Confused About Framing A Second Story Deck With A Roof
Old 05-20-2012, 05:56 PM   #1
dvatt's Avatar
Rewards Points: 380
I have seen a few pics on here of decks with a roof and there isn't a drop beam and the rim joist is just thru bolted into the 6 x 6 is this acceptable? I have always used a drop beam right at the rim joist, cantilevering minimally. Please advice.
dvatt is offline
Old 05-20-2012, 06:00 PM   #2
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Re: Confused About Framing A Second Story Deck With A Roof
I've done a number of decks with flush beams, but they are always notched into, or sit on top of a post with the proper hardware attached.
loneframer is offline
Old 05-20-2012, 06:02 PM   #3
The Sheriff
Jaws's Avatar
Rewards Points: 5,432
Notch the 6x6. I like to cantilever to hide the posts and beam, somewhat.
Jaws is online now
Old 05-20-2012, 06:02 PM   #4
The Sheriff
Jaws's Avatar
What he said.
Jaws is online now
Old 05-20-2012, 07:00 PM   #5
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,704
If you don't use a beam, you should at least double your rim.With a notch in the posts. I am not an engineer. but I think I could be.
NKLHD
knucklehead is offline
The Following User Says Thank You to knucklehead For This Useful Post:
Jaws (05-20-2012)
Old 05-20-2012, 07:03 PM   #6
dvatt's Avatar
Rewards Points: 380
I always notch as well and use a beam. Just seems standard.
dvatt is offline
Old 05-20-2012, 07:17 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,881
Both levels of this guy have the rims on top of the posts. That's generally how I do them.
Tinstaafl is offline
Old 05-20-2012, 07:32 PM   #8
dvatt's Avatar
Rewards Points: 380
Is that one continuous 6 x 6? Are you using hangers on the joist for the rim joist
dvatt is offline
Old 05-20-2012, 07:48 PM   #9
Capra aegagrus
Tinstaafl's Avatar
No, the deck rim sits on top of posts, with the upper posts sitting on that. And yes, joist hangers. Can't get away without them with that type of construction.
Makes for a cleaner look without the extra beams underneath.
Old 05-20-2012, 08:04 PM   #10
dvatt's Avatar
Rewards Points: 380
What are you using to tie in the 2nd level 6 x6 to the rim joist? A Simpson strong tie of sorts? Any particular one?
dvatt is offline
Old 05-20-2012, 10:50 PM   #11
Capra aegagrus
Tinstaafl's Avatar
The upper post is simply toenail-screwed to the rim, decking and blocking. With the weight of the roof assembly, you really wouldn't need a heckuva lot more than a couple of finish nails to keep it from walking, but I load it up so there are no uplift concerns.
If we were in a high wind area, no doubt I'd need to do more than that.
Old 05-21-2012, 09:40 AM   #12
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,494
The IRC 2009 says you can no longer just bolt a beam or rim to the post(s)
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
(page 8)
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 05-21-2012, 10:34 AM   #13
bmcquin's Avatar
Trade: deck builder
Rewards Points: 1,322
I do build in a high wind area and we are required to use Simpson type LSTA Z-max for band to post connection, the length depending on whether or not we are connecting a beam to a post or two posts separated by a beam like Tin shows.
There also a whole lot more connectors we have to use for roof framing and such.........
bmcquin is offline
Roof top Deck issue mandaloril Decks & Fencing 22 04-24-2012 10:19 PM
Opinion on deck framing Captainsls Decks & Fencing 14 12-06-2011 05:16 PM
Looking for a roof deck subcontractor (Boston, MA) brianford Business 1 04-29-2011 06:35 PM
roof framing complexities help. Timber1 Roofing 7 01-10-2011 07:10 PM
Bison deck supports for roof deck Chris G Decks & Fencing 20 11-17-2010 04:36 PM
