16" O.c.
Old 04-15-2007, 09:24 PM   #1
georgia dawg's Avatar
Trade: general contractor - SFR
16" O.c.
16"o.c. was developed because it was the maximum span to support lathe for plaster in the middle ages. It has nothing to do with modern dimensional lumber load bearing except for division of widths, but is still the "de facto" standard. Correct me if I'm wrong.
2x6 at 24" is just as strong and uses the same board feet which means that, wall to wall, it should cost about the same to frame.
Opinions?
"How much per sq.ft? Well.. gimme $1K and I can build a shed. Gimme $1M and I can build the same size shed with gold plating and encrusted diamonds."
georgia dawg is offline
Old 04-15-2007, 09:29 PM   #2
Thom
thom's Avatar
Re: 16" O.c.
Dawg, you are correct that the strengths, carrying a vertical load, are the same. Not all loads are vertical. 24" centers will add flex to your sheetrock and exterior finishes. You still need 16" centers for tile backer. 16" centers gives you a little more to screw cabinets to.
Mixing the centers, 16" and 24", seems to give the framers fits (I tried it for a while). You save a little in material. I figure, in the grand scheme of things, it's not worth the hassle.
thom is online now
Old 04-15-2007, 09:36 PM   #3
Re: 16" O.c.
I think the idea fo 24oc for exterior for more insulation and 16oc for interior trim would be nice. Your right, though, some of my framers can't count past 16 anyways.
Old 04-15-2007, 09:36 PM   #4
KentWhitten's Avatar
Re: 16" O.c.
I'd say that you COULD do 2' centers, if you really wanted to. I actually framed a house both out and in were 24". Usually, it was just the exterior. made for nice walking through the walls instead of around them.
I would say the sponginess of the sheetrock would be a concern unless you do 5/8" or the newer stiffer 1/2" maybe.
Dunno, I guess it's just a personal preference.
I wouldn't think twice on a starter home, but on a higher end home, no way would I even think about it. The HO would surely have a friend that would say something.
Salmon Falls Cabinetry
KentWhitten is offline
Old 04-15-2007, 09:59 PM   #5
Teetorbilt's Avatar
Re: 16" O.c.
dawg, I can argue this on a number of levels.
We can start with when a 2X4 was actually that and was old growth lumber. Much stronger than the 3-1/2 X 1-1/2 farmed propeller blanks that we get today.
Here, 16 or even 12" OC became the norm due to lessons learned from hurricanes long before we had codes. It was called survival back then.
Albert Einstein
Teetorbilt is offline
Old 04-18-2007, 08:41 PM   #6
Home Repair Specialist.co
hrscammisa's Avatar
Trade: carpentry
Re: 16" O.c.
16 " centers are the only way to get your seismic conection here in Calif for your ply.and back then they used a lot of 1x12 siding
hrscammisa is offline
