Anchor Bolts
Old 08-16-2009, 07:43 PM   #1
MarcP's Avatar
Trade: Carpenter/Cabinetmaker
Anchor Bolts
Does anybody know how far O.C. anchor bolts are supposed to be? It's been a while since I've done any framing, and I've got a garage to build next month. BTW, I'm in CT. Thanks
MarcP is offline
Old 08-16-2009, 09:15 PM   #2
Pompass Ass
bwalley's Avatar
Re: Anchor Bolts
We start 6" in from the corner and then 24" O.C.
Or we use Titan bolts (They are like a big Tapcon), the same layout but can be put in after the concrete is cured.
But I am in Florida so it may not be applicable to where you are.
bwalley is offline
Old 08-16-2009, 09:43 PM   #3
Sean
SLSTech's Avatar
Re: Anchor Bolts
As I recall:
IRC 2003 6' OC
IRC 2006 4' OC
I have always remembered doing it at 4 but that has been awhile
Always check with your local building dept
SLSTech is offline
Old 08-16-2009, 09:44 PM   #4
ClemS's Avatar
Trade: Framing
Re: Anchor Bolts
depends on where you are in CT. Local codes supersede national so check with your local building department. Thickness also varies. For instance nassau/suffolk counties in new york have been hurricane zones for several years now - our anchor bolts are 5/8". 6"-12" off corner and then spaced depending on locality. Depends on design wind load and height of building. Anywhere from two to four feet on center.
ClemS is offline
Old 08-16-2009, 09:45 PM   #5
Warren's Avatar
Trade: framing/remodeling
Re: Anchor Bolts
Pretty sure here in Ohio, 12 inches in from the corners, then every 6 feet. Seems its different everywhere so hows about telling us where you are.
Warren is offline
Old 08-16-2009, 10:33 PM   #6
I used to think so.......
wallmaxx's Avatar
Re: Anchor Bolts
12" in from corner then 4' oc is standard. Then the engineers get involved. I did a 5 story condo in Ocean Shores, WA built to 130+ MPH wind loads. The anchor bolts were 5/8" at 10" oc for the entire north side wall. It was insane.
Then you add hold downs for all openings, etc.
wallmaxx is offline
Old 08-16-2009, 10:36 PM   #7
topsail's trimcat
woodworkbykirk's Avatar
Re: Anchor Bolts
24 from corner and 6 ft o.c is the standard around these parts
woodworkbykirk is offline
