24" On Center Framing On Exterior Walls
Old 09-12-2009, 10:37 PM   #1
lunapark's Avatar
Trade: painting
Remodeling 1940's home and found 24" on center framing everywhere, including exterior walls and load bearing walls. Wondering if it needs to be shored up by placing studs in the middle to make it 12" on center?
lunapark is offline
Old 09-12-2009, 10:47 PM   #2
Joe Carola's Avatar
Trade: Framing Contractor
Re: 24" On Center Framing On Exterior Walls
Why would it need to be after 69 years? Is something wrong with the walls? They do frame 24" centers walls. It's a Regional thing. So far I haven't framed 24" center walls.
Joe Carola
Joe Carola is offline
Old 09-12-2009, 11:18 PM   #3
Why would someone hire a painter
to reframe a 60 year old house?
neolitic is offline
Old 09-13-2009, 02:35 AM   #4
jhark123's Avatar
If you need to ask this question, you need to hire a carpenter to do the work
jhark123 is offline
Old 09-13-2009, 02:53 AM   #5
I used to think so.......
wallmaxx's Avatar
I bet it was angled 3/4" ship lap on the outside and or lath and plaster (with the mesh) walls on the inside too.
wallmaxx is offline
Old 09-13-2009, 05:48 AM   #6
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Interesting topic. Not being a framer, carpenter, builder, etc, but a lowley paper hanger, painter,I have a question.
I was repairing a ceiling last week where the HO was in the attic and put his foot through the ceiling into the bedroom. After opening up the hole to attach some 2 by 4's for the patch found the joists were 24 in on center and was wondering if that was normal for somewhat new construction( about 10 years old)? Just curious as all I have ever seen is 16 in on center, but I mainly deal with older homes.
chris n is offline
Old 09-13-2009, 06:00 AM   #7
KentWhitten's Avatar
Yes, that's normal.
Salmon Falls Cabinetry
KentWhitten is offline
The Following User Says Thank You to KentWhitten For This Useful Post:
chris n (09-14-2009)
Old 09-13-2009, 10:30 AM   #8
Yes, that's normal.
Especially if it's trusses.
No offense intended to you Chris.
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
Old 09-13-2009, 11:15 AM   #9
Warren's Avatar
Trade: framing/remodeling
Bout twenty years ago, we were framing condos that had walls at 24 oc. They also had the silver foam sheathing, followed by vinyl siding. If you knew where the studs were, you could probably kick a hole right through the exterior wall. This county allowed 24 oc until just a few years ago.
Warren is offline
Old 09-13-2009, 11:53 AM   #10
UpNorth's Avatar
Trade: Engineer & Ret. GC
24 on center, exterior walls and roofs, is done routinely here in the north country.
90 pounds per square foot ground snow load, about 9000 heating degree days, seismic D1 design criteria, houses built circa 1840 have bays like that and wider.
If you aren't buying the lumber, and are being paid to frame, more wood makes sense. If you are paying for the wood, and paying to heat the place, less wood makes sense.
24 on center is fine with our AHJ, our state code, and meets most all structural requirements.
When engineers get involved in design, excess weight and material starts coming out. The body steel on automobiles has gotten much thinner, when compared with what it was in, say, the 1960s.
Wait until your elected congressional reps get done with cap'n'trade, and builders all have to go way beyond LEED. We'll see 24 centers everywhere.
UpNorth is offline
Framing Documents To Die For NC2X4 Framing 33 09-17-2010 11:45 AM
Framing Safety Safety Guy Tools & Equipment 3 08-13-2009 09:46 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 06:11 PM
Has anybody created a totally digital media center for themselves? Mike Finley Technology 14 01-05-2009 05:30 PM
24 on center vs 16 on center framing? Mike Finley Framing 106 07-17-2007 10:28 PM
