Beveled Bearing Plate For I-Joist Roof
Old 11-11-2009, 07:40 AM   #1
PlumbBob^2Pants's Avatar
Trade: Homebuilder
We're going to be using I-Joists on a roof for the first time, and the engineer has specified a beveled bearing plate on the top plate for the I-Joists to rest upon. The walls are 2 x 6 and we have a couple of ideas for the bearing plate: rip a beveled plate out of 6 x 6 post, or build up 2x material where each layer of 2x has been individually run through a table saw.
We're just looking for the fastest (and most cost effective) way to do this, but not sure how everyone else is doing it.
PlumbBob^2Pants is offline
Old 11-11-2009, 07:53 AM   #2
genecarp's Avatar
Re: Beveled Bearing Plate For I-Joist Roof
PITCH? what is it 3 pitch or 12 pitch?GMOD
genecarp is offline
Old 11-11-2009, 06:43 PM   #3
We have done this on 2 roofs. I ripped the bevelled plates out of a 2x4 to get two plates per rip. That gives plenty of bearing, on a 7-12 that is about 3" of bearing.
It is a very speedy process and not cutting a birdsmouth saves a lot of time. Also on your gable, lower your gable rafter and build a wall under it. This way you can put your lookouts over the top w/out notching.
Here is the photo album with these details. http://picasaweb.google.com/TimothyUhler/Lot35Muirkirk#
Timuhler is offline
Old 11-11-2009, 07:33 PM   #4
cbfx3's Avatar
Trade: Framing and General Construction
Ive done this by ripping 2x's
cbfx3 is offline
Old 11-11-2009, 07:43 PM   #5
KemoSabe
loneframer's Avatar
We sent these 6x Glu-Lams out and had them ripped by a local shop.
loneframer is offline
Old 11-11-2009, 08:18 PM   #6
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
I would use an individual shim on each rafter, then block between
knucklehead is offline
Old 11-11-2009, 08:38 PM   #7
ClemS's Avatar
Trade: Framing
that sounds like a horrible idea.
ClemS is offline
Old 11-11-2009, 08:45 PM   #8
Why?
Old 11-11-2009, 11:47 PM   #9
Trade: Homebuilder
Gene, it's a 12:12
Thanks Tim. Good tip on lowering the gable rafter. When you used a 2x4 for your beveled plate how'd you handle the open space left between the top plate and the bottom of the I-joist?
Old 11-11-2009, 11:58 PM   #10
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
On a 12/12 you would just be beveling one edge of a 2x4 and standing it up on the bevel. Then you need to rip another one to prop under the high side.
You would be better off ripping a 4x4 in half on the 45 and use both pieces for a full 3 1/2" bearing.
5/8" rock could span the gap between the top plate and the bottom of the rafter.
What is the stud size?
Gus Dering is offline
Old 11-12-2009, 12:36 AM   #11
Trade: Homebuilder
Looks nice, Loneframer!
Old 11-12-2009, 12:56 AM   #12
I used to think so.......
wallmaxx's Avatar
Lindal sent out pre-ripped bevel pieces out of 2x4 and I added a 2 3/4" ripped piece behind it.
As long as you are using spec'd straps to connect the TJIs to one another at the ridge and the ridge is braced or structural, then there won't be much shear load at the plates. You will also be adding some kind of clip or strap at the plate (if Simpson has their way)
wallmaxx is offline
Old 11-12-2009, 01:15 AM   #13
Trade: Homebuilder
Gus, the studs are 2x6x104-5/8. We've priced out 1/2" sheetrock for this build. 4x4's would work, but we'd just about have to go to the lumber yard and hand-pick them because we couldn't rely on them to deliver nice straight ones to us. Beveling a 2x6 on one edge and standing it up on the flat edge would cover the space on the high side, for sheetrock.
Going by loneframer's recommendation, we could use a 5-1/8" x 4-1/2" glulam and then stack a few pieces of OSB on the high side to bring it out flush to the wall for sheetrock.
Old 11-12-2009, 01:22 AM   #14
Trade: Homebuilder
Originally Posted by wallmaxx View Post
... You will also be adding some kind of clip or strap at the plate (if Simpson has their way)
Exactly ... twist straps and backer blocks are specified at the plate.
Old 11-12-2009, 06:45 AM   #15
Tom Struble's Avatar
Trade: siding
thats what she said?
Tom Struble is offline
Old 11-12-2009, 09:02 AM   #16
Just curious why a single 2x4 isn't enough? On a 12-12 you would have 2 1/8" of bearing. That is more than enough to transfer the load.
PlumbBob^2Pants,
We just ignored it. The drywall will span that easily. We normally only have about a 3" seatcut on dimensional lumber anyway, so this isn't an issue for us.
Last spring we drywalled the house we framed in the winter and framing the roof like this wasn't a problem when we drywalled. I'll try and get some shots today that show how this works.
Timuhler is offline
Old 11-12-2009, 04:02 PM   #17
Trade: Homebuilder
Thanks Tim, pics of that would be very helpful and much appreciated.
Old 11-12-2009, 05:33 PM   #18
Gus Dering's Avatar
With a 2x6 plate you would need about 7 13/16" piece of stock ripped on a 45 from long point to long point for the bevel on the inside to stack with the interior stud face. That seems a bit extreme to me.
Not sure how you are thinking a 2x6 would give you backing for drywall as you described. Maybe that was a brain fart, I'm intimately familiar with the syndrome.
Your 1/2" drywall will span the 5 1/2" IMO.
I would see if you can get this passed. All the cuts are easily handled on site and you only need one course of 2x4 to pull it off.
I hope this helps
If you really wanted backing at the rafter line, just rip another 2x and nail it on the bottom of the rafter.
The Following User Says Thank You to Gus Dering For This Useful Post:
wallmaxx (11-12-2009)
Old 11-12-2009, 07:04 PM   #19
Trade: Homebuilder
I hope this helps
Gus, thanks for taking the time to draw that out. Here's what I was talking about for backing to nail the sheetrock to ...
Old 11-12-2009, 07:06 PM   #20
Trade: Homebuilder
Gus, here's another option I thought about before you and Tim convinced me that the drywall spanning a 5-1/2" void across the top of the wall wouldn't be a problem ...
Deck Screws vs Joist Nails subybohn Decks & Fencing 100 11-25-2009 03:52 PM
Joist hanger for dropping down a joist to beam connection Btrbimmer Decks & Fencing 4 10-06-2009 12:07 AM
Load bearing wall removal options ikessky Remodeling 11 08-24-2009 01:40 PM
flatroof to pitched. Insulating above old roof Red Adobe Insulation 2 07-14-2009 11:30 AM
Ice Problems on a roof J-Peffer Roofing 4 10-01-2008 11:12 AM
