Survey: Window Casing Installation
Old 05-14-2008, 02:03 PM   #1
JourneymanCarpenterT
Journeyman T's Avatar
Post
What are all of the hand tools that you use when you install window casing that you do not use to install door casing?
If there are any tools that you use for window casing, but not for door casing, or vise versa, pleas explain why.
Journeyman T is offline
Old 05-31-2008, 02:12 PM   #2
tcleve4911's Avatar
Trade: Remodeling contractor
Re: Survey: Window Casing Installation
Stuff I use for window trim but not needed for doors
Pocket screws for extension jambs
Router for window sills
Stuff I use for door trim but not needed for windows
Chisels for strikers
Screw guns for hinges & hardware
Pocket screws for both window & door head to jamb casings
Sometimes pockets & biscuits
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 03-15-2009, 09:12 PM   #3
trimmerdude's Avatar
Trade: Finish Carpentry
I use a hand plainer alot. Many times the jambs are sticking past the dry wall and need to by plained down.
trimmerdude is offline
Old 03-15-2009, 09:37 PM   #4
m1911's Avatar
Trade: trim carp
Small circ saw and jap pull saw for stool.
m1911 is offline
Old 03-16-2009, 12:02 AM   #5
CarpenterMatt's Avatar
Trade: Finish carpenter
???? Gota pic there tcleve?
CarpenterMatt is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Survey: Door Casing Instalation Journeyman T Finish Carpentry 34 07-19-2008 02:14 PM
Window casing sidejobs Carpentry 2 04-24-2007 03:10 PM
Casing on pre primed window jambs icfbunt Finish Carpentry 10 11-13-2006 09:30 PM
