Stair Tread Jig??
Old 04-20-2010, 06:31 PM   #1
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
Stair Tread Jig??
I need a Jig, and I was hoping someone has some pics, or a quick way to make one.....
I'm not fitting stair treads....I'm going to be fitting about a hundred 1x blocks...finished stain grade between exposed beams.
I have a crude idea from something I read in a magazine...So, what I'm thinking is a horizontal board with grooves on both ends with adjustable vertical pieces attached with wing nuts. I have a bunch of scrap 1/2' ac plywood I'm planning to use.
Any tips, tricks, pics, would be cool!!
The beams are approx. 2'OC, so the jig will be about 20".....
WNYcarpenter is offline
Old 04-20-2010, 08:14 PM   #2
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
Re: Stair Tread Jig??
ive been looking for this as well, i took a couple photos of our stair guys home made one a couple years ago but the pics didnt turn out
just waiting to be on site again at the same time as he is. normally im long gone with the trim when we bring in the stair installer.
ive been wanting to get into finishing stairs more often as its a rarity that the gc lets us do it
woodworkbykirk is offline
Old 04-20-2010, 08:33 PM   #3
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
I would love to help but I'm not getting what you are up to. can you explain differently or provide a picture of something similar to what you are doing?
Gus Dering is offline
Old 04-20-2010, 09:41 PM   #4
Trim40's Avatar
Trade: Guy who plays with wood
Rewards Points: 550
Why not just use a tread jig? I think rockler has an inexpensive one.
I made mine from some left over lexan. It is somewhere in my shop. The bad news is , so is everything else.
Gus, think of it as a jig for bridging
Trim40 is offline
Old 04-21-2010, 07:47 PM   #5
wannabe
Trade: carpentry
I can't post attachments for some reason....anyway....I have to scribe filler trim between exposed floor joists. Similar to fitting stair treads between stringer trim.
So, I've seen an adjustable "H" shaped tread jig that you can extend the sides to get the exact scribe of both sides. No doubt Rockler has a jig, but the concept is so simple I figured I could just make one.
Old 04-21-2010, 08:04 PM   #6
Rewards Points: 2,000
Mine is just basically a straight piece
with a slot( short of both ends),
and two "Tees" each with a carriage bolt
and wing nut.
I radiused off everything but the two
business ends just so it looks pretty.
neolitic is offline
Old 04-21-2010, 08:32 PM   #7
jeffatsquan's Avatar
Trade: builder/renovator,Squam Lake NH
Rewards Points: 250
larger board about 4" shorter than your space with slots wing nuts and washers 2 smaller boards one on each end. epoxy a carriage bolt in each
they conform to your scribe tighten wing nut.
jeffatsquan is offline
The Following User Says Thank You to jeffatsquan For This Useful Post:
WNYcarpenter (04-21-2010)
Old 04-21-2010, 08:47 PM   #8
wannabe
Trade: carpentry
and wing nut.
I radiuse off everything but the two
That's the idea...thanks neo. I couldn't spit it out.....I'm thinking about nipping corners of the 'tees'
Old 04-24-2010, 01:53 PM   #9
wannabe
Trade: carpentry
here's the project.....filler blocks between the joists, and then a standard wrap.
Stain grade walnut trim...
Old 04-24-2010, 02:00 PM   #10
wannabe
Trade: carpentry
some pics of the jig I just made.... I'll modify the sliders and "Ts" to use for the stair treads....
I'd like to add aluminum to the "Ts" for more accurate scribing...for now I just wan to see if it works....
Which one- Stair Tread Measuring tool IHI Finish Carpentry 16 04-23-2010 08:23 PM
Stair tread remodel carpet runner mrick Flooring 23 02-10-2010 11:58 AM
stair help ravi2patel Finish Carpentry 9 09-13-2008 02:58 PM
Stair tread copusbuilder Painting & Finish Work 6 04-09-2008 06:30 AM
Stair tread instalation craker Finish Carpentry 12 07-13-2007 05:00 PM
