2x6 Exterior Walls - Building Corners?
Old 04-02-2008, 10:03 PM   #1
MHMConstruction's Avatar
Rewards Points: 150
OK, question #2 on the differences between framing w/ 2x4s or 6s
How do you build corners for 2x6 walls?? when you build corners for 2x4 walls, you have that extra 1" nailer for your drywall later on. what about 2x6s??
Many thanks for the help framer folk!
MHM
MHMConstruction is offline
Old 04-02-2008, 10:59 PM   #2
send_it_all's Avatar
Rewards Points: 1,000
Re: 2x6 Exterior Walls - Building Corners?
instead of using blocking to create a tripled up stud like you would with 2x4s, you create an L shape with the 2x6s on the wall that runs long (not sure how to explain it.) Then when you butt the other wall into it, you end up with 1-1/2" for drywall nailing because of the thichkess of the end stud.
send_it_all is offline
Old 04-02-2008, 11:41 PM   #3
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
2x6 corner - the people up here are big on the R value of a corner. For shear it changes
wallmaxx is offline
Old 04-02-2008, 11:44 PM   #4
Teetorbilt's Avatar
Rewards Points: 2,000
That'll work as long as you're not in a hurricane zone.
Albert Einstein
Teetorbilt is offline
Old 04-02-2008, 11:46 PM   #5
The ONLY way is DEAD_ON!
DEAD_ONConst's Avatar
Trade: Custom Finish/Carpenter
Rewards Points: 75
For my 2x6 walls, I build an L on the outside perimeter corner and add a 2x4 to the inside "nailer" corner. This allows me to fill the resulting "U"-shaped corner with insulation and create an insulated corner. Where I live, insulation is a premium, and with the cost of heating fuel/propane here, that make a precious commodity an asset to my business! I build as "Green" as possible but within the limits of my customers. Some of them just don't care! However, for the most part, I just do it, because I include the extra labor in my estimates, anyway.
I use LOW Expanding foam, and the result is that all members end up glued together, by the foam, and are seismic and severe weather compliant. my 2x4's are set in 3/4" to the interior wall so the adjoining wall can be face nailed to the edge of the adjoining 2x4 and "lock" the corner and create a box, which essentially becomes a column corner.
DEAD_ONConst is offline
Old 04-02-2008, 11:58 PM   #6
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,494
I'm not sure what you mean, You can insulate an L corner without a seperate 2x4. We always overlap the sheeting on corners so that the walls (exterior) are held together with 10 or so nails along the inside on the L corner,, Then with about 30-40 staples on the exterior overlapping sheeting. I'm in Calgary canada So no hurricanes but tornadoes happen in this vicinity. 2 touched down last year within 30 miles of here.
JT Wood is offline
Old 04-03-2008, 12:10 AM   #7
Rewards Points: 75
Your structure ALWAYS goes on the exterior. If you look at WallMaxx's Diagram, notice the two "stacked" 2x6s on the inside corner? In my design, the stacked 2x6 is moved to the exterior wall, and a 2x4, nailed on edge to the moved, "exterior" 2x6, creating a U. The UN-nailed edges of the 2x4 and 2x6 is now your INSIDE corner for nailing up interior drywall. Now you have created a "column" that is filled with insulation, and therefore about 33% more efficient than a standard California corner, and equally as strong.
Old 04-03-2008, 07:16 PM   #8
FramingFanatic's Avatar
Trade: Framing
Rewards Points: 77
Dead on im not sure i get what your saying. QAre you saying that instead of the way malmax's picture depicts you would put the 2x6 on its flat to the outside, and a 2x4 to the inside? Looks like a wasted step to get it structural, considering that end stud on the wall is within the 16" or whatver your using for stud centers. And as to the 2 2x6s being stacked that has few structural connotations(spl) to it at all. It is there so that when the drywallers are running thier boards they have something to nail to at the end. In reality you ar adding an extra stud so it should not matter structurally whether or not it is on the inside or outside.
Get er Done!
FramingFanatic is offline
Old 04-03-2008, 08:01 PM   #9
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
Rewards Points: 75
build as the diagram above but add a 2x6 on outside, building a u shape gives a lil more strength and allows for nailing for sheathing and siding .
odellconstruct is offline
Old 04-03-2008, 08:47 PM   #10
Palisade Point Const.
TempestV's Avatar
Rewards Points: 1,632
Same as I would do.
TempestV is offline
Old 04-04-2008, 03:28 AM   #11
CAD Services
wallmaxx's Avatar
Rewards Points: 144
I like this way for siding. I use the other way mostly for brick.
wallmaxx is offline
The Following 2 Users Say Thank You to wallmaxx For This Useful Post:
Quad Racer (06-08-2014), Timuhler (05-25-2014)
Old 04-04-2008, 08:02 AM   #12
Rewards Points: 75
thats the way in my book !
Old 04-04-2008, 11:12 PM   #13
Carpenter/Finisher
john5mt's Avatar
Rewards Points: 1,382
how would you build it differently with 2X4 walls? I build them that way with a 2X4 or 2X6 wall.
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Old 04-08-2008, 02:25 AM   #14
CAD Services
wallmaxx's Avatar
Rewards Points: 144
For 2x4 applications I mostly do #1 in areas concerned with R value (exterior walls). I have mostly built them like #2 over the last 18 yrs (interior / load bearing / and typical in the south). Never like #3.
wallmaxx is offline
Old 04-11-2008, 01:04 PM   #15
fourcornerhome's Avatar
Trade: home improvement contractor
Rewards Points: 204
Have always used #1...2x4 or 2x6.
fourcornerhome is online now
The Following 2 Users Say Thank You to fourcornerhome For This Useful Post:
CarpenterSFO (05-26-2014), RocketScott (06-27-2014)
Old 04-11-2008, 07:51 PM   #16
Carpenter/Finisher
john5mt's Avatar
me too
1st Gen tradesman
john5mt is offline
The Following User Says Thank You to john5mt For This Useful Post:
Old 04-11-2008, 08:55 PM   #17
mike backman's Avatar
Trade: carpenter
Rewards Points: 75
Is # 1 a "California corner"
mike backman is offline
The Following User Says Thank You to mike backman For This Useful Post:
RiverBG (06-27-2014)
Old 04-13-2008, 10:49 PM   #18
Kgmz's Avatar
Yes.
And around here you have to build them that way for energy code, unless it is a shear wall corner.
Kgmz is offline
Old 04-15-2008, 07:42 PM   #19
cmansmith's Avatar
Trade: Framer, Carpenter
Rewards Points: 75
I build mine like a ladder. I Use the end stud and the first stud on layout and put five or more blocks between them, depending on wall height. It allows you to stuff allot of insulation into the corner, gives you more to nail sheeting to, making a stronger corner and its convenient to have a ladder in every corner. I always built California corners, till I saw a guy in kansas city do it this way. I tried it out, was happy with the result and so was my builder. This is how I have been doing it ever since.
cmansmith is offline
Old 05-24-2014, 10:44 PM   #20
medeek's Avatar
Trade: Engineer
Rewards Points: 262
I happened upon this topic and even though it is a bit dated it is still very relevant. I've been struggling with the best way to frame ext. corners on 2x6 walls so I've put together a matrix with a number of methods.
A high resolution PDF file is here:
http://design.medeek.com/resources/f...NG_CORNERS.pdf
I do a lot of designs with hardiplank siding so good backing for the trim and siding is important to me. Up until now I've been specifying Detail 2 a lot, but now I'm looking at Detail 5 and it seems to offer the same advantages and more. Any thoughts?
medeek is offline
The Following User Says Thank You to medeek For This Useful Post:
clydebusa (05-25-2014)
Need help with a shocking outside waterspout Badoish Electrical 23 12-27-2008 04:18 PM
Nobody Wants to bid Deutsche Bank Building Now Wolf Demolition 2 08-26-2007 03:37 PM
railing corners MinConst Decks & Fencing 12 12-08-2005 08:01 PM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 07:37 PM
