Trade: GC/Developer
Bracing I-joists After Subfloor Installed.
I have a situation where I shouldnt need bridging for some wood I joists because the spans are really short. However the building inspector disagrees and wants me to add some bridging.
Normally for I joists I install the tension bridging from Simpson that nail to the top of the I joist before installing the subfloor. It connects to the lower edge of one ijoist and then the top of the next and the bottom of the third. I tried to use the regular nail into the side (with the little spikes) bracing that you use for regular 2x10s but because the flange of the I joists is wider then a regular 2x10 the bracing doesnt fit. Other then cutting up ijoists or using solid would blocking is there any good bracing that I can use to prevent twisting. As per the trusjoist website and my engineer I dont need them on this size span based with the joist hangers I use but I just need to find something easy to satisfy the engineer. |
#2 | |
Re: Bracing I-joists After Subfloor Installed.Quote:
You can brace the joists just to kiss his posterior, or see if you can get the engineer to document the issue for him (paper trails make idiots nervous, but will make an enemy out of him), or go to the board of appeals for your inspector and good luck.
Chief Toilet Mover
Trade: Bathroom Remodeling
What would be wrong with asking the inspector to show you where in the code it says you need what he is "requesting"? Unless things are different where you are this is all we do, we do it politely,like "hmm, never knew about that, now where in the code book does it say that so I will know for the next time?"
Thom
Or, you could cut 3/4" ply to the full width and depth, notch the corners of the ply for the flanges of the I joist, nail through the joist web into the plywood, and the inspector is happy.
#5 | |
Trade: Framing Contractor
All you’re doing now is preventing this ignorant inspector’s brain from twisting more than it already has.
Joe Carola |
Recovering Computer Guy
Trade: Home Improvement
Re: Bracing I-joists After Subfloor Installed.I wonder if a "rat runner" 1 x 4 across the bottom of all the joists would satisfy the inspector. Have you asked him about something simple like this? At this point it would be pretty painful for him to back down, but he may agree to a compromise as long as it doesn't *look* like a compromise.
I was looking at a new home awhile back that had a full basement, and it had I joists spannig maybe 36 feet. So anyway, I remeber seeing something there that was "interesting". Rather then blocking or bracing, the I joists were strapped in an X pattern with 1 inch wide brace or nail strapping....one strap over and under and over, and the parallel under and over and under, and so on.
Now I don't know if I would do this, but structurally, probably works fine, and perhaps this was a temporary anti twist thing that was left in when the sub floor went down. Looked like it was nailed off with 6d's and there were 2 runs of this on the length of the basement...maybe 60 feet. Anyone else seen this done?
Trade: GC/Developer
The bracing that joasis was talking about is actually what I normally use on I-joists in situations where it is called for. But you cant really get those in after the fact as one goes over and one goes under. It is exactly that, an anti twist thing.
In this building the engineer spec'd that the load bearing wall be steel and go all the way up to the next floors plywood. the joists then hang from that using top mounted hangers with fire rated plywood as backing. So in reality these joists runs are really small, either 8' or 12' feet. I am trying to dance the dance and not annoy him. I know I can cut up Ijoists but was trying to avoid that as the plumbing and electric are already roughed in. I was really looking to see if anyone knows of a metal brace like the over/under one I am using now that can be installed after the fact. |
| Sistering Sagging Floor Joists.... | AllGoNoShow | Construction | 22 | 02-25-2011 04:37 PM |
| Framing Roof Joists for Addition when top Plate is not Level | personalt | Framing | 3 | 07-20-2007 06:52 AM |
| Engineered Floor Joists....... | LEVELBEST | Construction | 2 | 01-07-2007 06:40 PM |
| Top mounted hangers against fire rated plywood, do studs and joists need to line up? | personalt | Carpentry | 2 | 08-20-2006 04:24 PM |
| Vaulted ceiling/no ceiling joists | medusa | Framing | 8 | 12-22-2005 01:57 PM |
