What Filler Do You Use? Paint And Stain
Old 12-17-2007, 06:30 PM   #1
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Question
What Wood Filler do you guys use on your trim work? I have tried a bunch of stuff from Wood Filler to Caulking to Drywall Mud (came up with that after seeing it on a This Old House segment. I still end up with dimples
Paint Grade:
Stain Grade:
LNG24 is offline
Old 12-17-2007, 06:36 PM   #2
Thom
thom's Avatar
Re: What Filler Do You Use? Paint And Stain
On paint grade I generally use ez sand. It doesn't shrink as much as other stuff.
thom is offline
Old 01-03-2008, 09:26 PM   #3
sausagefingers's Avatar
Trade: Cabinetry and trim
I use Fam-O-Wood for pretty much everything. I normally only have birch or maple colored and it matches fine even with red oak material. If whatever I'm doing is painting i bust out the lightweight spackle and it works great, especially if it's used on the joints of crown and base...pretty much anything that is going to paint.
sausagefingers is offline
Old 01-03-2008, 11:02 PM   #4
Any Season's Avatar
No real preference for stain but for paint I like to use lightweight spackle and wipe clean w/ wet rag after it dries, you can paint in one coat bc you've wiped off the excess that usually remains then flashes if you sanded.
Any Season is offline
Old 01-03-2008, 11:10 PM   #5
Charitable animal
Bone Saw's Avatar
Trade: decks
epoxy and microballoons
Bone Saw is offline
Old 01-13-2008, 11:05 AM   #6
MA
G@PC's Avatar
I agree with all season, light wgt. spackle works the best but you could also mix up a little durabond 45 which works well too. Stainable...I'm still looking for a good product. Best one so far is actually wood filler by Elmers. Needs to say paintable/stainable on label. If anyone knows of an alternative would love to hear about it.
G@PC is offline
Old 01-13-2008, 11:23 AM   #7
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Whatever I remember to have on hand, Durabond, lightweight, Red Devil,bondo.
silvertree is offline
Old 01-13-2008, 03:11 PM   #8
Grove Design's Avatar
Trade: custom remodeling/building
try using durhams water putty for paint grade- cheap and comes dry in can-never dries out in the can-mix what you need.
Grove Design is offline
Old 01-15-2008, 11:06 PM   #9
CasDev's Avatar
Trade: Carpenter/General
If your using drywall mud for filler you might need new glasses
Not that i ever need filler... but do you guys consider filling nail holes
the carpenters job or is it the painter/stainers job?
filler is for a a true FINISH carpenter shouldnt need it
CasDev is offline
Old 01-15-2008, 11:13 PM   #10
cleveman's Avatar
Trade: custom home building
I'm mostly filling a pre-finished wood, so I use a wax stick. Otherwise, I mix up a bit of filler using some fine sawdust and glue.
cleveman is offline
Old 01-16-2008, 12:15 AM   #11
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
How do you figure this one? Is there a new fastening technique for installing doors, windows, casing, crown, base, and shoe that I just dont know about yet?
Since I wont let any local hack painters (or even homeowners) get their grubby paintbrushes on any room I build, I swing the brush myself. If the trim is getting painted, I hit the nail holes with a little spackle, leaving it heavy... A swipe with some 220 grit levels it nicely. If trim is getting stained, I spray it all beforehand in my shop, usually topcoating with pre-cat lacquer, and fill the nail holes with a minwax pencil... Rub the pencil back and forth ntil the hole is filled flush, and wipe off the excess surrounding it with a damp cloth.
(I hate Minwax stains and wont use them, but there's usually a minwax pencil that comes close enough to whatever color I need)
- Alex
Long Island Remodeling Contractor
Splinter is offline
Old 01-16-2008, 02:59 PM   #12
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
I like to use CrackShot from DAP. Fill the holes, let them dry and wipe them down with a medium/fine grout sponge. I find rags tend to dig in the holes to easily.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 01-16-2008, 05:57 PM   #13
Trimwerx's Avatar
I've been using the Elmers stuff they have at lowes for my paint grade stuff and i like it. For the stain grade stuff, i've been using the minwax stainable filler.
Trimwerx is offline
Old 01-16-2008, 06:50 PM   #14
LRG WoodCrafting
Leo G's Avatar
If someone brings you a cabinet it should be ready to primer/paint/stain. If the installer puts up trim, cabinets, etc. it turns to the painters job. That's my take on it.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 01-16-2008, 09:49 PM   #15
General Contracting
LNG24's Avatar
Quite an interesting comment. So uou don't use nails in your cabinet making projects? Funny, I hae been building fine furniture sine 1979 and never have been able to sink a nail into trim without my eye ebing able to see the hole.
So since you are the expert here, please do tell us, just how do you fasten your trim without nails?
LNG24 is offline
Old 01-16-2008, 09:57 PM   #16
LRG WoodCrafting
Leo G's Avatar
90% (or more) of the cabinets and furniture I build I use no nails, screws or fasteners. It is called joinery [and glue]. One of the few things that I will nail are moldings. I could just glue them also but the time needed makes it prohibative. Installing trim and cabinetry usually requires nails or screws to make it safe in the home.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 01-16-2008, 10:34 PM   #17
The Man
Cashking63's Avatar
I get tired of the whole " framers: Screw it, the drywaller will fix it Drywaller: screw it, the trim guy will fix it
Trim guy: screw it, the painter will fix it"
When I finish something, cabinet, trim or whatever, it is ready to paint or stain. That means sanded, holes and imperfections are filled.
oh yea for paint I use bondo or durabond, for stain I have to agree about the minway stixs
Cashking63 is offline
Old 01-16-2008, 11:17 PM   #18
Tin Cup's Avatar
Trade: Repair & Restoration Contractor and Specialty Graphics/Sign Installer
fill em with your own drywall dust boogers after you sanded the walls! they don't shrink as much.
Tin Cup
Tin Cup is offline
Old 01-17-2008, 10:51 AM   #19
General Contracting
LNG24's Avatar
Leo,
I agree 100% with your statement, but the Trim is the last to go on and as you stated, requires nails. If you or anyone can tell me how you install Base, Door, Crown and Chair Rail mouldings in a home without using nails, I'd love to hear it.
After all, that was the Original Question. How do you hide nail holes when installing trim on a house. If I was referring to cabinet making, I would have been over on the Woodworkers Forum.
LNG24 is offline
Old 01-23-2008, 10:45 PM   #20
BTD's Avatar
Trade: Trim and Finish Carpentry, Remodeling
You must use the kind of wood that doesnt dry or warp. It must be nice.
BTD is offline
