Acceptable TJI Squash Blocking
Old 10-16-2007, 05:46 PM   #1
jerkyboy's Avatar
Trade: Electrical
I'm working with a framer on a job and we are using a TJI system. I am an electrician by trade but I'm helping frame. I helped frame a TJI addition a few months ago and we used 2x4s for squash blocks but the framer on this job insists that we use pieces of scrap TJIs as squash blocks; says he's done it hundreds of times and it doesn't sacrifice structural integrity. Any thoughts??
jerkyboy is offline
Old 10-16-2007, 06:18 PM   #2
KentWhitten's Avatar
Re: Acceptable TJI Squash Blocking
I guess if he insists, and it's his job, and he's paying the wages, then it gets done that way. There are reference materials about this and I don't remember seeing scrap TJI's used as squash blocks. I do remember seeing 2x4's. He's not talking about using them vertically is he? Like ripping off the ply web and using the bottom chord like a stud?
If that's the case, it should be completely fine. If he's using it like blocking, don't think that will actually qualify as squash blocking because it's relying on the web for squashing.
Salmon Falls Cabinetry
KentWhitten is offline
Old 10-16-2007, 10:09 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
I this point loading? Or are you maybe thinking of ROLL blocks? I cant see using TJI as point load blocks. Only thing to use TJI for is roll blocking.
RobertCDF is offline
Old 10-16-2007, 10:20 PM   #4
jerkyboy's Avatar
Trade: Electrical
No, he is not using the bottom chord for squash. He's using anothter 9 1/2" TJI on both sides. I read through the literature and it shows a vertical 2x 1/16" taller than the TJI to take the load. I have a vested interest in this job, so I want to make sure it's done correctly.
jerkyboy is offline
Old 10-16-2007, 11:31 PM   #5
I used to think so.......
wallmaxx's Avatar
Every time I've used I-Joists, they were engineered for the job. The floor system engineering supersedes the architectural requirements or structural engineering noted in the prints and becomes the law for the floor system. I always installed the floor system as directed by the literature provided by the guys who delivered the joists. i.e. LP has a list of authorized installation methods that they accept when assembling their joists in a floor system. You already know the right answer. Here is the image from the LP site.
I haven't seen them say NOT to use pieces of I-Joist, but if it was me I would approach your com padre and come from the angle that you were reading up on this stuff, and that you wanted to make sure that "we" wouldn't get in any trouble for not installing the joists as prescribed by the manufacturer. Something little like this can come back to bite you. It would suck to have the floor system fail inspection, and then you'd be putting in 2x4 blocks with the decking in your way.
Good luck to you.
Mike
wallmaxx is offline
Old 10-17-2007, 02:45 AM   #6
David Davis
shed-n-deck's Avatar
Trade: ? No thanks, I like mine better!
In Colorado, we call them "Point Loads". I've used TJ's and 2x's for sqaush blocks...With TJ's, a single is usually sufficient, as long as full bearing is obtained, with 2x's, you have to match what is loading down on the squash blocks and place them directly under the load. More typically, I've used the same material as the rim joists...Usually it's LSL....As long as full bearing is obtained, I've never had a problem...
I should say this: It's been 6 years since I've framed a house, so things may have changed quite a bit. Don't depend on my advice, ever...To be sure, use 2x4's(or whatever you use to frame your walls).
Shed
shed-n-deck is offline
Old 10-18-2007, 08:53 AM   #7
Kingfisher's Avatar
Never have used them. Do I understand right they can't support the wall load? Why not just use truss or real wood, are they that much cheaper?
Kingfisher is offline
Old 10-18-2007, 10:35 AM   #8
dlcj's Avatar
Trade: home builder carpenter Central Alabama
I-joist are more expensive than lumber of the same hight here but they are alot stronger and lighter. They can span alot farther resulting in less overal framing for a faster, stronger, and flater floor at a comparible price. We have used some as long as 48' and 2 men can frame a floor system as fast as 4 men using 2x10s. The load blocking is needed where the joist cross a beam and a load bearing wall is above. The 3/8" osb will crush at that point if not reinforced.
dlcj is offline
Old 10-18-2007, 08:20 PM   #9
RobertCDF's Avatar
All our studs always stacked on the BCI joists. And any sort of post had solid blocking from the post, or trimmer/king studs down to the foundation or midspan beam.
Old 10-18-2007, 11:26 PM   #10
framer
framergreg's Avatar
Trade: framing contractor
Send a message via Yahoo to framergreg
i have framed with i joists for years in both resi and comm jobs. wallmax has it right , u must use 2xblocking for all bearing/loadpoints with filler blocks(plywood)on bothsides of joist to form solid sandwhich. anylumberyard can give you a framing detail sheet from the product maker u are using. inspectors here in Mn love to nail those who use chipboard as a block.....its not gonna pass the test.
framergreg is offline
Old 10-19-2007, 12:58 PM   #11
Kgmz's Avatar
The big question is what does the engineered design say?
Not the typical detail sheet that comes with the TJI's that shows all situations.
Are the TJI blocks being install parallel or perpendicular to the run?
Also what code is used where you are at? IRC, UBC, etc.?
We changed to the IRC a couple of years ago and there were big changes with TJI's. We hardly ever use squash blocks now because there now has to be solid TJI blocking over all supporting walls and beams whether there is a load above or not. The reason for this is to give extra support for loads above and for roll stiffness.
Kgmz is offline
Old 10-20-2007, 04:08 PM   #12
Higgs's Avatar
Trade: CE Project Engineer
out of question what is the purpose of squash blocking is it just for supporting the load from the well above the joist?
Higgins
"The more we sweat in peace, the less we bleed in war."
-- Vijaya Lakshmi Pandit (1900-1990)
Higgs is offline
Old 10-20-2007, 04:42 PM   #13
Squash blocking is for support of a point load coming from a post above. A door or window really is considered a post or a point load. The load gets transferred through the bottom plate, through the subfloor, then when it hits the level of floor framing, there needs to be something there to transfer the load to the sill plate then to the foundation.
In TJI systems, you have this squash block that transfers this load. I hav ebeen under the impression for years, that the block is a 2x, vertical, that is cut 1/16" longer than the thickness of the joist in question, to accept this load rather than the end of the TJI's being just a 3/8" OSB core (usually)
In some instances, all the ends of the TJI's resting on the bearing wall will be required to have squash blocking, but it depends on the overall load. Usually, you sister something to the sides of the TJI web in order to accomplish this.
WA state was my experience with inspectors getting on your case about these. You HAD to have them in for you to continue. Don't put them in, you go nowhere. They were prickly about it.
Being scrap pieces, I'd seriously doubt they would be considered good for this. You would only have (2) 3/8" pieces of OSB instead of one.
Old 10-20-2007, 04:57 PM   #14
Have only used these in simple additions for clear span below, so no bearing walls. Doesn't that detail suck big time for mechanicals running from floor to floor? Looks like that would make wall stacks and R/A's a bear?
neolitic is offline
Old 10-20-2007, 08:19 PM   #15
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Another reason I hate rolling TJI's. Yeah they are easy but the work that goes into getting them structrual is rediculous especially on a 2000 sq ft. subfloors with multiple loads from the upper floors.
JustaFramer is offline
Old 10-22-2007, 06:32 PM   #16
tinner666's Avatar
Thanks for this thread. I hadn't used them before, but I sure learned something new here.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 11-18-2007, 02:07 AM   #17
miterclamp.com
clampman's Avatar
Trade: interior trim/cabinets
Kgmz,
You said it all with "Do what the engineering details show". As long ago as 1979 in Vail, we had to use coped TJI's between joists everywhere for roll blocking and solid blocking in addition for point loads. Point loads were spec'd on the print details. I don't remember about the roll blocking - just that we had to do it.
I probably should add "....engiineering details AND the local inspectors"
clampman is offline
Old 11-18-2007, 02:13 AM   #18
miterclamp.com
clampman's Avatar
double post
clampman is offline
Old 11-18-2007, 01:48 PM   #19
72chevy4x4's Avatar
the LP book I looked at shows systems w/ squash blocks and w/o-seems to depend on the load. Around my parts, engineered lumber requires an engineer, which the local lumber house sends the plans to the company's engineer (LP in this case), who will note the required blocking. If an engineer noted blocking as he is using, then it should be deemed ok-if no engineer signed off on the system, I would go w/ 2x blocking to be on the safe side (i.e. overbuild it).
72chevy4x4 is offline
Old 11-19-2007, 09:16 PM   #20
Pavola's Avatar
I agree with chevy. Each floor system is engineered for the house design so all the requirements should be noted on the layout plan.
Pavola is offline
Floor Joist Blocking barbie13607 Carpentry 10 10-09-2007 08:18 AM
Cost of blocking in a room in a shop? BulldogMedia Masonry 11 09-09-2007 11:08 PM
What's acceptable condition for backfill work ??? Driftwood Excavation & Site Work 7 05-02-2007 09:25 AM
Acceptable moisture content of unfinished hardwood Grainywood Flooring 2 09-24-2006 08:46 PM
When is @#$% Acceptable? ProWallGuy Off Topic (Non Trade) 5 10-16-2005 02:44 AM
