Best 18' Garage Door Header
Old 06-21-2012, 06:18 PM   #1
txgencon's Avatar
Rewards Points: 384
Double 1-3/4" X 11-7/8" LVL
or 3-1/2" x 11-1/4" Glu-Lam?
I've always used Glu-lam's in the past but nowadays they're $60 more so the suppliers seem to assume you'll want the LVL's.
The Glu-Lam has a very slight arch to it (unloaded).
What are your thoughts?
The $60 difference is not an issue.
txgencon is offline
Old 06-21-2012, 06:22 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Best 18' Garage Door Header
Have you sized out and priced a wide flange beam yet?
Chris
Chris Johnson is offline
Old 06-21-2012, 06:56 PM   #3
txgencon's Avatar
Rewards Points: 384
No, this is for a single story structure with a fairly small ceiling and roof load.
Steel would introduce some additional connector issues and be overkill.
I've never had an issue with excessive deflection with the Glu-lam, possibly due to the positive camber.
A loaded LVL will have some defelection. Normally, deflection isn't too noticeable, but with a garage door header you have the reference of the door. If you go with a raised panel door, it is even more noticeable if there's any sag.
txgencon is offline
Old 06-21-2012, 06:58 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Glu Lam...
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
ohiohomedoctor (06-21-2012), ScipioAfricanus (06-21-2012)
Old 06-21-2012, 07:40 PM   #5
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 856
Originally Posted by griz View Post
Glu Lam...
I agree.
Andy.
ScipioAfricanus is online now
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
hdavis (06-21-2012)
Old 06-21-2012, 08:22 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,209
We almost always use lvls for garage headers. No issues that I have seen. If it makes you feel better, go one size bigger and compare that cost.
Warren is offline
Old 06-21-2012, 09:03 PM   #7
PaulPrice's Avatar
Rewards Points: 226
I like lvl's personally.... I don't really have too much experience with glulams (used one once).
My main thought here is that lvls are readily available, and you can half the wieght.
half the wieght because you can set them one at a time
PaulPrice is offline
Old 06-21-2012, 09:28 PM   #8
txgencon's Avatar
Rewards Points: 384
Weight is not an issue, I have lift equipment. I'm pretty sure I'll insist on a Glu-lam so I don't have to nail/bolt the two LVL's together.
Thanks to all who commented.
txgencon is offline
Old 06-21-2012, 09:38 PM   #9
General Contractor
greg24k's Avatar
Rewards Points: 7,024
Is that a bearing wall and if yes what is the load that header will be supporting? In some cases you will need a larger header then 3.5 X 11.5 header to carry the load over an 18' span.
greg24k is offline
Old 06-21-2012, 09:40 PM   #10
Geometrist
Warren's Avatar
3 clips of nails, and 3 minutes of time. I will take the sixty bucks.
Warren is offline
The Following 2 Users Say Thank You to Warren For This Useful Post:
Brutus (06-23-2012), slowsol (06-23-2012)
Old 06-21-2012, 10:01 PM   #11
txgencon's Avatar
Rewards Points: 384
I've used LVL's before in a floor system. The specs specified a specific nailing pattern and either 5/16" bolts or 16d CC sinkers (different pattern depending on which fastener used) and PL construction adhesive. I've not found a source for this kind of gun nail.
I'm assuming the same would hold true for this application.
txgencon is offline
Old 06-21-2012, 10:08 PM   #12
txgencon's Avatar
Rewards Points: 384
It's a load bearing wall on a 22' wide structure with 2x10 ceiling joists with 5/8" fire rated rock and a 6/12 pitch roof with 300#/sq roofing. Boise spec'd the LVL's mentioned. A 3-1/2" x 11-1/4" Glu-lam is a structural step up.
txgencon is offline
Old 06-21-2012, 10:09 PM   #13
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,602
Lvl cheaper? Not here- lvl is the more expensive option here in southern Utah. I just priced a 26' beam and lvl was $100 more. If I had a way to put em up I'd use glb but where I have a 3 man crew right now I use lvl, one at a time. I always nail 3" o.c. Vert and 12-16 o.c down the length. Unless I have engineering that details a pattern of course.
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
Old 06-21-2012, 10:16 PM   #14
Geometrist
Warren's Avatar
Gun nails can be used on lvl. Minimum size is .128. Just need a few more.
Warren is offline
Old 06-23-2012, 02:02 AM   #15
SoCalWoodWork's Avatar
In Los Angeles, everything here is overkill seeing homes built in the 40's and 50's without the expensive hardware are still standing, even through all the quakes. On garage openings we always put simpson strong walls on either side of the garage and mount a parallam across them, attaching up through the strong wall with 3/8" lags. Parallam are fairly heavy compared to a glue-lam or even a fir beam.
SoCalWoodWork is offline
Old 06-23-2012, 06:13 AM   #16
Carolina Surface Prep
Rob1954's Avatar
Trade: Media blasting and residential restoration
Rewards Points: 202
"A 3-1/2" x 11-1/4" Glu-lam is a structural step up."
You should have someone verify that before you install a Glu-lam where an LVL beam has been specified. Glu-lams are available in different grades and layups.....some are stronger than LVL.....some are not. And 5/8" difference in the depth can make for a considerable difference in the stiffness of a shallow beam.
Rob1954 is offline
Old 06-23-2012, 08:03 AM   #17
txgencon's Avatar
Rewards Points: 384
I had the supplier go back to Boise Cascade and specify what I wanted and its application. The person doing the takeoff had interpreted my request for an "18'-9" garage door header" to the least expensive 20' long beam. On previous projects, I have been supplied a Glu-lam Boise makes specifically for garage door headers that was 3-1/2" x 11-1/4" x 18'-9". The beam they have specified now is 3-1/2" x 12" x 18'-9". This beam is "suitable for garages with a second floor above".
txgencon is offline
Old 06-23-2012, 08:17 AM   #18
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Like this..
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
Tom M (06-23-2012)
Old 06-23-2012, 09:58 AM   #19
slowsol's Avatar
Rewards Points: 2,192
We pretty much use LVL's exclusively.
-John
slowsol is offline
Old 06-23-2012, 10:02 AM   #20
Tom M's Avatar
Rewards Points: 3,618
I would lean towards a power beam at 18ft or try the new LSB.
Tom M is offline
Bloodmoon (08-20-2012)
2 spare breakers 15 & 20a, want to wire outlets in garage pitterpat Electrical 8 05-13-2012 03:58 PM
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 09:14 AM
Garage problems.... nwksremodeler Remodeling 29 05-12-2010 03:55 PM
does the garage really need the GFI? handyman99 Electrical 21 08-31-2009 12:33 PM
