Trade: landscaping
2x4 Or 2x6 Outer Walls?
Is one better than the other? Will it help with insulation?
Priced In
Trade: Exiled For Life
Re: 2x4 Or 2x6 Outer Walls?
2x6 you get r-19. 2x4 with minimal windows which equals less heat loss and is as effient. But who wants less windows? Other than the insulation factor 2x4 is cheaper in the building phase.
Depending on what "zone" you are in, and if the IECC is enforced as part of your building codes, you may have no choice but to build with 2x6 for the added R value. That's the way it is in my area.
#4 | |
Priced In
Re: 2x4 Or 2x6 Outer Walls?Quote:
It is enforced here but the only way around it is like four windows per floor level; then 2x4 can be used. It probably has some thing to do with sq ft per floor but I don't really care to know one window per room is nasty unless you like living in a cave. |
I am told that it is required here depending on the location (wind zones). Right now everything is in such a state of flux, you don't know who to believe and what was code today may change tomorrow.
Trade: landscaping
I am in San Antonio, Texas. So the "zone" would be ?
You have to check that out locally.
Bexar county is in Zone 4.
That means R-26 ceilings, R-13 walls, R-11 floors, R-5 basement walls, and no required slab perimeter R value. With these minimum requirements, you can build with 2x4's if you use the higher density 3-1/2" fiberglass in the walls. |
Priced In
What MD said.
J.O.A.T.M.O.A.C.
In addition to the high density insulation there is another method to meet the required R factors. There is a styrofoam paneling that you can put on the exterior of the building and then stucco over that. Im not sure what it is called as I stick with 2X6 walls. Much stronger and most of the seismic hold downs require it. And then there is also the ICFs' that can be used. No wood at all hardly. But IMHO a serious pain in the ass to work with.
#11 | |
#12 | |
Have heard rumors that a certain high-end apartment building in Cleveland where some of the Cavaliers spend their "post-game" evenings is making them sick. Covered with EIFS... Allows no moisture escape/ventilation whatsoever. Yes,ICFs are also difficult for trades to work with,but very strong. |
If you have the $$$ go with 2X6. The house has a lot more of a solid "feel" to it not to mention that it really cuts the noise level down. Be prepared for all the extra cost of extension jambs for all your windows and doors.
#14 | |
Trade: construction
Gees , these are old threads . Not that its any importance . Its a lot easier by far to frame two by four walls . Mechanically it may be more practical to do 2x6 , not only for R but for electrical roughs ,etc.. Also if its two storys or better . In the higher elevations where you have snow loads to work in to design, 2x6s hold up the heavy loads . Might be a local code as well
Trade: I am a residential builder.
Up north here near Canada we have what is called the Michigan Energy code. It's great reading....but pretty much everything here ae 2x6's.
Hudson Valley
Trade: Restorative Painting
2*6: 24 o.c, greater r values, less thermal bridging, and IMHO crowning studs.
www.blueskiesrestorations.com There's some top class people on this forum,........and then there's me...Touching cloth. |
#18 |
I always did 2x6 but any short wall, like bays and box window where you have header, window , and a little piece of insulation on the bottom, I always went with 2x4. Since you end up with almost no insulation in the wall you get the advantage of 1) no extension jambs 2) nicer trim detail 3) more room in the bay. By bay I'm talking about the built out floor joist bay with 3 individual windows.
#19 |
Capitalist
Trade: Framing Sub/Building Contractor(Custom Homes)/Dock Builder
If you have any type of volume go with 2x6 or better. I built a crazy house cantering over water with 12' and 14' 2x 4 walls and they just shake; I mean enough to knock pictures off with any winds. I even put studs on 1' centers and it didn't help. We have a rule down here or did. 2x6 on the bottom, 2x4 on the top, that was when everything was 8' walls and energy was cheaper. Now we just frame to the plans and usally have to call the engineer once a job to ask him "are you sure about this". I recomend this because those guys stamp anything. We set a set of trusses a few years ago 60' span 14' walls, 8/12 with a 2x4 bottom cord that colapsed; Come to find out they had to be like 2x6 or 8 (forgot). Last week we were building a 2 story with a deck to support like a 5000 lb hot tub, all joist running to an 18' double 2x12. With joist hangers...still waiting on new engineering.
#20 |
Trade: Home Improvement
I am in the SoCal desert. 2x6 framing is a good way to go if you are going to be in the house for a long while. My neighbor finished his house a couple of years ago. It has 2x6 exterior walls. He runs his central air all summer long and his bill is only slightly more then those of us with water coolers and older 2x4 houses. I am not sure how 2x6 const compares to sips, it would be interesting to know.
| Smooth Finish Heavy Textured Walls | riccog | Drywall | 5 | 03-10-2009 11:57 AM |
| Block Walls | DaHammer | Masonry | 29 | 03-06-2009 07:11 PM |
| concrete walls finishing | mjay | Masonry | 2 | 03-05-2009 03:36 PM |
| Bridging for above grade Concrete Walls | ETHICS05 | Construction | 1 | 11-21-2005 12:43 PM |
| drywall over interior plaster/ brick walls | n8sr | Drywall | 10 | 11-10-2005 10:18 PM |
