#21 |
Trade: Framing
Re: Acceptable TJI Squash Blocking
Used to use TJI's a few years ago for a guy i was working for. They were used on ranches with complete wrap around porches and decks. Great system but the particle board rimmer they give is no good for attaching decks to. Using the 2X squash blocks helped but when trying to bolt on an external rim joist for the outside deck didn't always work. I suggested using LVL's for the rim joists, that way we didn't need squash blocks and the treated lumber was really well bolted on from the outside. The crew i worked for were all about speed so it was a great time saver, but I'm not sure on the engineering aspect of it, when your wall is only really sitting on 1"3/4, but it seemed to work pretty good. Iv'e also seen guys use no squash blocks, and "gotten away with it". I think you should definitely use 2X squash blocks because any decent size weight coming down on a TJI will just buckle it. End of the day it's only OSB.
| Floor Joist Blocking | barbie13607 | Carpentry | 10 | 10-09-2007 08:18 AM |
| Cost of blocking in a room in a shop? | BulldogMedia | Masonry | 11 | 09-09-2007 11:08 PM |
| What's acceptable condition for backfill work ??? | Driftwood | Excavation & Site Work | 7 | 05-02-2007 09:25 AM |
| Acceptable moisture content of unfinished hardwood | Grainywood | Flooring | 2 | 09-24-2006 08:46 PM |
| When is @#$% Acceptable? | ProWallGuy | Off Topic (Non Trade) | 5 | 10-16-2005 02:44 AM |
