What Is Opinion About Out Of Square Kitchen?
Old 12-10-2017, 09:08 AM   #1
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,437
Installed kitchen where 2 walls was out of square. At another side knee wall is square with main wall. Now of course 45' cut of counter tops do not match and I need cut it again at different angle (45 cut by menards). What is here opinion about out of square kitchens, is it that OK.
Edit, I installed knee wall and I did level up other wall with strips but didn't square it with main wall. Obviously it would not be acceptable if floor would go "parallel" with out of square wall but it is not case as floor but in that wall.
What is opinion about out of square kitchen?-20171208_115514-1-.jpg   What is opinion about out of square kitchen?-20171208_115502-1-.jpg   What is opinion about out of square kitchen?-20171208_115533-1-.jpg
tipitop is offline
Old 12-10-2017, 09:19 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,061
Re: What Is Opinion About Out Of Square Kitchen?
My opinion:
Don't mess up that cut; you have no extra material to spare.
Tinstaafl is offline
Old 12-10-2017, 09:23 AM   #3
tipitop's Avatar
Trade: carpenter
^^^ Actually both countertops are to long around 1". It is visible in 3 photo that countertop is to long by refrigerator. I ordered so because I knew will have to cut it again. That two that go over knee wall I ordered right length.
tipitop is offline
Old 12-10-2017, 09:24 AM   #4
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 254
Get fancy with your re-cuts if you want, but here's what I'd do:
Get more of that separate backsplash (the stuff on the right of the range). Rip the backsplash off the postformed to the left. Chew into the drywall in the corner to be able to stuff the corner of the counter in deeper (or belt sand the corner off). Stick the backsplash on and get gone.
Edit: just read that it's too long at the fridge... you might as well fix the miter, then.
Defenestrate is offline
The Following 3 Users Say Thank You to Defenestrate For This Useful Post:
Fouthgeneration (12-13-2017), MarkJames (12-10-2017), Metro M & L (01-07-2018)
Old 12-10-2017, 09:33 AM   #5
tipitop's Avatar
Trade: carpenter
^^^ I cut countertops with back splash, angle or square no matter, in this way - put yellow tape at cut than attach level with clamps as guide. Usually did that from top but recently do cutting from back. However cutting of back splash have to be finished with 10" chop saw as it do not fit under my 8 1/2" and skill saw can not get all of it. Open to hear about better methods. Must say my method work like brease. Cut probably up to 100 square or angled cuts of countertops and never run in trouble.
Generally my idea was it is easier to do 2 countertop cuts then square wall.
tipitop is offline
Old 12-10-2017, 09:55 AM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,977
I didn't realize folks cut off the 45 on that stuff. I also would belt sand the back of the corner, and do some drywall embedding. Then backer rod + caulk, and bring the paint down onto the caulk.
MarkJames is online now
Old 12-10-2017, 10:45 AM   #7
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,678
Make a template out of 3" plastic ABS strips (My preference over wood as it can be glued up solid in a matter of minutes, and doesn't move once set. Plus the glue is squirted in without moving the templates after setting them perfectly in place.), then cut/sand the counter tops to the template. The back splash shown will cover everything else.
Have you ever watched a stone company make templates for their counter tops? Although I really didn't read this article it covers the basics.
http://www.proconstructionguide.com/...rtop-template/
Can you really trust the cuts at Menards? My luck with hardware store cuts is not good.
Peter_C is offline
Old 12-10-2017, 11:10 AM   #8
VinylHanger's Avatar
Rewards Points: 7,596
This is why there are countertop guys.
Let the guys who do what they do do.
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
B.D.R. (01-02-2018), TNTSERVICES (12-11-2017)
Old 12-10-2017, 11:26 AM   #9
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
Yep, agree with the others.
Heck I'd never even think about doing countertop work without making a accurate template (or at least taking some measurements and checking for square.
Years back, I saw a granite company using drywall shims and a glue gun to make their templates. It went quick and they easily folded it up to take it back to the shop.
"It's rare to find square."
You have extra wiggle room to re-cut it and/or hide it with backsplash or grout(or both)
I once measured up a kitchen for new countertops and the walls were doing an inward wave between each stud. A good 3/4" to 1." Out of square corners is all too common.
You're a carpenter ?
kirkdc is offline
The Following 2 Users Say Thank You to kirkdc For This Useful Post:
Defenestrate (12-10-2017), SmallTownGuy (12-10-2017)
Old 12-10-2017, 11:32 AM   #10
avenge's Avatar
How often do you run into perfectly square corners? I quit doing counter tops years ago when I did I cut my own.
avenge is offline
Old 12-10-2017, 11:38 AM   #11
rrk's Avatar
Rewards Points: 1,902
I that a post formed top?
The way I have done it in the past is hold a spacer the width of the gap centered over the seam.
Hot melt a piece of hardwood to the top butted against the spacer. Remove the spacer.
The area left is what needs to be cut. Remove tops and use a router with a guide bit and cut from the back side with the bearing against the hardwood. Use a belt sander for the back splash.
I does work but takes a while
Just make sure the guides stay in place, after removing the tops clamps can be used to hold them in place
rrk is online now
Old 12-10-2017, 01:44 PM   #12
Stilla's Avatar
Trade: Finish carpentry
Rewards Points: 598
The only thing square these days is the paper the plan is drawn on.
Stilla is offline
The Following User Says Thank You to Stilla For This Useful Post:
m2akita (01-01-2018)
Old 12-10-2017, 02:05 PM   #13
TimberlineMD's Avatar
Rewards Points: 738
Put the miter together as perfectly as you can.
Set counter top onto cabinets and push til the backsplash touches the back of the wall.
Adjust top so you see where the humps in the wall are.
Mark the wall with a sharp pencil at the same hieght as the top of the splash.
You can remove drywall where the top splash touchs wall up to a 1/2" and embed the splash into the wall.
You can remove up to 1/2" of the top of the splash by scribing it to the wall.
Your limitations will be when the front top nosing touches the face frame of the cabinets and will not let you push the top back any further.
It's easy to have a business that is busy.. it's harder to have a business that makes a profit
TimberlineMD is offline
Old 12-10-2017, 03:00 PM   #14
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,434
This belongs on diychatroom.
Big Johnson is online now
Old 12-10-2017, 03:32 PM   #15
rrk's Avatar
No, Tipi is good
rrk is online now
Old 12-10-2017, 03:36 PM   #16
rrk's Avatar
It may work, that left side is at least 1" out of square judging by the gap. I would not touch the right side because that would bring the end out really far
rrk is online now
Old 12-10-2017, 03:40 PM   #17
Originally Posted by rrk View Post
No, Tipi is good
Ok..
Well my advice is: never buy countertops with attached backsplash. Never ever.
tipitop (12-23-2017)
Old 12-10-2017, 04:08 PM   #18
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,085
Hey do me a favor and finish taking the plastic off the microwave!!!! The crown molding looks good btw!
Jay hole is offline
Old 12-10-2017, 05:52 PM   #19
rrk's Avatar
Ok..
How else do you by post formed tops ?
rrk is online now
Old 12-10-2017, 06:03 PM   #20
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,926
No, Tipi is good
These the brand you wear?
SmallTownGuy is online now
Your help is needed! Inventory work track checklist? ElectricianC-10 Electrical 19 10-26-2017 04:07 AM
Recommend a double square for tool belt Spencer Finish Carpentry 20 04-29-2016 10:11 AM
Quartz kitchen countertops redwood Kitchens & Baths 7 07-21-2013 08:25 PM
Poll - Do you give free Estimates? metroconstruct General Discussion 39 06-12-2013 11:18 PM
Pricing by the sq. ft./lin. ft./unit Seven-Delta-FortyOne Business 13 02-09-2012 11:19 AM
