1,012
Re: Do You Overcut?
Are you saying hack-like for guys who overcut stringers and rafters, or just over cutting stringers?
Joe Carola
Joe Carola is offline
Old 02-12-2009, 09:01 AM   #65
Gary H's Avatar
Rewards Points: 2,342
Re: Do You Overcut?
Originally Posted by wallmaxx View Post
Wow.
So did that yellin stop when you plugged his mouth with your fist?
If violence isn't an option...just start dating his mom...that puts a whole new spin on things.
Thats a good one.
Gary H is offline
Old 02-12-2009, 10:55 AM   #66
Meetre's Avatar
Re: Do You Overcut?
Wow.
No, didn't hit him. I wanted to, but some how managed not to. I did leave that job that week, finally got feed up enough to start my own business because of that day.
Best part about it, the steps in question were getting covered with carpet!
Meetre is offline
Old 02-12-2009, 06:23 PM   #67
Lester S.'s Avatar
Trade: General
Re: Do You Overcut?
Never overcut anything. Why not take the time?
Lester S. is offline
Old 02-12-2009, 06:53 PM   #68
Kent Whitten's Avatar
Rewards Points: 2,040
Re: Do You Overcut?
In the situations I have listed above, I feel it's not necessary. My old boss told me "we ain't building a piano". There is a point in framing (or anything) where your concentrated focus on little things is detrimental to the actual outcome.
SalmonFallsCabinetry.com
Kent Whitten is offline
The Following User Says Thank You to Kent Whitten For This Useful Post:
Cole (02-12-2009)
Old 02-12-2009, 07:56 PM   #69
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 1,484
Re: Do You Overcut?
Cole is offline
Old 02-12-2009, 08:34 PM   #70
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Re: Do You Overcut?
Overcutting on rafter birdsmouth cuts is harmless because the seat cut bears fully on the wall plate.
Overcutting an inside intesection such as a stair notch not only is unsightly but could possibly weaken
the framing structure of the stairs. (Could) is reason enough for me to spend what amounts to about
five minutes on an average run of stairs from floor to floor. Remember; just because you can't see it,
doesn't mean it isn't there.
loneframer is offline
Old 02-12-2009, 09:07 PM   #71
Deicide1's Avatar
Rewards Points: 75
Re: Do You Overcut?
Only on stringers. Stairs are something to take time on and do right.
Cutting the birdsmouth on rafters isn't such deal...and I use a stacked Dado on them and there is no way to overcut!
Deicide1 is offline
Old 02-12-2009, 09:20 PM   #72
Joe Carola's Avatar
Re: Do You Overcut?
You can overcut rafters without any problems. There's no need to waste time cutting them with a jigsaw, handsaw or anything else.
Joe Carola
Old 02-12-2009, 09:53 PM   #73
D.Foster's Avatar
Trade: Carpentry & Remodeling
Re: Do You Overcut?
Originally Posted by borat_borat1950 View Post
A 1 X 12 skirt board by the trim guy fills this nicely!! and they love us framers that think this out for them!!!
Think what out?? How to step out a framing square, and do math?
I would'nt want that kinda trim guy on my job.
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 02-12-2009, 10:00 PM   #74
dubz's Avatar
Trade: General Contracting
Rewards Points: 250
Re: Do You Overcut?
I over cut rafters now. I used to not, but I saw other good framers do it so I started.
I am pretty good at judging just how much to allow the piece to fall slowly as I pull the saw away, or sometimes I have to give it a little tap with the side of the shoe to make it fall. You have to notch a little corner out with a utility knife most of them, but I don't mind. You kind of get in the groove and do the steps in a nice fluid motion.
I can't envision what using a set of dado's does for you when cutting rafters. Please explain, decide1
dubz is offline
Old 02-12-2009, 10:54 PM   #75
D.Foster's Avatar
Re: Do You Overcut?
they used to market a dado set for worm drives, a beast of a thing. And you could bevel it, and gang cut all the birds mouths at once. I saw it in a tauntons roof book.
I didnt know you could still get them though, maybe second hand.
D.Foster is offline
The Following User Says Thank You to D.Foster For This Useful Post:
dubz (02-13-2009)
Old 02-12-2009, 11:50 PM   #76
Rewards Points: 746
Re: Do You Overcut?
You can get a machine shop to make them. John Harman shows his in his article for JLC http://www.jlconline.com/cgi-bin/jlc.../View/0409gang
He had a machine shop make it. I think, but don't quote me, that you can get Big Foot to make one. I'm not 100% on that though.
The problem I've been told, is that you don't want ot use it on pitches over 7-12 because it is hard on the saw to take out that much meat at once. I think John said he prefers to use it 6-12 and under and his might be wired for 220v.
Timuhler is offline
The Following 2 Users Say Thank You to Timuhler For This Useful Post:
D.Foster (02-13-2009), dubz (02-13-2009)
Old 02-13-2009, 12:02 AM   #77
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Re: Do You Overcut?
Okay
I am going to have to weigh in on the over-cut side.
Come on...let's get real here. Some have said that is seriously weakens the stringer...that's just false. A bunch of knots in your stringer do that no matter how pretty your cut is.
I happened to cut a stringer today. I did it the same way I do all my inside, non-exposed stringers. The evil "over-cut" is 15/16" on the face and 0" on the back. It slopes from face to back at the arc radius of 3 5/8" from what comes from a 2 1/2" deep cut.
Now, "over-cutting" makes absolutely no difference on the stringers that are attached to walls, right? Do we all agree?
So really, we are only concerned with the free standing stringers as far as being "weaker." Sure, over-cut vs non over-cut is more wood removed...at this stage. However, I always add a ripped 2x6 to both sides of all my middle stringers and usually a midspan knee wall. Also, I use 2x12 treads and 2x8 risers...very solid.
When I read the dogmatic comments about how "wrong" it is to over-cut...I laugh. Of all the nit picky things to worry about. I guess if I was using OSB or 1/2" ply for treads, and 2x10s for stringers (like I saw in N. Delta (Vancouver) BC I would be more concerned.
Do you overcut?-dsc07352.jpg   Do you overcut?-dsc07354.jpg   Do you overcut?-dsc07350.jpg
wallmaxx is offline
Old 02-13-2009, 12:03 AM   #78
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Re: Do You Overcut?
I will photo document this set
wallmaxx is offline
Old 02-13-2009, 12:07 AM   #79
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
Re: Do You Overcut?
Hey Tim, if you're a subscriber to JLC, do you get into their website free? I went to look at that article and got the first 100 words before they wanted to charge me $3 to view the rest...
Mac
BuiltByMAC is offline
Old 02-13-2009, 12:24 AM   #80
Lester S.'s Avatar
Trade: General
Re: Do You Overcut?
I guess the attitude of " We're not building a piano " is quite prevalent in some areas. When running some guys, the attitude of being precise helps alot. Once it gets away from you, it's hard to get it back.
Stair risers/kickers wallmaxx Framing 25 03-28-2009 11:19 PM
