Fast Fred
Guest
Posts: n/a
Basement Wall Frosting
I am currently finishing my basement. I live in Northern WI so the temps this time of the year get "COLD".
I have my basement framed and insulated. I built 2 X 4 walls and have insulated them with R13. I insulated the wall and after a few days I began to insulate them. I was suprised to find "FROST" on the back side of the insulation, which was against the concrete wall. I went ahead and placed 4 mil poly on the interior framed wall. My question is whether or not the frost is a concern? Was it a result of not having the vapor bear on the wall? I assume the tempture difference between the heated basement and the cool concrete wall caused the frost...... but I am now questioning my thoughts. HELP! |
#2 | |
scaryjerry
Guest
Posts: n/a
Re: Basement Wall Frosting
It might be more ideal to use a celotex type insulation. between the block/concrete wall and your framing
You really dont want moisture trapped in with the insulation. Mold will thrive on it and you could get yourself into a bad situation. Quote:
Chief Toilet Mover
Trade: Bathroom Remodeling
Ridgid foam insulation between the basement wall and the 2x4 studs.
Trade: plumber/gasfitter/steamfitter
frost on basement walls is definitly a humidity(moisture problem) and can be caused by inadequite drainage. Wicking is how it gets through,when it gets cold the moisture expands and pushes its way through. I believe that proper drainage outside is the most important, sealing infiltration points at the sill or wherever else air can get in is important inside, as well damproofing is recommended to seal the wall inside as well. frost will cause damage and create pitting on your wall, repair these first with hydraulic cement and then damproof. Ignoring the problem and hoping that a vapour barrier and extra heat or different insulation will cure it is asking for big trouble as well expensive repairs and wasted materials. Look for your leakage points first and then seal them,next damproof and this should cure your problem. I feel that mould will grow on the rigid insulation so this is a bandaid and not a cure.
If anyone has extra experience to help here please chip in. |
#5 | |
Trade: builder remodelor
Re: Basement Wall FrostingQuote:
Trade: I am a residential builder.
Living here in Upper Michigan, I've done quite a few basements. There are a few ways to go. I normally like to use 2" rigid that has 1x2's built into it for finish wall. Another way is to use 2" metal Z-channel available at any drywall/metal stud supplier. But the rigid is the way to go. But sometimes you may have an older basement with cmu walls that aren't very plumb, then I would use either metal studes or wood studs with the bottom plate being pressure treated with fiberglass insulation but leave at least a 1" gap between back of insulation and cmu wall. I also normally use a vapor barrier on the heated side of the wall. Actually your cmu wall shouldn't be all that cold under the 42" frost line. I'm assuming you don't have a leaakage problem in your basement currently. The use of a drylok product before wall assembly would also be a good idea. Just a little Finnish food for thought!
Hudson Valley
Trade: Restorative Painting
Use a hair dryer, heat gun, something to dry a section of wall. Use duct tape to tighly seal a piece of aliminium foil to basement walls, after 24/48hrs
If the outside of the foil is wet, you got condensation; if the side of the foil against the wall is wet, you got seepage. Check gutters, downspouts, siding, grading etc: Look for reasons that water may not be draining away from foundations. How old is the house? Was the exterior waterproofed? What drainage is underground? Is the house at the bottom of hill? Rigid insulation is the way to go. Take out the fibreglass and vapor barrier: Vapor barries trap moisture and will create a breeding groud for rot and mold in wall cavities. This will not only damage walls [masonary and wood], but also unhealthy air quality. And never carpet a basement. www.buildingscience.com is a good start for info also Fine Homebuilding 169 March 2005 has a great article, check your local library. Good luck with the project
www.blueskiesrestorations.com There's some top class people on this forum,........and then there's me...Touching cloth. |
#8 | |
Trade: Residential custom home builder
While you might take the advice given here and use rigid foam, your best bet might be to use nothing at all. Minnesota's upcoming building code changes allow remodelers to skip insulation altogether in existing basements because so many problems originate from moisture. Whatever you do, don't add a second vapor retarder which will trap moisture. Allow it to evaporate into the building and install or utilize proper mechanical ventilation down there.
Clint - carpenter, coordinator, webmaster |
#9 | |
Hudson Valley
2nd.Solve that problem. 3rd. Insulate with rigid foam: It's semipermeable and won't trap moisture, it will thermally protect the basement, and break the contact between framing and concrete. This moisture will diffuse into the air, use an A/C or a dehumidifier to remove excess moisture. Yep. Trapped moisture = Decay + Mold Therefore no Vapour Barriers/Retarders Skipping insulation? Makes no sense if you want a useable area, unless of course your using it for a walk in fridge.
| basement wall help | ygbsm66 | Painting & Finish Work | 1 | 01-20-2007 07:28 AM |
| Help Water in Basement | LG2720 | Construction | 12 | 01-17-2007 02:40 AM |
| Plaster on Basement Wall, Dirt! | mattleaders | Construction | 0 | 10-16-2006 11:22 PM |
| Open Basement Wall; Insert Window? Help, Please! | bluethumbnail | Framing | 5 | 08-25-2006 12:45 PM |
| Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 08:31 PM |
