Calling All Roof Framers ( Help!?)
Old 01-09-2009, 08:30 AM   #1
djmesh's Avatar
First off im from the uk, so we dont do a lot of roof framing its mainly trusses. anyways iv attached a sketch of a small roof below, its a regular hipped roof, the rafters on all planes of the roof are to be a 35 Degree pitch.
Normally when framing a hip roof, we will drop the hip, but its important on this occasion that we plane on the backing angle. my question to you guys is how do i find this angle practically when on site? given the above dimensions etc.
Probably sound like a noob
any help would be massively appreciated guys
djmesh is offline
Old 01-09-2009, 09:16 AM   #2
Joe Carola's Avatar
Trade: Framing Contractor
Re: Calling All Roof Framers ( Help!?)
Attachment 13976
Do you use a framing square to figure out your rafter lengths or a Construction Master calculator? That answer will let me know what way to show you.
You said the pitch is 35°. That makes it around a 8-3/8:12 pitch. The backing angle is 23.92746° or 24°. Are you backing this because it's a wide hip or the bottom of the hip is planing in with the bottom of the jack rafters because of a cathedral ceiling and sheetrock?
Joe Carola
Joe Carola is offline
Old 01-09-2009, 10:48 AM   #3
djmesh's Avatar
I do my framing using a speed square its being backed because the drawing states that it must be as part of regulations, no idea why to be honest. so how do you work it out as 24 degrees then?thanks
djmesh is offline
Old 01-11-2009, 07:27 PM   #4
Aframe's Avatar
Trade: Carpenter/GC
Using Framing square (in inches sorry)
Common Rise /over Run = ex. 8:12
Common rise /45 degree hip run = 8:17
It will be the same as if you were planing off the top of the rafter, you will or need to raise or lower the seat cut to match the rafter face your lining up with
Speed square gives you common and hip angles on different scales,
Correct me if I have this wrong but, does the drawing matches the dimensions you have?
By the dimensions you give 2500/2600mm you either have to give up a true 45 degree hip or adjust the pitch on one plane of the roof.
Aframe is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Roof Cleaning Pictures Wanted !! Roof Cleaning Pressure Washing 5 09-07-2010 09:24 AM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
