Trade: trim carpenter / remodeller
What Is This Partial Miter Joint Called?
Can someone tell me what the proper name is for this partial miter joint?
it can be found at http: //s231. photobucket.com/albums/ee48/thexsleeper/?action=view¤t=cutandmiterjoint.jpg (remove the spaces) I have always called it a cut and miter joint, but I don't know if that's the appropriate term. |
copper magnet
![]() Trade: custom metal fabrication
Re: What Is This Partial Miter Joint Called?
I can't get the picture open, but are you referring to a coped joint?
I like Green things
Did they use zig zags to hold it together?
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
I've heard it called a jack-miter, but what do I know.
LRG WoodCrafting
it is called a haunch cut. Not sure if that is the way it is spelled though.
Old houses have 4 1/2" casing with a 1/4" roundover on the interior edges, and backbanding around the outside perimeter... Since you can't do a butt joint with the 1/4" roundover, you make a miter cut on the first 1/4" of the roundover... then after that it becomes a butt joint. The picture is much clearer.
http: //i231.photobucket.com/albums/ee48/thexsleeper/th_cutandmiterjoint.jpg (remove the spaces) |
LRG WoodCrafting
I looked it up and I found one of my own posts. I am contributor L
http://www.woodweb.com/knowledge_bas...r_Details.html
Very good, thanks guys. I googled "jack miter" and sure would like that Festool setup that Brice Burrell has! wowie!
LRG WoodCrafting
Never heard it called a Jack Miter.
#11 | |
LRG WoodCrafting
Re: What Is This Partial Miter Joint Called?Quote:
Trade: Architectural woodworks/sheetmetal
I've seen it called and call it myself, a "Mason's Miter". Maybe a local name adapted by region.
Spheramid Enterprises
Architectural Wood Works |
I've heard it called a European Mitre.
Funny how I have always used the "tre" spelling rather than the "ter" spelling.
Trade: Builder
Lots of old houses around here, 1800s. With a bead running on the inside of the casing. Often the bead is on both sides of the corner. We call the joint a "Jack Mitre" here also.
#15 | |
to Canada.
| Tub-Tile joint, grout or caulk?? | Aframe | Ceramic & Stone Tile | 11 | 06-27-2011 02:55 PM |
| Anybody tried the Milwaukee 6955-20 Miter saw?? | jansondt | Tools & Equipment | 29 | 03-15-2011 01:00 PM |
| miter box need a lil help from experience | matthewcims | Tools & Equipment | 9 | 03-13-2009 09:33 PM |
| Amazon has got the Denali Miter Saw Stand on SALE for $65.89 delivered!!! | tnb | Tools & Equipment | 7 | 10-28-2008 05:07 PM |
| Miter Joints In Laminate Flooring ?? | AL MURZYN | Flooring | 6 | 12-27-2006 10:15 PM |
