Survey: Door Casing Instalation
Old 05-09-2008, 02:29 PM   #1
JourneymanCarpenterT
Journeyman T's Avatar
Post
What are all of the hand tools that you use when you install door casing (and only door casing), and which ones do you keep in your tool belt?
Journeyman T is offline
Old 05-09-2008, 02:43 PM   #2
General Contractor
KB construction's Avatar
Re: Survey: Door Casing Instalation
I keep a tile knife, a hammer, a tape, a nail set, and a pliers.
KB construction is offline
Old 05-09-2008, 02:46 PM   #3
Tom M's Avatar
Hammer,knife,tape, combination square and nail set.
Tom M is offline
Old 05-09-2008, 03:13 PM   #4
Forry's Avatar
Trade: General Contractor, Remodeler
Pencil?
Forry is offline
Old 05-09-2008, 03:24 PM   #5
lee's Avatar
Trade: 2nd Fix Carpenter
a pencil. maybe a hammer and punch.
lee is offline
Old 05-09-2008, 04:43 PM   #6
Dan_Watson's Avatar
ruler, tape, knife, nail set, hammer, pencil, combo square, 5 in 1 tool
Dan_Watson is offline
Old 05-09-2008, 05:11 PM   #7
Teetorbilt's Avatar
Just for installation? 5mm mech. pencil and pad in top pocket, 25' FatMax on belt. Angle finder in back pocket for older, settled homes.
Albert Einstein
Teetorbilt is offline
Old 05-09-2008, 05:21 PM   #8
Professional Instigator
rbsremodeling's Avatar
a pen to sign the check to pay my carpenter that installed it
rbsremodeling is offline
Old 05-09-2008, 05:25 PM   #9
Thom
thom's Avatar
A finish nailer and two squeeze clamps.
Casing is pre-cut. some doors take the clamps to squeeze everything together tight.
thom is offline
Old 05-09-2008, 06:07 PM   #10
Carpenter/Finisher
john5mt's Avatar
pencil, putty knife or 5 in one, utility knife, collins miter clamps, mini combo square, estwing 16 oz, nail set, and titebond 2
1st Gen tradesman
My summer job in college became my profession
john5mt is online now
Old 05-09-2008, 06:20 PM   #11
orson's Avatar
Trade: Kitchen & Bath
hammer, tape, 6" combination square, nippers, 5 in 1 painter's tool, glue bottle, nailset, bunny planes, sandpaper.
orson is offline
Old 05-09-2008, 06:53 PM   #12
genecarp's Avatar
jack hammer, case of caulking, chainsaw
genecarp is offline
Old 05-09-2008, 07:02 PM   #13
billy d's Avatar
Trade: carpenter
Hi Journeyman only door casing 1 6' level,1 2' level, 4 1 1/2" brads,string line, nail punch, hammer,combination square,tape and pencil.If it's hard wood + 3/8" centre point wood drill for grain plugs.If its in block a plugging chisel and axe because the bricklayers forget to put the plugs in even though they've been paid for it.
billy d is offline
Old 05-09-2008, 07:26 PM   #14
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Reading glasses, Ibuprofen, pencil. All in my pocket. Have not worn a nail pouch for years. I heard they make you sterile
silvertree is offline
Old 05-09-2008, 10:24 PM   #15
Hi. This is very interesting. It's nice to be able to talk to someone from another country.
First, what do you use the levels for? Do you use them for the casing, or simply to check the door jamb before installing the casing?
Second, I have the same question about the string.
Old 05-09-2008, 10:30 PM   #16
Remodeler
MinConst's Avatar
I'll bet the string is to check the plane across the walls.
Doesn't everyone use a level?
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 05-09-2008, 10:40 PM   #17
orson's Avatar
By the time I get to casing the worrying with level or plumb is over.
orson is offline
Old 05-10-2008, 12:27 AM   #18
Quiglag's Avatar
Trade: Finish Carpentry
Send a message via AIM to Quiglag
That's the truth.
Combo square, hammer, tape measure, 1.3mm mechanical pencil, spring tool nail set (best invention ever), shims, shark bar, nippers
Quiglag is offline
Old 05-10-2008, 07:25 AM   #19
billy d's Avatar
Trade: carpenter
Hi Journeyman the 2' level is to check the floor to see which jamb you fix first and also keep the head level.The 6' level is to check the walls,plumb the first jamb and check the timber for any undulations and fix with shims if necessary. The string is to tie my self up so the other guys can catch up LOL.After one jamb is provisionaly fixed and also one point on the other jamb a 1 1/2" nail is tacked at the top and btm of each jamb with the string you form a X across the face of the casing.You can then move the loose jamb so when the string touches in the middle you know that the two jamb's are 100% parallel with each other and on the same plain and there are no problems when you come to swing the door. Some times you must through the casing a bit I know this is not right but you must give the man coming after you a chance to get his cover on the walls,using the string will maintain that the jambs are parallel. On new block work the brickies should only go 5 or 6 course's high and move on but if it is raining they've got to make a living as well.To take it higher is to much weight for the wall and courses it to buckle and we just have to get round these problems. Billy
billy d is offline
Old 05-10-2008, 06:41 PM   #20
Trimwerx's Avatar
Hmmm... Hammer, punch, 5in1, tape, and pencil.
Trimwerx is offline
Do you use an impact driver? Quick survey help would be very much appreciated. cohaver General Discussion 4 04-02-2008 07:20 PM
fire marshal requires electrical survey 72chevy4x4 Electrical 1 02-21-2007 12:07 PM
Year end survey dumplin1078 Marketing & Sales 16 10-24-2006 07:56 PM
FEEDBACK: Online Survey Tool Nathan Off Topic (Non Trade) 9 08-29-2006 06:20 PM
