Another Roof Framming Question
Old 03-06-2006, 08:44 AM   #1
dproc's Avatar
Trade: Sundecks
I guess it's screen porch season. I have another framing issue. Customer wants a 16 x 20 screen room with closed ceiling. I have a couple issues. House is L shaped where porch would go. A-frame or shed roof?
For shed roof:
Second floor bottom window height is 12' from FF- I may be able to get 4-6" by stepping down from FF of house. @ 16' out 3/12 pitch w/ 2x12's I put top of frame at 12'-10" @14'out I gain only 6" . Even with drop in floor it wont work. I don't think 2x10 make a difference. I don't want to go flatter than 3/12 customer wants to use matching shingles. I was thinking of using TGI's for rafters if I can get narrower, shorten porch to 14' and drop down.
Any suggestions for rafter size/product?
For A frame:
Plenty of height between windows but porch tucks into corner. House bumps out 12' requiring a cricket 12' long. Customer worried about leaking. At first I was leaning towards shed roof but height is to tight. If flashed properly I don't think A-frame would be a problem. House is covered in vinyl. Am I right in thinking cricket should not come to a point at vinyl outside corner? Have valley of cricket 8-10" higher and close in triangular area (vertical wall) with flashing. So many things come together at one point.
dproc is offline
Old 04-01-2006, 03:14 AM   #2
Capitalist
Framer33884's Avatar
Trade: Framing Sub/Building Contractor(Custom Homes)/Dock Builder
Re: Another Roof Framming Question
man that is too much too read, would a super gutter work? I really didn't read it.
Framer33884 is offline
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Pricing question for Baltimore rowhome roof AmateursGuide Roofing 11 11-10-2005 03:15 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
