#101 | |
KemoSabe
Re: Custom In The Woodlands,TXQuote:
It's the nature of the "Super Framer" though, you have to keep challenging yourself to get better or else it becomes nothing more than monotony.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#102 | |
These days, the lumber yards around here have plenty of time to spare, I can’t imagine that it is a whole lot different in Houston. I have a decking suggestion for you. But it is not like you haven’t done it this way either, so if this is how you do them, great! See you at choir practice. Have the decking sent out with a forklift and tell them that the lift is necessary for staging material and will extend the delivery time by a half hour. Have the fork lift driver help you stock the materials in an advantageous manner by lifting it to the second floor level where needed and manually stocking it around on the floor or attic spaces. When decking roofs steeper than 10/12 I like to cut in the attic or second floor spaces and feed the sheets through the rafters. I put one toe-board per 4’ course and nail it as I go. The row itself provides a hand hold for the nailers and that will speed up production by limiting the movement of the guys up top. Steep roofs often have ample cut station space under them too. Nice job you have there. Keep up the good work! PS I hear you about using subcontract deckers! I’ve used decking subs too, but for the most part they disappointed me by not doing near the same job I would do. They waste material, nail off poorly, often create booby traps for the roofers, and I have even had them cut up the leftovers and throw them in the dumpster to increase the sheet/$ charges. So I tend to deck my own roofs. I did have one good decker years ago, but he was expensive too. Another funny thing is; I’m usually faster than most decking crews and I can’t stand to pay someone ‘too much’, or more than I make myself, to do something that is very easy to do, do it poorly, and it is something I can do faster, cheaper, and more efficiently myself. But a good one can speed the job up by freeing me up to punch it out at the same time. Cheers! ![]() Richard |
#103 |
Trade: Framing Contractor
I see the 16/12 roof sheathing as a no-brainer on this 10,000 sqft house. Hire the plywood subcontractor, as long as he has his own insurance, and spend a day cleaning up and fixing any of the roof sheathing that your not happy with. Or use your own crew and listen to them wine and cry all day as their trying to install 75 pound sheets of 3/4" T&G on an 16/12 roof. Then your crew would be bascily worthless for about a week after the roof sheathing was complete.
About 6 months ago I asked John if the Arcus blade was worth the cost for cutting 2x radius rafters. John said it was worth the cost. What he should have said You would be a **** idiot not to use the Arcus blade for cutting 200 radius rafter tails. Well, you would have to be an **** idiot not to hire a subcontractor to roof sheathe a 10,000 sqft house with 340 sheets of 3/4" T&G. Sim note: Richard... shouldn't it be [ I was usually faster than most decking crews]. |
#104 | |
Sim, I don’t remember telling anyone to be a ‘****ing Idiot’. I wonder what John’s decker wants to do the decking? That has a little to do with who does it, doesn’t it? I definitely would try to find a sub first to speed things along. But if I couldn’t, it is not that big a deal. As the framer I always felt I had an advantage over the sub deckers because I already had the decking install planned to go smoothly. I was always there, thinking ahead, I could help stage the materials intelligently, and I rotated my guys, and the tasks, so they wouldn’t get burned out from being on the same end throughout the task. Also, there are plenty of things to do out there, you can take a break from decking and do something else, pick up the decking again in the morning. It all has to get done. I do agree that you don’t want to kill your men doing anything. Work smarter, not harder, Smooth Framing beats Rough Framing any day. Just got to stay busy, and you can easily do that without killing anyone. But thanks for your thoughtful comments. Richard |
#105 | |
I wasn't referring to myself as an **** idiot. It was just a general statement. I only mentioned your name in my post regarding the I’m usually faster statement. Both of us were usually faster at everything ... when we were in our 20's,30's,40's. At our age we need to use the word was instead of I am. John, I kept our forklift rental for an extra 5 days on our current job. It cost me $2800 a month and for the 5 extra days it cost me $2500. For the extra $2500 it cost me I could have hired a plywood tech (subcontractor) to roof sheet our house. I'll never do that again. Sim |
#106 | |
Sim, Our forklift cost was originally going to be 800 a week, which the builder was going to pay. We were going to send it back and then get it again a couple of weeks later when needed again. I decided it would be better to keep it, so I told the builder I would split the additional costs of keeping it for a month. The final charge for 2-16 thru 3-18 was just over 1800. Of that I pay 500. We got a good deal from the rental company. As far as the decking crew is concerned, the cost for them is almost double what is normally charged. This isn't a 7/12 with 7/16 OSB on it, so of course it will run more. I do the same things with guys and tasks, keep them rotating to prevent burnout. I started out cutting rafters, and did almost all of them. When we started on the center section of the house, I wanted to be up nailing. And some guys who were nailing are now sheathing the walls. I will be back down cutting tomorrow, using the Arcus blade for the radius rafters. There are 50 on the front of the house and about the same on the two garages, with radii between 14' and 16'6. There is also a couple of sections with ~7' radius to do. More than likely there will be two of us cutting. This part is really going to give the house it's look, and I am looking forward to it. |
#107 |
Trade: Carpenter- Building and Remolding
another great thread. these thread that you contractors/builder start on your projects is a big inspiration and a big help to young builders such as myself. keep up the great work!
#108 |
Well, I got out to the job yesterday and drew a full scale mock-up of the radius rafters. The plans gave me the radius, I just needed to define the working points of the fascia and tangent intersection with the main rafters.
I used a little bit of math I learned from Joe Bartok. Much obliged, Joe. I used a 2x12 rafter on a 9/12 pitch intersecting the 16/12 main to carve out the 16' radius, then lofted in the hips. I left my Arcus blade at home, in another truck I have been trying to get fixed up to use as my tool vehicle. transfer case needs work now... Anyway, I used the same Diablo blade I cut most of the other rafters with to cut these radius rafters. It worked really good, as a matter of fact I used it today to cut more rafters for another radius section.... |
#109 |
I like Green things
Very nice.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
#110 |
Had a pretty big pile of scrap left after cutting all those rafters.
There are two masonry fireplaces going up through these sections of roof. That's why there is a big hole in the framing... |
#111 |
Today, I started on the 16'6" radius.
That front is finished and blocked in, now I have the garages to do tomorrow, which will be a little tricky because the window sills had to be changed to have them 36" AFF for furniture issues. I'm hoping the decking gets dropped soon, while the weather is good. |
#112 |
Trade: Framing,Remodeling,General Contractor
Are they gonna use 3/4 " to sheet that radius?
#113 |
The radius rafters are held up a quarter inch so 1/2" can be used there. I have it all blocked now to help with the weight issues.
Wrong picture. I think one of these shows the blocking. Last edited by kpatrix; 03-23-2010 at 09:53 PM. |
#114 |
wannabe
Trade: carpentry
That's awesome! I like the use of separate radiused tails from the commons! I'll have to think a bit, but I'm pretty sure that would have simplified things for me, or atleast have made adjustments easier....Thanks!
"I knew I lost my wallet as soon as I threw my pants over the fence". -'lil jarhead bro when asking for a wire transfer... |
#115 | |
Sim |
#116 |
Maybe it's been mentioned but or I just can't find it but,
why the short walls in the first floor framing?
https://www.facebook.com/pages/John-...94183374011504 |
#117 |
Sure, I can do that...
what happens on the underside of the radiused rafters at the birdsmouth?
is that angle visible from inside? |
#118 |
Sim,
There will be lots of man hours in the trim details, that may be a whole new thread. The cove/fascia returns into the window trim. We are looking towards coordinating with the brick mason for staging, because of all the overlap in our work. It is really going to get complicated. Right now we are using pump jacks for the wall sheathing and WRB. Oldfrt, The short walls are architectural- They allow for clipped ceilings throughout the second floor. When you walk through the upstairs, the low walls make it cozy, while the 9'4" ceiling height adds gives depth. While framing the walls, it seemed odd, but now that the roof is on and we are flattening the ceilings, it really gives the house character. The steep roof helps with this, with three feet of run giving four feet of rise. Had the walls been any taller, then the flat ceilings would have been out of proportion to the doors and windows. I will try to make a video walk through some time this week. |
| The Following User Says Thank You to kpatrix For This Useful Post: | oldfrt (03-23-2010) |
#119 | |
At one section, in the center area, I had to make an elongated level cut to avoid having the rafters hang below, with a beveled plate wedged between rafters and joists. |
#120 |
Been out there busting a$$ trying to get things done, starting to look like a house. Turned in a draw on Monday... Haven't seen the super all week.... Out there this morning and power company showed up, red tagged the power pole, shut us down. Called the office and phones were disconnected. Not looking good....
| Starting a Custom Tommorrow | galla35 | Framing | 16 | 01-22-2011 12:53 PM |
| Custom ver Manufacture | Roberts Ren | Finish Carpentry | 6 | 12-02-2009 11:34 PM |
| Is a custom website important | karunnt | Websites and SEO | 12 | 11-25-2009 04:58 PM |
| Custom Home Builder vs. Spec and Tract Builder | renet | General Discussion | 4 | 11-16-2008 01:51 AM |
| Custom Garage and Custom Deck Builder Subs Wanted Illinois | hendron24 | Help Wanted or Looking For Work | 0 | 10-22-2008 12:47 PM |
