Trade: trim carpenter
Trim/Crown Cutting Jig By Basswood
For big jobs, I make a cutting jig with a fence the height of the baseboard, and attach a curb to the table that holds the largest crown on that job (I make fillers that fit inside the curb to hold smaller crown "in position").
The jig allows me to cut base standing up, crown bedded (for upside-down and backwards cutting) and casing is cut flat in the same jig. Any questions, comments, or tomatoes? |
| The Following 2 Users Say Thank You to basswood For This Useful Post: | Deadhead Derek (02-06-2009), Winchester (02-15-2009) |
Trade: Contractor
Re: Trim/Crown Cutting Jig By Basswood
I like it. It is pretty much the same as what I do. It's surprising the number of guys who think it is a waste of time.
| The Following User Says Thank You to precisionbuild For This Useful Post: | Deadhead Derek (02-06-2009) |
Mod / ArchiBuilder
I make the same jig, it makes it very fast!
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
| The Following User Says Thank You to Cole For This Useful Post: | Deadhead Derek (02-06-2009) |
Takes 15-30 min and pays you back the same day.
I make mine out of 1/2" MDO (signboard). Here is a plan for a table/fence and supports out of 1 4x8' sheet: |
Re: Trim/Crown Cutting Jig By Basswood |
Mod / ArchiBuilder
You got that right!, I am with you.
Hmmmm, spooky!
Pretty much the jig I use for crown...... And that's my saw there.
Neo do you have a Delta? or are you just razzin' me?
Yup, I like it, except at 65lbs
it should be listed as a stationery power tool.
Trade: Residential Remodeling
Thanks for the info! I do not do a tremendous amount of crown molding (trim carpenter usually does it) but I have had to do some in a pinch or on a small job. I will certainly be putting one together for the next one.
Trade: Finish Carpenter
I also make something similar - you gave me a couple idea's to incorporate next time I through one together. Thanks.
Oops, I just noticed, in the 3rd
pic I can see you have the "worm drive" version.... Mine is the cheaper twin laser. You have more depth on a left hand cut, right? The lasers save a lot of glasses on glasses off stuff for me though.
#13 | |
Re: Trim/Crown Cutting Jig By BasswoodQuote:
Regards, Bass |
#15 | |
G'day, Bass |
#16 | |
Wasting Time
Two questions: (and please forgive me for my ignorance) 1. How do you secure the wooden fence to the saw's fence? 2. If you cut larger crown and you want a crown stop/jig won't the 6 inch table top be too small? I noticed in your later post with the larger crown that it didn't appear that you used stops |
Trade: Carpentry, Remodeling
I usually have to frankenstein stuff like that together out of whatever's laying around LOL
#18 | |
http://www.mcfeelys.com/product/0510...Mounting-Screw The crown pictured is 6-1/2" and the jig I made will work with crown up to 7-3/4" if the curb is moved out to the edge. This is the largest crown the Delta will cut bedded ("in position"--upside-down and backwards). I cut larger crown flat on my Hitachi 10" SCMS. I like to cut crown bedded with curb (though one pic shows a jig w/o a curb). |
| The Following User Says Thank You to basswood For This Useful Post: | Knighton (02-06-2009) |
#19 |
Wasting Time
Thanks for taking the time to respond and for the photo. I have a Rigid SCMS and it does have the holes. Why don't you use your Hitachi SCMS all the time?
#20 |
I use both saws on many of my jobs (see pic).
12" CMS's, like the Delta I use, have greater vertical cutting capacity than 12" sliders. This is most useful for cutting tall base, standing up, or cutting big crown "in position." The trim carpenter I learned the trade from used a 15" Hitachi CMS. http://www.toolbarn.com/product/hitachi/C15FB/ The 12" Delta I have has greater cutting capacity than the 15" Hitachi due to the innovative design (housing notched out behind the arbor, vertical motor, etc.--see photo). The Delta was designed by visiting jobsites and seeing how guys like me notched their housings and altered saws to get more capacity. The DeWalt 12" CMS is a close 2nd place in vertical capacity. Of course, sliders have greater horizontal cutting capacity, but 10" sliders have about the same horizontal capacity as 12" sliders, and the 10" saws have less runout, less expensive blades, and are lighter saws. This is why I use a combination of a 10" slider and a 12" dual-bevel CMS. The 10" slider goes to most every job, and the 12" Delta CMS goes to the tall base and big crown gigs. Best of both worlds. The Delta is heavy, as mentioned, and spews dust in all directions, but it is the best for cutting big trim. Last edited by basswood; 02-06-2009 at 11:40 AM. |
| tip for cutting back metal roofing | 72chevy4x4 | Construction | 15 | 04-12-2010 02:02 AM |
| Cutting Concrete Board | jarvis design | Ceramic & Stone Tile | 19 | 10-16-2008 12:14 AM |
| Metal cutting circular saws??? | nwksremodeler | Tools & Equipment | 17 | 05-04-2008 07:29 PM |
| proper way of loading of brush from a cutting pail | Zeebo | Painting & Finish Work | 7 | 08-11-2006 11:58 PM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
