Trade: Finish carpenter
This Is Why My SCMS Is A Bitch!
So I read the Mitre saw accuracy story in "This Is Carpentry" online magazine. Apart from the general tuning which is all pretty easy to achieve on the Dewalt, I found a serious problem in the flatness of the base. I have struggled to achieve good results with this saw, & lulled into a false sense of security by all those nice convincing milling patterns on the table, it never occured to me to look further. I'm not happy that I now have to pull my saw apart & get a machine shop to re-machine the base flat. Is it really that hard to get this right from the factory?
Re: This Is Why My SCMS Is A Bitch!
So I cut two test pieces & holding them in the vertical position against the fence I made a cut from each side.
This is how far out held against a straight edge. Now if I just had that Bosch angle measure........
Unless you are building a piano, the minor imperfections that you are describing are common in most of the tools we use, and should not cause us to much difficulty for most carpentry tasks.
LRG WoodCrafting
Seems to be the nature of the beast. My Hitatchi 12" will cut perfect 90* x 90*. But when you slide it over to 45* the vertical is no longer 90*. Doesn't seem like much but it makes it a big difference in quality of the joint. Trying to cut a simple flat picture frame with 45* angles becomes a chore instead of 8 simple cuts.
My DeWalt looks like that too. Fence in back is out front to back also.
True, but you do tend to have accuracy pushed when doing finish/custom work, & it helps if the saw in itself is working with not against you. General duties though, yep it wouldn't be an issue.
Trade: Finish Carpenter
After reading that article I went out and bought a digital caliper and spent some time tuning up my miter last week - I have been obsessing over it quite a bit myself - maybe too much.
Carpenter/Finisher
I have the same prob with my hitachi 12"
I read that (since it was manf in china) the tolerances arent real tight on the slide mechanism so the bevel doesnt stay true ![]() I have way less problems with my older style Hitachi (made in japan). The 12" has basically stayed in the shop in a corner for the past year since i made this discovery.
1st Gen tradesman My summer job in college became my profession |
Trade: trim carpentry
my dewalt is the same, I've learned to live with it.
I took one dewalt back b/c there was a full 1/8" difference from the stationary bottom plate to the part that swings. Material would catch it and get hung up when sliding it across. |
| Hitachi or DeWalt 8 1/2" SCMS? | KMac | Tools & Equipment | 11 | 12-28-2008 12:16 AM |
| New BOSCH 4405 SCMS w/Free Bosch stand $328 and FREE shipping | tnb | Tools & Equipment | 3 | 12-19-2008 02:43 PM |
| SCMS Which one 10" or 12" Bosch, Hitachi ??? | tnb | Tools & Equipment | 36 | 05-13-2008 01:14 AM |
| bosch scms wobble | Mrmac204 | Tools & Equipment | 3 | 07-26-2007 11:29 PM |
| Making a higher fence for Makita SCMS | Chris G | Tools & Equipment | 0 | 11-14-2006 10:08 AM |
