32 X48 Garage How Am I Going To Brace This Thing
Old 11-20-2014, 06:44 PM   #1
I prefer carpenter
marklo154's Avatar
Rewards Points: 81
Took this frame awhile back, was just a garage to bang up when we had a chance. Got the plans today its 32x48 with 12' 2x6 walls, on a poured slab no interior walls.
I got thinking and I am wondering how I am going to brace this think for the roof. Not really a fan of driving stakes in the ground, and its frozen here ..
Any ideas.
marklo154 is offline
Old 11-20-2014, 06:48 PM   #2
#MAGA
EricBrancard's Avatar
Trade: Builder/Renovator
Re: 32 X48 Garage How Am I Going To Brace This Thing
I usually just drive stakes because I would be building on frost walls and the slab would be poured after dry in.
Would they allow you to drive tapcons into the slab for some cleats to brace off of?
Could you run 2x stock across the bottom from plate to plate and then brace off of that?
EricBrancard is offline
Old 11-20-2014, 06:53 PM   #3
I prefer carpenter
marklo154's Avatar
Rewards Points: 81
Slab is all ready poured, I was thinking I may have to anchor something to the slab to brace it. Its a mess the one 48 foot walls has 3 overhead doors in it the other is loaded with windows so I am going to need alot of braces.
So much for a quick and easy frame
Old 11-20-2014, 06:53 PM   #4
txgencon's Avatar
Rewards Points: 430
I'd just brace to the other side or diagonally for the 48' side.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 11-20-2014, 06:54 PM   #5
Shellbuilder's Avatar
Trade: Shell building contractor
Rewards Points: 1,236
If you could push rebar in the ground with a machine or a demo hammer, clamp a brace on those at their base. Ive never worked on severe ice but did this with an asphalt lot beside a large similar building.
www.shelladditions.com
Shellbuilder is offline
The Following User Says Thank You to Shellbuilder For This Useful Post:
jb4211 (11-20-2014)
Old 11-20-2014, 06:58 PM   #6
SAcarpenter's Avatar
Trade: residential/remodeling carpenter
Rewards Points: 938
X2 on the plate across the bottom otherwise I would run long "x"'s the short way. Attach them in the middle where they meet and then run cross bracing so they dont sway back and forth
You can rest when you're dead
SAcarpenter is offline
Old 11-20-2014, 07:18 PM   #7
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I've used pallets with material we're going to use on them. Like the shingles. Then brace to those. I've also driven skid steers, back hoes, and excavators on 6x6 and braces off to those.
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
Spencer (11-21-2014)
Old 11-20-2014, 07:23 PM   #8
Dan_Watson's Avatar
Rewards Points: 2,466
Run 2x4's on the slab from wall to wall across the entire floor and attach your braces to them as if it was a wooden subfloor. They self brace with forces acting against each and pushing against the foundation. It is a little extra lumber but very easy.
Dan_Watson is offline
The Following 3 Users Say Thank You to Dan_Watson For This Useful Post:
jlsconstruction (11-20-2014), Joasis (11-22-2014), shanewreckd (11-20-2014)
Old 11-20-2014, 07:27 PM   #9
stacker of sticks
Rewards Points: 590
I like that idea
Old 11-20-2014, 07:38 PM   #10
txgencon's Avatar
Rewards Points: 430
With so much stained concrete nowadays, this is the most common method here. Framers used to shoot blocks down. Always created a divot that won't work if you're staining. It does take a lot of lumber. I think I used around 80-2x4x16s on a similar sized building.
txgencon is offline
Old 11-20-2014, 07:51 PM   #11
concrete2013's Avatar
Trade: Concrete
Rewards Points: 260
Or cut 1.5 ft pieces of lumber and attach them to the slab with a hammer drill, 16 penny nail and a piece of cow tie (Wire)
This is how we do form work on top of existing concrete.
concrete2013 is offline
Old 11-20-2014, 09:16 PM   #12
Safety Third
shanewreckd's Avatar
Trade: Concrete Carpenter. Concreepenter? Carpencrete?
Rewards Points: 196
I do that on most concrete, that isn't exposed. Since it's exposed slab I would avoid putting holes in it. I normally would go with JLS's idea. Pallets with a sheet of plywood and a heavy mound of dirt, or just a 2 ton lock block. We always have lots of blocks in our yard. I like Dan's idea though, counteracting forces bracing until the trusses are up. Slick.
shanewreckd is offline
Old 11-20-2014, 09:27 PM   #13
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 828
There are control cuts right? We drill holes for tapcons right in the control joint and tapcon a 2x block to the floor. Run the brace to that. When block is removed there is very minimal damage around the hole.
overanalyze is online now
Windwash (11-21-2014)
Old 11-20-2014, 09:36 PM   #14
stevenp's Avatar
Trade: Residential Home Builder/Carpenter
Rewards Points: 2
put up the 3rd truss from the end. Nail one end. Then get a 2x4x16 and nail the top of the brace to the bottom cord of the truss to where the bottom of the brace reaches the bottom plate of the wall where you nailed the top. Have a string nailed up on the inside of the wall and pull it straight according to the string and nail it. Then get the other end of the truss right and nail it. Then put a brace on the other side. This works pretty well for us. We do this for ijoists with long spans too. No holes in the floor, no suler long braces in the way no stakes in the ground. The only problem is if they are weak laterally. Then you may have to do a little bracing on the ends to keep them from moving that way. Repeat every 3 to 4 trusses.
stevenp is offline
Old 11-20-2014, 11:47 PM   #15
totes's Avatar
Rewards Points: 910
I do like so, tapcon in the cutline is good. Especially if sided pre tilt-up Quicker for me to just throw a 2x brace on the exterior also.
wam bam keep movin...
"faster horses, younger women, older whiskey, and more money"
totes is offline
The Following User Says Thank You to totes For This Useful Post:
JT Wood (11-21-2014)
Old 11-21-2014, 06:53 PM   #16
Rewards Points: 746
We need to do this in 2 weeks. Fortunately the owner is going to put a coating on the slab and say we can drill it. I'm going to put 1/4" Titans into the holes.
Am I the only one that can't get Tapcons to work? I use the bit that comes with them and still always break the screw.
Timuhler is offline
Old 11-21-2014, 07:07 PM   #17
Windwash
Windwash's Avatar
Rewards Points: 148
Ha! I thought it was just me
I worked commercial for 12 years and we never used tap cons for anything temporary. Everthing was drill 3/16" hole, drop in 10" piece of tie wire folded in half, hammer in 16 duplex. Easy to pull nail when done with this setup and doesn't require everyone to have an impact or drill to back out tap con.
Windwash is offline
Old 11-22-2014, 06:04 AM   #18
Joasis's Avatar
Rewards Points: 1,388
If you guys have seen the duplex screws, we use those to hold ICF braces into the slab.
If you guys have never used these: http://www.homedepot.com/p/RemoveRit...7ZkRoCZ_jw_wcB you should try them. I don't buy then at HD, my contractors supply carries several sizes, and we use them for all kinds of stuff, over and over. The heads do not get buried like a good torx screw will, and these can take the punishment, plus the 1/4 drive head.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is online now
The Following User Says Thank You to Joasis For This Useful Post:
tgeb (11-22-2014)
Old 11-22-2014, 09:46 AM   #19
Rewards Points: 746
Awesome thanks! We are hoping to do an ICF foundation in a month or two. Just waiting on pricing to see where its at.
This is a small house that is two stories on top of the garage and the return walls are small. Engineer designed the thing full height concrete walls including garage header. I really am looking forward to forming this thing, but I also hope we get to go ICF route.
Timuhler is offline
Old 11-22-2014, 12:11 PM   #20
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
good man
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
2 spare breakers 15 & 20a, want to wire outlets in garage pitterpat Electrical 8 05-13-2012 02:58 PM
Can someone give me a generic estimate on this garage? lman22 General Discussion 3 03-12-2012 12:14 PM
Peeling paint in unheated garage ApgarNJ Painting & Finish Work 28 05-09-2011 08:38 PM
Framing 20'x20' garage carterarce Framing 12 09-29-2009 10:24 AM
does the garage really need the GFI? handyman99 Electrical 21 08-31-2009 11:33 AM
