6/12 Roof Pitch
Old 05-20-2009, 09:44 PM   #81
Joe Carola's Avatar
Trade: Framing Contractor
Rewards Points: 1,012
Re: 6/12 Roof Pitch
Originally Posted by knucklehead View Post
How do I cut that 63 degree angle?
I forgot to answer that. I have a Bigfoot saw that will cut that angle. If you don't just keep the saw at 0 degrees and cut the plumb cut. Scribe the center of the plumb cut. Set the saw at 27 and run the table down the center of the plumb cut and that will cit the 63. Keep the saw at 27 and lay the rafter flt and cut the other side of the cheekcut.
Joe Carola
Joe Carola is offline
Old 05-20-2009, 09:49 PM   #82
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,289
Re: 6/12 Roof Pitch
Are you guys saying that you cut all your raftersto the correct bevel no matter what? My saws will go to 50 degrees. Unless it is a large rafter, I will cut the bevel at 50 even if it calls for 63. I have seen some rafters that needed to be a 75 degree bevel. Can't imagine anybody cutting those. When I do an octagon, I will cut the first 8 rafters correctly, then I will bevel some spacers, tack them into place, and then cut the rafter ends with no bevel.
Warren is online now
Old 05-20-2009, 09:56 PM   #83
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Re: 6/12 Roof Pitch
That depends on the circumstances. If I can get the full cut with an 8 1/4 saw, I'll bevel it. If not sometimes I'll head it off or just let it be.
loneframer is offline
Old 05-20-2009, 09:59 PM   #84
Joe Carola's Avatar
Re: 6/12 Roof Pitch
I meant 9 3/4 17
If you wnt to use 17, it would be 7-5/8:17..
24.09 [Pitch]
17 [Inch] [Run]
[Rise] - 7-5/8"
6" is ab odd measurement I wanna go with 7" -- 2x6 lookout with a 2x4 on top.
That will work. Just adjust the birdsmouth.
What is the stand on that?
It's the same s the 12/12 Stand at the plateline AFTER you bevel the top of the hip on both sides.
The 12/12 side is 39.22 degrees and the 6/12 side is 11.54 degrees.
Joe Carola
Old 05-20-2009, 10:02 PM   #85
Joe Carola's Avatar
Re: 6/12 Roof Pitch
Warren,
With the 10" Bigfoot saw cutting up to 73 degrees, making those cuts is just as fast and easy as setting your saw to 45 degrees and cutting a normal hip. Takes 2 seconds.
Joe Carola
Old 05-20-2009, 10:11 PM   #86
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,702
Re: 6/12 Roof Pitch
Are you sure?
knucklehead is offline
Old 05-20-2009, 10:49 PM   #87
Rewards Points: 746
Re: 6/12 Roof Pitch
Timuhler is offline
Old 05-20-2009, 11:09 PM   #88
galla35's Avatar
Rewards Points: 250
Re: 6/12 Roof Pitch
SAFETY GLASSES!! dont see them around here very often
galla35 is offline
Old 05-21-2009, 11:09 PM   #89
sponge racing's Avatar
Trade: carpenter
Rewards Points: 75
Re: 6/12 Roof Pitch
Hey do you guys put blocks inbetween the rafters at the tail ends above the wall?? The ends will get soffits. The ceiling height is 8feet 4 1/2in then slopes up too about 10feet 6 1/2in across with the collar joist. Does have a small space for a attic or loft. So the ceiling insulation will be inbetween the roof and the sheetrock for that small 2 foot rise. I will use the air vents stapled up to the plywood before it gets stuffed with insulation so it can breathe. So block it or no??lol Thanks
sponge racing is offline
Old 05-22-2009, 05:28 AM   #90
Kent Whitten's Avatar
Rewards Points: 2,040
Re: 6/12 Roof Pitch
Block it, yes.
I find this thread curious. Usually everyone will jump all over you because they smell a rat, yet we have given you a pass into the framers club. Very unusual.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 05-22-2009, 06:10 AM   #91
KemoSabe
loneframer's Avatar
Re: 6/12 Roof Pitch
Block it, yes.
I think that is because of the fact that the questions were well thought out and intelligently asked, with no mention of how much to charge.
Old 05-22-2009, 07:16 AM   #92
Trade: carpenter
Rewards Points: 75
Re: 6/12 Roof Pitch
This is not for a customer its part of my house. So definetly dont need a price to charge. I never charge when doing this type of work. When I do it its helping friends or my personal projects. As for work I do do and get paid hourly is through the nycdcc. We never work on residentail houses. All trade shows and commercial building. Thanks guys Shouldnt I leave some space at the top for air to circulate from the soffits to the ridge vent? Maybe use a 2x4 for blocking leaving a 1in space at the top??
Old 05-22-2009, 07:20 AM   #93
Re: 6/12 Roof Pitch
This is not for a customer its part of my house. So definetly dont need a price to charge. I never charge when doing this type of work. When I do it its helping friends or my personal projects. As for work I do do and get paid hourly is through the nycdcc. We never work on residentail houses. All trade shows and commercial building. Thanks guys Shouldnt I leave some space at the top for air to circulate from the soffits to the ridge vent? Maybe use a 2x4 for blocking?
You could put some V-notches or drill holes. We used bird blocks in Seattle. They had 3-2" holes with 1/4" screen stapled from the back.
Or set youir heel height to 4-1/2" and use 2x4's to get your 1" air gap
Old 05-27-2009, 12:23 AM   #94
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,622
Re: 6/12 Roof Pitch
Originally Posted by RobertCDF View Post
Personally I would call my truss guy and order them. Then in a few days I would have trusses. Side by side on the same garage I will have my roof sheathed before you get your first row of ply down.
Ding, Ding, Ding. When I saw your question, I thought: "umm, I dont know, call the truss guy and order them"
jhark123 is offline
Old 05-27-2009, 06:49 AM   #95
Joe Carola's Avatar
Re: 6/12 Roof Pitch
Trusses for a 16' wide garage? Waiting a few days for them? You can have this simple roof stick framed an sheathed in half a day while you wait for your trusses.
Joe Carola
The Following User Says Thank You to Joe Carola For This Useful Post:
A W Smith (05-27-2009)
Old 08-10-2009, 07:29 AM   #96
MR.KNOW IT ALL's Avatar
Trade: CARPENTRY
Re: 6/12 Roof Pitch
The ridge height is 4' 7 3/8" who ever didnt come up with this # roll your **** up and go home... I cant even spell carpenter but i are one
i have framed for 27 years in 110 degree weather. And i can figure it out
MR.KNOW IT ALL is offline
Old 08-10-2009, 07:47 AM   #97
Trade: CARPENTRY
Re: 6/12 Roof Pitch
Hey framerman carola is wrong its 120 5/8"
Old 08-10-2009, 07:57 AM   #98
Trade: CARPENTRY
Re: 6/12 Roof Pitch
If i have a 10 foot wide opening
and i want the top of my arch at 10 foot
and the bottom of arch is 9 foot
what is the radius???????????????????????????????????
Old 08-10-2009, 11:24 AM   #99
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Re: 6/12 Roof Pitch
Originally Posted by loneframer View Post
I happen to use a scientific calculator instead of the construction master, only because it's what I learned on and am comfortable with it.
Ditto
I need to send you some program routines that will convert all of your decimal answers into Feet - Inches - Sixteenths
It makes it nice on the brain.
wallmaxx is offline
Old 08-11-2009, 07:56 PM   #100
Adam13's Avatar
Trade: Foreman/Co-owner/Carpeneter
Re: 6/12 Roof Pitch
Hi im building a garage and wondering if I can get some input about framing out a gable roof. The full outside lenght is 16 feet 4 1/2 inches and needs to have a pitch of 6/12. Thinking my ridge beam height should be 49 1/2 inches from the top of the garage walls with the 6/12 pitch. I dont have a book of common rafters to look up the info. I know the degree of a 6/12 pitch is 26.50. But I dont have the span of the rafters. Im using 2x8 roof rafters. Any info would be greatly apprectiated. Thanks
Just a question...why are you framing the roof by hand instead of using engineered trusses? Is it a matter of cost efficiency? What is the width of the garage?
Adam13 is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Determining roof pitch - hip roofed cedar MrRoofer Roofing 11 03-25-2009 10:07 AM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
