Trimhead Screw Countersink Tip
Old 02-28-2009, 10:23 PM   #1
basswood's Avatar
Trade: trim carpenter
I have found that if you drill countersinks for trimhead screws (even though people say you don't need to), that the driver bits last much longer, especially in hardwoods.
I use GRK screws and have found the a Unibit (stepped drill bit) is a great for drilling coutersinks (perfect size and geometry). The step next to the screw head in the pic works for the T-10 screws and the next step up works for the T-15 screws.
I use an 1/8" bit for the pilot, the Unibit for countersink, and then use the impact driver to run the screws in.
I use trimheads to join cabinet faceframes together (and lots of other stuff).
Trimhead Screw Countersink Tip-unibit-countersink.jpg   Trimhead Screw Countersink Tip-faceframe-setup.jpg
basswood is offline
Old 02-28-2009, 10:26 PM   #2
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
Re: Trimhead Screw Countersink Tip
I use my step bits for lots of things, like drilling out lock cylinders and peepholes for exterior doors. Good call on countersinking trim screws.
olyteddy is offline
Old 02-28-2009, 10:34 PM   #3
Five Star's Avatar
hey Bass, is it just me or is the makita gun on the left shorter than the one on the right..?
just currious i have the same set and the drill is hard to use on cabinet work because it so long..the impacts are perfect im taking about the drills..?
Five Star is offline
Old 02-28-2009, 10:39 PM   #4
LRG WoodCrafting
Leo G's Avatar
Nope, the one on the right is shorter than the one on the left. All three are different guns.
So it is you.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 02-28-2009, 10:41 PM   #5
basswood's Avatar
I do have two different drills and one is shorter, lighter, and is just 2-speed. (I bought a second kit to get another drill & charger and additional batteries).
If the shorter drill is still too long, this right angle attachment gets in really tight spots:
basswood is offline
Old 02-28-2009, 10:45 PM   #6
topsail's trimcat
woodworkbykirk's Avatar
i normally just use a #6 countersink bit with a tapered pilot hole bit in it. they have a hex shank which my impact driver will accept
just avoid the mibro brand bits, i was checking out what sears had in their tool section one day and saw they had a 4 pack of the different sizes, they were only 14.99 as opposed to 32.99 which hd charges for the wolfcraft set.
regardless after 3 holes in mdf the mibro broke all to hell and im back to the wolfcrafts
woodworkbykirk is offline
Old 02-28-2009, 11:07 PM   #7
Five Star's Avatar
i have the makita lxt right angle impact, the reason i asked i thought the only lxt blue kind was a hammer drill too..but now i see the 2 speed and me like. time to browse
Amazon.com: Bare-Tool Makita BTL061Z 18-Volt LXT Angle Impact Driver (Tool Onl
Old 03-01-2009, 08:17 AM   #8
KMac's Avatar
Right on with countersinking trim heads - those things are sometimes hard enough to drive. I use this http://www.mcfeelys.com/product/MS-7...ad-Countersink
And I have the makita LXT set myself - love the impact gun.
KMac is offline
Old 03-01-2009, 08:24 AM   #9
basswood's Avatar
KMac,
I used to use the pilot and countersink combo, but I like to drill deeper pilot holes... so went back to the standard bit for pilots.
I do like the Makita Li-ion stuff. Muy bueno.
basswood is offline
Old 03-01-2009, 08:31 AM   #10
KemoSabe
loneframer's Avatar
Hey Basswood, I've been using a bunch of different Torx head screws, I havn't seen them in a typical trimhead size though. I will say that in other apps. they perform much better than square drives or phillips. Have you used them? Anybody? Have you seen them in trimheads?
loneframer is offline
Old 03-01-2009, 08:38 AM   #11
basswood's Avatar
I use GRK torx drive trimheads... the only way to go:
http://www.grkfasteners.com/en/TRIM_0_information.htm
basswood is offline
Old 03-01-2009, 08:40 AM   #12
KMac's Avatar
There are star drive trim head screws readily available.
KMac is offline
Old 03-01-2009, 08:43 AM   #13
KemoSabe
loneframer's Avatar
How well do they perform? Do the bits round off easily?
Old 03-01-2009, 08:47 AM   #14
KMac's Avatar
Better than a square drive for sure. I get mine from Mcfeelys. That link basswood posted looks like some good fasteners.
KMac is offline
Old 03-01-2009, 08:50 AM   #15
basswood's Avatar
T-10 bits have a shorter life than the larger torx bits... really short for some knuckleheads... there is a learning curve. Some guys will snap several bits in a day, but mine last for weeks... Hmmmm.
I do think the GRK bits last longer. I like it that they are color coded too. Makes it easy to see at a glance which bit is a T-10 (gold) or a T-15 (red).
Might not make sense, but the T-10 bits last longer in an impact driver than in a standard drill/driver too.
basswood is offline
Old 03-01-2009, 08:53 AM   #16
irockwithdirt's Avatar
Trade: Carpentry, Remodeling
IMO the torx and square drive trim head screws are far superior, torx the better of the two. Always had problems with the phillips head ones stripping out.
Depending on the material I've found countersinking very useful, especially if you might need to back the screw out/ reposition.
irockwithdirt is offline
Old 03-01-2009, 09:02 AM   #17
KemoSabe
loneframer's Avatar
Yup, we drive a ton of stainless screws, and they are usually a one shot deal, we use them alot with the hidden festener decking systems, and the treated SYP is tough on them. Next time I'll try the torx heads.
Old 03-01-2009, 09:04 AM   #18
I've used the step bits in a pinch,
but mostly in the other direction..
#12 & #14 +.
I have some Vermont American pilot bits
and they are stepped up from bit to
shank to head.
If i stop at the shank part its just right
for trim heads.
On cabinet rails I go back with a longer
twist bit to finish the deeper pilot.
(Need to get this pic sizing thing down)
neolitic is offline
Old 03-01-2009, 10:04 AM   #19
LRG WoodCrafting
Leo G's Avatar
Same set I have. Not impressed with their sharpness. I'll have to get off my lazy but and resharpen them like I do with all my cheap tools. Then they will work better.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 03-01-2009, 10:13 AM   #20
They don't "clear themselves" very well
in hardwoods, but they do have their
place in my arsenal.
neolitic is offline
drywall screw length vs vapor barrier blacksheep Drywall 7 02-08-2009 09:01 PM
quik drive screw guns platinumLLC Tools & Equipment 6 12-23-2008 11:34 PM
collated screw guns for backer platinumLLC Flooring 3 12-01-2008 07:11 PM
Screw length for fastening 2 x Ipe? Chris G Decks & Fencing 9 09-18-2008 07:50 PM
Auto feed screw guns vs. pneumatic screw nailers sk8park Tools & Equipment 9 04-07-2008 11:41 PM
