Best Framing Nailer?
Hey all,
My POS Porter cable has destroyed it's buffer after only 2 years. I am going to fix it, but it needs to be relegated to back up status because I just don't like it. Does anyone have the new Hitachi N90? What other guns have YOU used that work well |
It is what it is
Trade: Roofing, Remodeling, Concrete
Re: Best Framing Nailer?
I went through 2 of those new Hitachis, Both jammed up and broke the driver.
Patriot Broadcasting Network |
Trade: Remodeling contractor
Bostich stick & coil framers work well for me in production . Paslode cordless awesome for small frames.
Back in Maine Dubbin' Around Doin' good stuff ...... |
Trade: Carpentry & Remodeling
Bostitch 28 degree stick nailers. Got 3 no problems
Do what you would do, as if i won't Do anything after you Did It! |
I like Green things
Bostitch works great for me, if they ever die (please!!!!) I will replace with Grex.
Rock it...
I built 3 houses ground up with the new hitachi and no problems so far. And its not been friendly up here weather wise. Just my 2 cents.
i had a porter cable two hitachii's and neither of them compage to my max framer...the front opens for jambs....inc.. also lighter....they also have a real low profile model the whole head of the gun is lower.
strat hd
Trade: framing contractor , remodeler , GC occasionally
Used paslode for years than I went to senco. I have a hitachi and 3 sencos. So far I really like the hitachi. Who makes the max framer ?
Trade: Home Builder
Paslode - Not because it is the "best", but I can buy the nails everywhere around my area. So it is a convienence thing for me.
strathd,
max usa ..... do a gooel search on it ..i first seen it at my local "White Cap Construction Supply" look for the SN883Rh thats the smaller profile one....the also are the makers or the automatic rebar tiers never used one but suposed to be good ...i just noticed they are making cordless nailers now also |
Carpenter/Finisher
Ive used my hitachi in -10 and 100 and havent had any prbs with it. On its third year
1st Gen tradesman My summer job in college became my profession |
Trade: Remodeling / Carpentry
If you have a service center nearby as I do:
Tools of The Trade: "Our top choice is the Max" http://www.toolsofthetrade.net/indus...ticleID=649074 I'm a remodeler. It's lightweight, well balanced, only 12 1/2" hgt not as much recoil as many other guns. However, not the best going through eng wood products. Last edited by We Fix Houses; 01-19-2009 at 02:21 PM. |
#13 | |
Trade: Lead Nail Bender....
Re: Best Framing Nailer?Quote:
Had Hitachis now for 6 years or more. Never had any problems. I like the coils...don't have to reload and the slide is ackward. Dropped a friends stick nailer Hitachi three time off a roof on concrete from 8 ft or so...never did a thing to it. Wasn't used to holding it...I felt pretty bad about it.
Course those guns are older and a lot can change in a few years with a product. I would never have bought a Bostich years ago because the seals were always going bad a leaking. I think they have fixed that now. Bought a bostich finish nailer a year ago and I like it a lot. Josh Jaros |
#15 | |
Im a full believer in Paslode, i bought mine from a framer used he had it for 5 years, i own it for 3 a total of 8 years, with me it had fallen of the 2nd floor of decks a few time, and about 1 time in a house which cause it to leak a bit now, but want to count NUMBERS, try this, commercial fencing 4-5 nails per board, and i est about 54,000 shots i have done in 3 years and the bastard still goes. Mind you its a heavy gun
Custom Decks Custom aquarium all salt water Renovation next on my list............planting trees for all those material i used |
Tool Junkie
I use the hitachi nv 75 ag for everything I started out using it strictly for siding but found that it can take a lot of abuse i run my compressor @ 150 psi & have had no problems in 4 years
| Hitachi VH650 Coil Framing Nailer | GitSum | Tools & Equipment | 0 | 11-06-2008 03:01 PM |
| New framing nailer | fredbuilt | Carpentry | 8 | 08-17-2008 05:32 PM |
| Who uses a coil framing nailer? | buildenterprise | General Discussion | 12 | 05-01-2008 12:58 PM |
| New Hitachi Nr 83a2(s) 3 1/4" Framing Strip Nailer | Jdove | Contractor Swap | 2 | 04-02-2008 10:39 PM |
| max coil framing nailer for sale | judsteam | Contractor Swap | 0 | 05-25-2007 04:04 PM |
