Trimming Out Arch Windows ??
Old 03-07-2010, 10:59 PM   #1
232323's Avatar
Trade: remodeling contractor
Im trimming out a housefull of arch windows in a remodel job. Do to sloppy header contruction and other issues, the wall thickness around these windows can vary as much as 3/8" . The sheetrock may be flush with the jamb at a corner or two and then the jamb may be as much as 3/8" shy at the opposite corner. Normally, I would just add to the jamb, but I can't do that since it varies so much. Also, Im not sure if I have a way to add an extension to the arch...but it also varies from one side to the other (flush to 3/8" shy). For lack of a better idea, I've scored the sheetrock in areas that are within 3/16" or so and cut the shreetrock out completely using the arch and casing as a templete in the worst areas. The trim is then embedded into the shreetrock in places. Looks fine looking straight on, but alot of extra work. Might be a better idea out there??
232323 is offline
Old 03-08-2010, 09:37 AM   #2
DN Construction
dnconstruction's Avatar
Trade: Construction
Re: Trimming Out Arch Windows ??
boy I hope it is going to have painted trim and not clear!!! I hate to say caulk is going to be your friend on this job but I think it is!
dnconstruction is offline
Old 03-08-2010, 10:20 AM   #3
genecarp's Avatar
Most window companies offer matching ext jams, order the ext jams using the deepest measurement, then trim back from there to meet the sheetrock, and trim GMOD
genecarp is offline
Old 03-08-2010, 04:33 PM   #4
YesMaam27577's Avatar
Trade: Small-jobs contractor
Like Gene said -- get the pre-bent jamb extensions, and do whatever scribing you need to do.
YesMaam27577 is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Windows - Blind Inside? MHMConstruction Windows, Siding and Doors 12 02-20-2010 01:50 PM
Bad windows or bad installation ? AllenCreations Windows, Siding and Doors 18 01-26-2010 05:25 PM
Windows XP Mode in Windows 7! gideond Technology 9 05-15-2009 12:34 AM
Labor Est. for swapping vinyl rep. windows to wood clad rep. windows? Tallguy1 Windows, Siding and Doors 6 02-10-2009 12:58 AM
