Trade: trim carpenter
Table Saw Millwork Thread
So yesterday I did some router table millwork... today was the table saws turn. I milled up 126' of 5" stepped casing for a Victorian. This job will related to several threads as this casing will be Jack-Mitered and Backbanded and will have a cabinet head crown too.
This casing was made with one pass on the table saw, followed by a router table pass, and then 3 passes through the table saw on edge. Tomorrow I will ease the corners on the steps with a sanding and will hog out a relief cut on the back of the casing with the dado head. |
Trade: siding
Re: Table Saw Millwork Thread
more please
Tom |
Otay.
The smooth faces on the steps have not been sanded. I used a Freud Glueline Rip blade it produces very smooth cuts... great for this millwork application. The blade produces ribbons like this that are paper thin and uber-smooth. Also here is a pic with a couple of steps cut and one of the pile ready for easing of the step corners. I'll check in later... off on a bike ride.
Maker of fine kindling
Nise set up, Bass
Sure will suck if you are few feet short though.
Every parent who has walked barefoot into their child's room late at night hates Legos |
The Remodeler
Trade: Home Remodeler
Re: Table Saw Millwork Thread![]() ![]() ![]() I've done that.....
Re: Table Saw Millwork Thread |
Trade: siding
you cut stuff short too??
me too!!
Tom |
| The Following User Says Thank You to Tom Struble For This Useful Post: | nEighter (07-30-2009) |
You did what??
I've never done that
Builder/Remodeler
Nice work Bass... You'd give Norm a serious run for his money.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
LRG WoodCrafting
I cut it three times and it's still to short
| The Following User Says Thank You to Leo G For This Useful Post: | Tom Struble (07-30-2009) |
Trade: interior remodeling
Another new saw blade,3 dozen spring clamps--
![]() ![]() ![]() ![]() Can I order all these toys through you so you get the commission? |
| The Following User Says Thank You to basswood For This Useful Post: | nEighter (07-30-2009) |
LRG WoodCrafting
Stop using the 1" mark for your exact measurements. Use the 10" line, if you screw up by 10" you deserve to have to remake it.
You did what??
#15 | |
Re: Table Saw Millwork ThreadQuote:
Here are a couple of pics of the "relief cut" set-up... I was dialing in the layout and depth... the shallower cut (3/32") is what I went with. It took 4 passes, but only two set-ups--run--flip end for end and rerun--move fence 3/4"--repeat. Making these shallow and wide dados in this set of millwork took one hour. |
#16 | |
The good blade helps, but the featherboards are the key. A few times I failed to keep the boards tight to the table and got bumps in the step line. I re-ran and couple that I noticed, but this one I missed and the saw was switched to the dado head... so I got out my straight-edge and utility knife and just fixed it... took just a few seconds to shave it back to the line: |
LRG WoodCrafting
How much time you got into them moldings Bass? A 2 1/2" cutter for my W&H costs about $80 and you could run a 10' length in about 1 minute the way I have it setup.
#18 | |
1 hour set-up 4 hours milling faces 1 hour plowing out backs 3 hours sanding, etc. 10 hours total x $60/hr = $600 labor Material: = $150 wood Total: $750 or 5.95/lf for custom 5" casing... seems fair to me. ![]() I think the mill wanted a couple hundred for knives and set up and it was going the be a wash so I just did it... work being scarce and all... or so I hear. For any larger run than this a shaper and power feed or W&H would be nice... but you know me... I still used a folding rule today.
#19 |
LRG WoodCrafting
$80 for cutters
$150 for wood add 15% $173 1 hour to size blanks $ 1 hour to hog out back $ $1.69/lf to run using my formula (125') $211 about 15 minutes to run. 1 hour to sand, maybe $ $465.00 using 3 hours 15 minutes time. $3.72/ft But of course that doesn't include the W&H setup which is about $2500 Usually if I am running mote than 50' of something I want to make a W&H cutter.
Sawdust Follows Me Everywhere http://lrgwood.com Custom Cabinets in Hartford County Connecticut Last edited by Leo G; 07-30-2009 at 08:13 PM. |
#20 |
I do this kinda thing by the hour... so you could say I'm a production trim carpenter... I produce as many billable hours as possible.
| The Following User Says Thank You to basswood For This Useful Post: | TBFGhost (07-30-2009) |
| Do you need a table saw on the jobsite? | CJ21 | Carpentry | 95 | 01-30-2011 02:20 AM |
| Looking to Purchase New Portable Table Saw | TurnkeyConst | Tools & Equipment | 22 | 04-24-2009 11:43 PM |
| New Bosch Table saw in Canada yet?? | 10fingers | Tools & Equipment | 9 | 04-18-2009 07:28 AM |
| Replacement fence for Porter Cable 698 router table | Panzer5 | Carpentry | 4 | 04-10-2009 11:47 AM |
| Makita Table Saw Problem....... | Donegal | Tools & Equipment | 1 | 04-01-2009 11:34 PM |
