Beam Situation
Old 09-16-2008, 04:31 PM   #1
rakuz66's Avatar
Trade: carpentry
Beam Situation
Ok, I thouht I was helping my cause, but I guess I'm wrong. Here's my situation. I have a vaulted ceiling that runs 16 ft long. Rafter span is 11 ft ( half the roof/ from wall to ridge). Total span is 22 ft. Snow load is 70#. I have 4 beams at plate level in this 16 ft holding walls together. I thought that if I placed a double 2x12 SPF#2 beam under the 2x8 rafters ( 19.2) ctr at their halfway point ( 6ft) that I would be helping support them. Come to find out that this beam may actually be " pulling" on the rafters and "weighing" them down instead of supporting them because it's undersized. Take into account beam is properly supported at both ends with posts and footings. Engineer said I really don't need beam anyway.
Should i take it out?
Replace it?
Is it pulling and weuighing down rafters?
rakuz66 is offline
Old 09-16-2008, 04:48 PM   #2
Meetre's Avatar
Re: Beam Situation
engineer says you don't need it, is it causing any other problems? posts for the beam into living space? any reason to take it out? don't make work for yourself.
Meetre is offline
I Beam ....or another alternative bkcm111 General Discussion 9 03-14-2008 05:33 PM
Steel beam replacement BHI Carpentry 17 02-28-2008 12:03 AM
need some advice framing to a beam Vabuilder Framing 23 02-22-2008 04:41 PM
Updating main beam in century-home: end. bob_cntrctr Framing 8 02-07-2008 04:04 PM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 10:58 PM
