2x12 Or 2x10
Old 11-18-2009, 09:26 PM   #1
izzy's Avatar
2x12 Or 2x10
Just curious what some of you other guys use for stair stringers. I use 2x12 if there is not an issue with head room below the stairs. Makes a strong set of stairs but it seems the majority of framers around here use 2x10.
Allot of times I'm not in the norm.
I always build 16 oc as well. 24 oc is just not worth it to me.
izzy is offline
Old 11-18-2009, 09:30 PM   #2
Warren's Avatar
Trade: framing/remodeling
Re: 2x12 Or 2x10
Wow. If you have to pick up headroom by using a smaller stringer, that is one tight house. I sure hope your talking about closed stringers. There is no way your gonna notch a 2x10 out and have enough meat left.
Warren is online now
Old 11-18-2009, 09:43 PM   #3
smeagol's Avatar
Trade: new construction and remodeling
Re: 2x12 Or 2x10
you only would have around 1 5/8" left with 2x10
smeagol is offline
Old 11-18-2009, 09:46 PM   #4
BCConstruction's Avatar
Trade: Construction
Re: 2x12 Or 2x10
I always go ott with stringers. i use 3 2x12's normally
BCConstruction is online now
Old 11-18-2009, 09:47 PM   #5
mics_54's Avatar
Trade: contractor
Re: 2x12 Or 2x10
but he's worried about 24 in centers
mics_54 is offline
Old 11-18-2009, 09:49 PM   #6
izzy's Avatar
Re: 2x12 Or 2x10
I agree totally sometimes Ill use 4 depending on the stairs
izzy is offline
Old 11-18-2009, 09:49 PM   #7
jochase1's Avatar
Trade: Framing contractor-General contractor
Re: 2x12 Or 2x10
I've used Timberstrand rim board for several years, straight and strong
jochase1 is offline
Old 11-18-2009, 09:54 PM   #8
izzy's Avatar
Re: 2x12 Or 2x10
I have had a tight area that required the use of 2x10's in a remodel job that the inspector would not grandfather. I think you missed the part were I said I use 2x12 stringers.
But seriously Im one of only a few who use 2x12 stringers in new construction in my area.
izzy is offline
Old 11-18-2009, 09:54 PM   #9
Dave from Macatawa
macatawacab's Avatar
Trade: GC, cabinet maker and remodeler
Re: 2x12 Or 2x10
3 - 2x12 for 48" wide stairs. 24" oc min.
macatawacab is offline
Old 11-18-2009, 10:31 PM   #10
Joe Carola's Avatar
Trade: Framing Contractor
Re: 2x12 Or 2x10
How do you figure that? What run and rise are you using to have only 1-5/8" left?
Joe Carola
Joe Carola is offline
Old 11-19-2009, 01:32 AM   #11
I used to think so.......
wallmaxx's Avatar
Re: 2x12 Or 2x10
I build them like this
http://wallmaxx.com/Media/ROUGH%20STAIR%20FRAMING.mov
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
Winchester (11-19-2009)
Old 11-19-2009, 04:02 AM   #12
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
Re: 2x12 Or 2x10
In the last bunch of houses I framed, we had the stairs pre-fabbed by a stair building company. They were all built with two Timberstrand stringers, one on each end giving it a three foot span for the treads.
But if I'm building the stairs myself for a house, I use 3 - 2x12's for a three foot wide stairwell.
KennMacMoragh is offline
Old 11-19-2009, 04:06 AM   #13
Re: 2x12 Or 2x10
Originally Posted by wallmaxx View Post
Did you make that video?
Old 11-19-2009, 04:55 AM   #14
KentWhitten's Avatar
Re: 2x12 Or 2x10
It says "beware of this site, malware"
Oh man, sorry, I couldn't resist.
Salmon Falls Cabinetry
KentWhitten is online now
Old 11-19-2009, 10:35 AM   #15
wallmaxx's Avatar
Re: 2x12 Or 2x10
you ass
You had me going for about 3 seconds
wallmaxx is offline
Old 11-19-2009, 10:37 AM   #16
wallmaxx's Avatar
Re: 2x12 Or 2x10
Yes. Its format is kinda small, but I have a full-sized slide presentation that I have posted here before in PDF format.
wallmaxx is offline
Old 11-19-2009, 10:24 PM   #17
Zimmermann
BrianFox's Avatar
Trade: Wood Cutter
Re: 2x12 Or 2x10
the last 8 staircases I built I ripped down 6 12" strips of advantech glued ,screwed and clamped them together and used that for stringer material.
Happiness is produced not so much by great pieces of good fortune that seldom happen, as by little advantages that occur every day.
- Benjamin Franklin
BrianFox is offline
Old 11-19-2009, 10:57 PM   #18
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
Re: 2x12 Or 2x10
I have cut and installed hundreds of stairs with 2x12's, 3 per set, In the last couple of years I have used the timberstrand or lvls because that is what the builder wanted . I am not sure it is better. I don't think I have ever used 2x10 for stringers.
knucklehead is offline
Old 11-19-2009, 11:13 PM   #19
Zimmermann
BrianFox's Avatar
Trade: Wood Cutter
Re: 2x12 Or 2x10
the next set Im doing Im switching to timberstrand. I know using ply/osb stringers there is virtually no deflection or sag over time like dimensional lumber will do eventually. Cuts are nicer and easier to jig.
- Benjamin Franklin
BrianFox is offline
Old 11-20-2009, 01:59 PM   #20
Civil / Structural PE
Tim Garrison PE's Avatar
Trade: Engineering & Software
Re: 2x12 Or 2x10
Here's my two cents...
A 2x Doug Fir #2 has an allowable bending stress of about 1,000 psi.
An LVL has an allowable bending stress of about 2,500 psi, more than double the 2x.
An LSL has an allowable bending stress of about 2,300, still more than double that of a 2x.
And a PSL has an allowable bending stress of about 3,000 psi - 3 times the 2x.
If they were my stairs I would spec 11-1/4" LVL or LSL at 24".
Tim Garrison PE is offline
The Following User Says Thank You to Tim Garrison PE For This Useful Post:
wallmaxx (11-20-2009)
72* Degree on a 2X10 Mahogany Joist? II Weeks Carpentry 20 07-16-2009 12:43 PM
2x10 joists Bill Framing 6 05-09-2009 10:35 AM
Job Sequence - New House MHMConstruction Construction 19 12-09-2007 01:14 PM
maximum span for 2x12 TRIPLETS Carpentry 1 10-22-2006 09:20 PM
Another Deck pricing Question fullhouse Decks & Fencing 5 05-10-2006 09:28 PM
