Stringer Trim Detail
Old 04-28-2009, 08:21 PM   #1
wannabe
WNYcarpenter's Avatar
Trade: carpentry
I should have some pics , but I'm hoping others may with their solution...
2 flight stairway with a landing separated by a 2x4 wall. Square stock stringer trim follows the wall and must wrap around the corner and continue down the 2nd fight. The dimensions I believe are arbitrary since this problem exists regardless....
The problem: the height of the trim on flight A cannot be wrapped around the wall and match the height of flight B. We're missing by 2 something inches.
Our solution: We're wrapping the corner on the first downward flight "A" (but we'd have to chamfer the wrap to get the miters to match) and squaring off plumb at the nosing of the first tread at flight "B" (edge of landing). We're Then butting the trim of flight B wherever it meets the wrap at the nosing.
I hope I explained this well enough! I'll take pics tomorrow so this detail is easier to understand.
WNYcarpenter is offline
Old 04-28-2009, 08:28 PM   #2
genecarp's Avatar
Re: Stringer Trim Detail
Is this the basic layout that you are describing with a 2x4 wall between the two runs?
http://www.piedmontvintagehomes.com/...entStairs2.jpg
genecarp is offline
Old 04-28-2009, 08:32 PM   #3
wannabe
Trade: carpentry
That's the basic idea...yes....Thanks
Old 04-28-2009, 08:42 PM   #4
basswood's Avatar
Trade: trim carpenter
This is how I deal with having to change height for a stringer.
Stringer Trim Detail-stair-skirt-base-layout.jpg   Stringer Trim Detail-base-skirt-trans.jpg
basswood is offline
Old 04-28-2009, 08:45 PM   #5
genecarp's Avatar
Thanks, i have been trying to figure out how to put that in words, nice you had that photo kicking around
genecarp is offline
Old 04-28-2009, 09:56 PM   #6
wannabe
Trade: carpentry
Thanks...That's it... That detail also solved another problem!
I would tend to bisect the angle from the tread/riser joint to the miter, or use a 45. just curious...is the chosen angle for the cope?
Old 04-28-2009, 10:22 PM   #7
basswood's Avatar
For the good of the cause!
after seeing the pics I remember doing something similar a few years ago.
I hoped that was what you were looking for. Carry on.
basswood is offline
Old 04-28-2009, 10:38 PM   #8
wannabe
Trade: carpentry
Basswood, how'd you come up with the angle for your miter? (I edited my previous post)...I would tend to bisect the tread/riser joint with the 5" base being returned into the stringer.
your miter ends just below the nosing. I'm probably missing something, but I'm thinking it has something to do with the profile.....I'm using square stock.
obviously there was a reason for what you did....
Old 04-28-2009, 11:31 PM   #9
You have to carry the horizontal
to the face of the riser, so the
vertical piece will work.
Can I confuse you some more?
neolitic is offline
Old 04-29-2009, 02:11 AM   #10
Meetre's Avatar
the angle is carried through from the other side of the miter...extend the line of the miter, it cuts the out side angle in half.
Meetre is offline
Old 04-29-2009, 07:12 AM   #11
Railman's Avatar
Trade: Railing
WNY,
He simply intersected the heights/widths of the mouldings, & then bisected the angles. That way the profiles will meet up perfectly. If your using flat stock, the profiles are gone, & angles can be fudged somewhat.
You can even fudge profile/bisect a little, but not so much as to change profile match too much.
BTW, there is no cope in his picture.
Bass,
As always, you've go the answers, & the picts!
Joe
Railman is offline
Old 04-29-2009, 07:34 AM   #12
stp57's Avatar
Trade: carpenter/ handyman
Basswood,
The wood you used looks like Poplar, even the cap molding. I didn't know it came in Poplar? Do you make your own molding?
Steve
stp57 is offline
Old 04-29-2009, 07:59 PM   #13
Originally Posted by stp57 View Post
Basswood,
Steve
It does up here in the heartland.
neolitic is offline
Old 04-30-2009, 06:50 PM   #14
basswood's Avatar
WNY,
Looks like your questions have been answered by others.
How did it go?
Steve,
Yellow-poplar is common here for paint-grade work. The base cap is part of the base ("speed-base")... no separate base cap.
basswood is offline
interior trim painting sprayer48 Painting & Finish Work 14 08-06-2011 01:47 PM
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 06:43 AM
Custom Trim jfrench General Discussion 11 04-12-2009 09:44 PM
Pricing new homes for trim? woodworkbykirk Finish Carpentry 24 01-26-2009 10:26 PM
