Trade: General Contracting
Is There An Easy Fix?
Should have been a simple trim job, door casing! Around a pre-hung door. The home owner framed out the walls and installed the door himself. The door is hung plumb and square. The walls don’t come close. For instance, the hinge jamb face is flush with the drywall top to bottom and the striker hinge jamb face sticks out past the drywall more than 1 inch at the top and tapers to the bottom then becomes flush with the drywall. On the other side of the door. The hinge side jamb face sticks out a ¼ inch at the bottom then sinks bellow the drywall ½ inch at the top. The striker side jamb face is sunken bellow the drywall 1 inch at the top and bottom. Any suggestion how to make this work without removing drywall and reframing the walls correctly? Drywall is finished an painted!!!
#2 | |
It's all about the Avatar
Trade: I have no face!
Re: Is There An Easy Fix?Quote:
Insert title
Trade: Doors-Windows-Decks
Nothing will ever look perfect to another finish carpenter. I have tried running extension jambs at an angle with the worst being 2"-->0" over six feet. Sometimes if the door is at the end of a hallway you can run the same size ext jamb and fill in behind the trim. Sometimes caulking will work.
I like to bring a 6' level to see how plumb the walls are before I quote a job. I much rather not do a job than do a job and have the customer un-happy with the outcome.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
oh, gets better. carpets in and drop ceiling also.
doest sound like 500 anymore. |
Trade: Florida Certified Design-Build Contractor CBC023304
tearing down the wall and starting from scratch is the only way to be "perfect", if perfection in this imperfect world is your goal. But, if you want to "fix" the problem, the best way is to re-hang the door; remove the casing, use a nail-set to punch through the nails in the jamb, then rehang the door, "humoring" the wall. In other words, make sure the edge of the jamb is flush with the drywall. If the wall is out of plumb, then the door will be out of plumb. But, it will "look" right!
#6 | |
this idea sounds like the quickist way, but the end result????
If i reset the door and hummor the wall the door will be out of plumb about 1 inch on the stiker side jamb top to bottom. this may look vary odd. decisions,decisions.......... |
Trade: carpentry
I'd try to get as close as I could w/ extension jambs, then find a talented plasterer to float mud and feather it into the field of the wall to bridge the gaps where the jambs stand proud of the drywall...
Trade: Remodeling contractor
No way ... stop it!!!!!! feather this you lazy bastard...........
Back in Maine Dubbin' Around Doin' good stuff ...... |
#10 | |
The idea of floating this and cutting that is the lazy man's way. Knock that jamb around until it's flush to the wall, make the correct adjustments with striker, the latch & door stop. Those walls can't be that out of whack. Split the differences. Not rocket science here guys.................
Heavy Weight Champ
Trade: finish carpentry
sounds like you are working in Arizona. I would just beat the $#!$ out of the dry wall. put the casing up and trace whare it is going, and beat the $#!$ out of it. I do it almost everyday.
Real nice guys |
#12 | |
Heavy Weight Champ
Real nice guys Last edited by King of Crown; 04-22-2007 at 11:51 PM. Reason: spelling |
Home Repair Specialist.co
Trade: carpentry
Hang some curtains there and call it good LOL
Get out of there! Don't you have something else to do? The HO got this far, let him finish it! I see anguish written all over this job.
Charitable animal
Trade: decks
couldn't agree any more
When wall is that out of level dont try and be the one to solve everyone elses work. Set the door even with wall so your trim sits correctly. Remove and reset the stop moulding so it closes. Then to stop the door from swing open or closed because its out of level bend the hinge pins a little to create friction. You cant be reframing walls here.
Trade: Residential General
Re: Is There An Easy Fix? |
#18 | |
Heavy Weight Champ
Real nice guys |
#19 |
wannabe
Trade: carpentry
How old is the house? We cut that much off the botoms of doors! We remodel 100+ year old homes...and short of a $100,000 remodel we do whatever we can. Worst case, we taper our extension jambs and reverse taper the opposite side.
Sometimes it feels like we're walking through a fun house, but historical value is what it is. Last edited by WNYcarpenter; 04-23-2007 at 02:56 PM. |
#20 |
I thought it was only a door install or casing. So why get involoved Baseboard trim, wall framing, drywall spackle and paint. When price new doors and trim for a remodel I dont go around leveling walls before estimates so you have to work these things out in the field. I never suggested to anyone to reframe a wall---only if the customer weas extremely anal and couldnt accept any other option. Just my thoughts.
| web easy 6 | donb1959 | Technology | 5 | 03-10-2008 06:48 PM |
| Easy Sand | boman47k | Painting & Finish Work | 10 | 04-28-2007 10:17 PM |
| Kids got it easy! | ron schenker | Off Topic (Non Trade) | 14 | 02-26-2007 08:51 PM |
| Easy now.. | Standstrong | Decks & Fencing | 21 | 12-11-2006 07:58 PM |
| OK Crown Molding easy????? | heavyparts | Carpentry | 8 | 04-27-2006 07:28 PM |
