Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Finish Carpentry
Old 05-10-2006, 10:08 AM   #1
Trade: Audio/Video
Are uncut stringers old fashioned for stairs?
I have a home that when you walk in you can see the stairs from the side view. I'm putting down wood floors but don't want to lay the wood on the stairs for budget reasons. The stairs now have cut stringers exposing the stairs but I'm thinking to close that up so you can't see the stairs and adding carpet to save money.
With modern stairs almost always being open.........do you think enclosed stairs scream "old fashioned"?
atari is offline   Reply With Quote
Old 05-11-2006, 11:28 PM   #2
Trade: Trim/Finish Carpentry, Woodworking, if its wood we do it!
are you talking about the skirt board? that's the piece of 1-by that runs the length of the staircase that the risers butt/miter against, and is installed as part of the finishing/trim job. stringers are the framed 2-bys (usually 3) that literally "make" the staircase, and they are what the risers and treads (and skirt boards on exposed applications) ATTACH to.
i think youre talking about the skirt board.
personally, I think it might be tricky to run a simple straight skirtboard on an exposed side of a staircase and have it look good with the rail and everything. However, it would look nice if you were able to box out the skirtboard to give it a few inches of width for something the balusters can attach to, but you'd have to do some neat trimwork to integrate the extra width of the box to the wall below it. but, it can certainly be done!
Have you considered hybrid treads? theyre called "hybrid" because they are made out of hardwood AND regular, paint grade wood. Theyre used on staircases that are made to look like they have oak treads with a carpet runner. the hybrid treads have either just one end with the hardwood that will be exposed, or both ends in applications where both sides of the staircase are exposed. Hybrid treads are less expensive than full hardwood treads, and this way you could keep your current skirtboard AND add carpet.
my .02
kris jusnes is offline   Reply With Quote
Old 05-30-2006, 12:59 PM   #3
Trade: Residential custom home builder
A one-by skirt wouldn't look too bad in an old-themed home, but it might look odd mixed with modern trim. You'd need to build it out to a knee-wall, like kris said.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline   Reply With Quote
Deck stair stringers?? bujaly Decks & Fencing 29 08-12-2007 11:05 PM
Facia/post wraps/trim for stringers w/IPE? mucky24 Decks & Fencing 6 07-01-2007 07:40 AM
