Can You Get It Up?
Old 11-14-2007, 10:15 PM   #1
bluehomes's Avatar
Trade: homebuilder/framer
Can You Get It Up?
figured that'd get your attention. I've got a gable end wall to stand 22' high at peak. Too muck for wall jacks. Any suggestions? Also what do you think of installing windows before its stood?
bluehomes is offline
Old 11-14-2007, 11:04 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Re: Can You Get It Up?
How wide is it? We did a wall about 19' tall at the peak (lots of windows, not set just headered 2x8's) of course the wall was 2x6 and was around 22' wide. 3 of us stood it using brute strength and some braces as we went up. I will tell you that it was not a lot of fun and I would prefer to never do that again... But you know how life is.
RobertCDF is online now
Old 11-14-2007, 11:54 PM   #3
Joe Carola's Avatar
Trade: Framing Contractor
Originally Posted by bluehomes View Post
figured that get your attention. I've got a gable end wall to stand 22' high at peak. Too muck for wall jacks. Any suggestions? Also what do you think of installing windows before its stood?
Don't sheath it and just stand it up. Or, set the gable end rafters and set the ridge and fill in the gable studs after.
Joe Carola
Joe Carola is offline
Old 11-15-2007, 12:12 AM   #4
Putty Truck's Avatar
Trade: hjrafiuoashfed
Frequently.
Putty Truck is offline
Old 11-15-2007, 06:45 AM   #5
joasis's Avatar
One more reason to own a high lift. We don't set trusses the hard way anymore either.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 11-15-2007, 03:26 PM   #6
jmic's Avatar
My wall jacks are 23' tall and I don't know how long the wall is that you're doing , but I don't see why if you set a wall jack 1/3 of the way in from each end you'd have a problem.
Joe
jmic is offline
Old 11-15-2007, 04:48 PM   #7
KentWhitten's Avatar
no, don't put windows in unless you're feeling lucky or can take out the sashes. too much chance for braking by someone with the butt end of a 2x. wait until you're done.
what kind of wall jacks you got? cable or 2x4 kind? cable ones should have no problem. I used 2x4 ones and you have to get a little creative. I might go as far as just nailing the plate down and nailing up one stud at a time. Have a guy stock and one on the staging.
Any way you look at it, gable walls take extra time.
Salmon Falls Cabinetry
KentWhitten is offline
Old 11-15-2007, 05:12 PM   #8
jmic's Avatar
My wall jacks have cable and are made by Proctor. Big, big life saver when you run a small crew or a one man show.
Joe
jmic is offline
Old 11-15-2007, 09:36 PM   #9
bluehomes's Avatar
my wall jacks are for use with 2x4's. I'll look into the cable kind, if all else fails think I'll rent a crane. Thanks guys
Old 11-15-2007, 11:00 PM   #10
Al Smith
A W Smith's Avatar
Joe Carola has the common sense answer. Why bother to rent a crane or wall jack for one wall? Stick frame it in place stud by stud.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 11-15-2007, 11:29 PM   #11
NorthstarNC's Avatar
Trade: Jackleg
Indeed.
NorthstarNC is offline
Old 11-16-2007, 02:59 PM   #12
mattvc's Avatar
I always did the balloon walls in short tall sections and used bunches of 2x4 braces. Atleast 4 guys helps a lot. And I always do those walls before the other walls (so that you've got room to work) I only used a crane one time, ever, to lift a wall like that. But that wall was 28' (or so) tall and had windows and windows and windows. All the headers made it really heavy. Just my opinion.
mattvc is offline
Old 11-16-2007, 08:46 PM   #13
Pavola's Avatar
I agree, but using wall jacks on a gable wall comes with a whole new set of rules.
Wouldn't window manuf. void their warranties from the possible stress on them because no wall lifts up perfectly flat.
Pavola is offline
Old 11-16-2007, 09:04 PM   #14
Joe Carola's Avatar
Can you please explain to me, why in the world would you rent a crane to frame a gable wall?
Joe Carola
Old 11-16-2007, 09:57 PM   #15
constructionldr's Avatar
Trade: General Contractor........Commercial/Residential
not to stray from subject...but on a 64"w window, 2 x framed wall, a 2 x 8 would be good enough for a header or jump to a 2 x 10??
constructionldr is offline
Old 11-16-2007, 10:06 PM   #16
Al Smith
A W Smith's Avatar
if its a gable wall it bears nothing, 2x8 would be fine.
Al Smith
Old 11-16-2007, 10:26 PM   #17
My bad...it would be in a load bearing wall
Old 11-16-2007, 10:39 PM   #18
Al Smith
A W Smith's Avatar
It all depends on the loads above. is it just a ranch? is there a room above? is there a similar window or opening above it which trasfers the loads around your header in question? or is there an offset window above it which concentrates a load over the center of your window? when in doubt use a Span Chart
Al Smith
Old 11-16-2007, 10:46 PM   #19
simple ranch...6/12 pitch 2' overhangs, tin roof. Thanks for the input
Old 11-16-2007, 11:01 PM   #20
Al Smith
A W Smith's Avatar
2-2 x 8 header would be fine then. But why bother blocking above a 2x8 header when its faster to just use a 2 x 10 with a 2x4 cap that will fill in the space fully above your opening? (assuming your studs are 92 5/8 pre cuts)
Al Smith
