Stair Treads
Old 08-04-2009, 01:16 AM   #1
Old Crow's Avatar
Trade: General Contractor and Remodeling Contractor
Stair Treads
I am fixing to do some stair treads in cherry and i can't decide which way to go about it. First choice is to have 3/4 flooring and a 1inch nosing piece rabbeted out on the bottom to match the 3/4. Second is to glue up treads out of 3/4 stock with biscuits and the same 1" nosing piece. I know the flooring would be faster are there any other advantages or disadvantages? Thanks!
Old Crow is offline
Old 08-04-2009, 06:45 AM   #2
SDC's Avatar
Re: Stair Treads
Why not buy cherry stair treads....with labor prices I cannot see making them for less than buying them.
Just my $.02
David Cookman
SDC is offline
Old 08-04-2009, 10:17 PM   #3
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Re: Stair Treads
Buy 5/4 treads. Or glue up and mill 5/4 treads. Final dimensional thickness needs to be 1" clear, or they will crack and warp. I was in a house I installed 14 years ago a few weeks ago, it was the first solid tread job I ever installed. The treads still don’t squeak, and look great. But they are real treads. Flooring glued down will last 2-3 years tops. You will make money because it will last long enough to get you out of warrantee, but that is it.
Originally Posted by Leo G View Post
Ahhhhh, just buy it.
http://sacramentomillworks.com
Scribbles is offline
Old 08-05-2009, 04:26 PM   #4
KMac's Avatar
Trade: Finish Carpenter
Re: Stair Treads
Are they replacement treads?
KMac is offline
Old 08-06-2009, 07:41 PM   #5
mikeswoods's Avatar
Trade: interior remodeling
Re: Stair Treads
You will be able to find cherry stair treads at any flooring supplier. Also many mills offer glue up services.
LOOK AROUND. Make a few calls. seems silly to reinvent the wheel.
P.S. please put your location in your profile. Can't send you to any one if we don't know where you are.
mikeswoods is offline
Old 08-07-2009, 11:42 PM   #6
Old Crow's Avatar
Re: Stair Treads
Thanks for the info! Found some 5/4 stock today so i will start gluing up Monday. Have a good weekend!
Old Crow is offline
Old 08-08-2009, 07:59 AM   #7
mikeswoods's Avatar
Re: Stair Treads
You are welcome.
And thank you for the courtesy of letting us know the outcome.
Sometimes people forget to conclude a post and leave every one wondering how things turned out.
GOOD GLUING! MIKE
Old 08-09-2009, 08:32 PM   #8
finaltouchfloor's Avatar
Trade: Flooring & Remodeling
Re: Stair Treads
Are 5/4 treads the same as 1 1/4" treads? I've just never heard the term. We just always buy the treads sand/stain/seal/cut & install.
finaltouchfloor is offline
Old 08-09-2009, 11:41 PM   #9
chief pencil holder
Scribbles's Avatar
Re: Stair Treads
5/4 rough lumber, is normally 1 1/8" - 1 3/16 thick, after glue up and machining you have a 1" thick solid tread.
Old 08-09-2009, 11:55 PM   #10
carpentershane's Avatar
Trade: general carpenter
Re: Stair Treads
5/4 is the way to go... Used to work for a stair company, glued many a tread...
carpentershane is online now
Old 08-10-2009, 09:03 AM   #11
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
Re: Stair Treads
I vote for buying the treads. I just completed a 15 step conversion in my house from carpet to oak treads with white risers. I had some 5/4 left from other jobs. DAMN at the time it eats up, planing, edge joint, glue and clamp, planing final thickness.....
No way could I price out a job and plan to make the treads.....
Just my 2 pennies worth
BACKWOODS is offline
Old 08-10-2009, 02:01 PM   #12
chief pencil holder
Scribbles's Avatar
Re: Stair Treads
Oak treads I always buy, they are so cheap it is ridiculous; I am paying $25 or so a tread for 48" unfinished. Maple about 50% I buy depends on what the local flooring company has in stock. Other woods I always make cherry, walnut, mahogany, exe. The cost on those justify the labor involved in manufacture, also you can get better looking treads.
Old 08-11-2009, 11:48 AM   #13
copycat
mullaman's Avatar
Re: Stair Treads
You need at least 1" thickness on the treads. I always purchased the treads it saves time and ends up being cheaper. The treads I work with are usually 1.0625".
Buy the treads and make the returns if you need to out of the same material. Thats your best bet.
strikes and gutters, ups and downs
mullaman is offline
Old 08-14-2009, 08:38 PM   #14
Re: Stair Treads
I can't believe that lowe's sells 48" oaks treads for only $25 , and the solid oak risers are only $15.The wholesaler i been using for years charged me $36 per tread.
http://www.finaltouchflooring.net
Old 08-14-2009, 11:01 PM   #15
chief pencil holder
Scribbles's Avatar
Re: Stair Treads
I would have a stiff talk about your price schedule with your wholesaler.
Old 08-14-2009, 11:01 PM   #16
I like Green things
WarnerConstInc.'s Avatar
Re: Stair Treads
Mine are like 3/4", been there for about 120 years, still doing good!!
WarnerConstInc. is offline
Old 08-14-2009, 11:06 PM   #17
chief pencil holder
Scribbles's Avatar
Re: Stair Treads
120 year old hardwood is a different beast all together.
Old 08-14-2009, 11:19 PM   #18
I like Green things
Re: Stair Treads
True, very true.
And kind of sad at the same time.
new stair treads over old cutback ruggermike Flooring 2 04-02-2009 08:36 PM
pressure treated vs. raw lumber for new painted ext. stair treads, what to use? jordanski Painting & Finish Work 7 03-17-2009 10:23 AM
Replacing stair treads innovous Remodeling 11 12-23-2008 07:24 AM
Hickory Stair Treads dokuhaku Flooring 66 11-20-2008 12:20 AM
varathane stair treads more traction? surferal Flooring 0 09-28-2008 08:58 PM
