Tall Base Into Toekicks - Finish Carpentry - Contractor Talk
Old 12-01-2016, 04:29 PM   #1
saynever's Avatar
Trade: electrical
Rewards Points: 229
What's the preferred method when you have tall base on a wall with no cabs meeting a wall of base cabs at 90?
Is it better to run the base or base and shoe past the cabinet and scribe a filler or just notch the base?
We are talking a more traditional 1x6 or 1x8 with cap.
Or neither of the above?
saynever is offline
Old 12-01-2016, 10:03 PM   #2
slowsol's Avatar
Rewards Points: 2,234
Re: Tall Base Into Toekicks
Die the base into the cabinet?
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
pinwheel (12-13-2016)
Old 12-01-2016, 10:37 PM   #3
Westward's Avatar
Trade: Home Builder
Rewards Points: 314
I'd prefer an accurately notched base running under the cabinet to the kick, provided you don't need to notch over or bevel the notch to allow the door to clear.
You could return the base to the wall at the cabinet, but you'd have to decide if that would look OK or not.
Westward is offline
Old 12-01-2016, 10:40 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,493
Install filler first, so run base to the filler. Notch it to extend into the toekick, if necessary. If you're using a thin scribe molding at the wall, do that last and run it down to the top of the baseboard. That's one way.
MarkJames is online now
Old 12-01-2016, 11:33 PM   #5
saynever's Avatar
Trade: electrical
Rewards Points: 229
There was an allotted 1 1/2" filler to assure drawer clearance past the door casing from the beginning.
Mark, that's what I was thinking and have done before.
It would be different if the filler was smaller than what I have to work with here. I was asking more for future reference if the cabinet designer/installer had forgotten to accomadate the base or casing thickness.
saynever is offline
The Following User Says Thank You to saynever For This Useful Post:
tasdidalvi (06-01-2017)
Old 12-02-2016, 04:28 AM   #6
Big Shoe's Avatar
Rewards Points: 1,884
Cabinets should have a filler. At least 3/4 minimum. If not then you may need to be creative.
Expect the Unexpected
Big Shoe is offline
Old 12-02-2016, 01:17 PM   #7
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 194
Add a Plinth block at the cabinet to have the Base run into. Doesn't need to be full width, but can be slightly taller than the Base.
jlhaslip is offline
Old 12-02-2016, 04:41 PM   #8
Livin the dream...
Spencer's Avatar
Trade: Remodeling/Finish Carpentry
Rewards Points: 5,512
I always notch it.
Lewis Carpentry
Spencer is offline
The Following 2 Users Say Thank You to Spencer For This Useful Post:
john5mt (12-19-2016), pinwheel (12-13-2016)
Old 12-13-2016, 08:16 PM   #9
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
Filler will be flush with the face frame?
I'd butt the top of the base against the filler and extend the remainder (3") of length to the toe kick.
I hate these configurations with tall base.
philcav7 is offline
The Following User Says Thank You to philcav7 For This Useful Post:
OldWorldTrim (12-15-2016)
Old 12-14-2016, 10:01 PM   #10
OldWorldTrim's Avatar
Trade: Finish Carpenter
Rewards Points: 16
I've always notched the base to die into the cabinet and toe kick
OldWorldTrim is offline
The Following User Says Thank You to OldWorldTrim For This Useful Post:
Metro M & L (12-15-2016)
base picture frames and chair rail on out of level floors mastersplinter Finish Carpentry 10 04-18-2014 10:33 AM
base trim on island Kent Whitten Finish Carpentry 40 03-03-2012 01:14 AM
Scaffolding - Base Width Question ZachElwood Health & Safety 2 11-09-2010 02:09 PM
Router Table base cabinet. ApgarNJ Tools & Equipment 83 11-06-2010 12:39 AM
Need a saw to cut 7.25 base standing up DKC94 Finish Carpentry 14 09-26-2010 08:11 PM
