Stair Tread Instalation
Old 06-22-2007, 09:45 AM   #1
craker's Avatar
Trade: NC contactor
I am installing Br 111 engenered (SP?) flooring in my house.
I was wondering what methods you found the best for installing yellow pine stair treads ? nail, glue, screw?
I don't like the look of srew hole that have been pluged
I frame and build decks and porches but i have never installed interior treads any help will be appreaciated
Thanks
craker is offline
Old 06-22-2007, 09:47 AM   #2
RISENRUN's Avatar
Trade: STAIRS AND DOORS
Re: Stair Tread Instalation
What does the flooring have to do with the SYP treads..? I'm confused..
RISENRUN is offline
Old 06-22-2007, 01:24 PM   #3
craker's Avatar
Trade: NC contactor
Nothing. Just added that for the heck of it
craker is offline
Old 06-22-2007, 01:25 PM   #4
send_it_all's Avatar
Are there any skylights involved?.....j/k
send_it_all is offline
Old 06-22-2007, 01:38 PM   #5
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Reminds me of when I order auto parts. No matter what it is they always ask if it has air conditioning?
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 06-22-2007, 04:35 PM   #6
RISENRUN's Avatar
I would try nailing glue and screw. That should work just fine.
RISENRUN is offline
Old 06-22-2007, 05:01 PM   #7
mickeyco's Avatar
Trade: Squirrel Handler
I think glue would be a problem in a cross-grain situation like threads and risers to stringer/carriage. You can use pocket holes from below, I've also seen angle brackets used below. I think nails would be fine to. Could always go with a housed stringer staircase if you're motivated and have some cash laying around.
mickeyco is offline
Old 06-22-2007, 08:28 PM   #8
house bldr's Avatar
We always glue and nail. Nail through the back of the riser into the tread also, thats where most squeaks occur!
house bldr is offline
Old 06-22-2007, 08:39 PM   #9
KentWhitten's Avatar
OK, why not use the BR-111 for treads? They have the bullnose for it. Granted it ain't as cheap as SYP.
Your treads can be glued and that should be fine with some pin nails to hold them in place while the glue cures. Now what kind of glue is the question. Construction adhesive....good, but don't let any seep out onto the woodwork. Gorilla glue...wicked good, but don't let this seep out onto ANYTHING!
Screws, fine, just plug them if you want to.
KentWhitten is offline
Old 06-23-2007, 11:12 AM   #10
Trimcat's Avatar
Trade: Trim contractor
Send a message via MSN to Trimcat
I used to wonder about the cross grain glueing too mickey, but believe it or not, it's OK. I guess the grains are going mostly in the same direction if you think about it. However, you definitely don't want to glue along the whole edge of the treads with a finished bullnose cap piece if you are using one. Only glue the first few inches, and put a nail in the back so the tread is allowed to expand and contract. If you glue the whole thing on the treads will crack in time.
I like your pocket screw idea though from underneath... add some construction adhesive to that and you'll have a solid, squeak free set of stairs.... you could use glue blocks from underneath too if you want a fastener free look.
Trimcat is offline
Old 06-23-2007, 11:16 AM   #11
tcleve4911's Avatar
Trade: Remodeling contractor
Housed stringers is the way to go. Get out your router & square......
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 06-23-2007, 11:28 AM   #12
DrewD's Avatar
Trade: Log Home Construction/College Student
Glue them down then place tread on the stringer. Screw up through the front of the stringer at about a 45 degree angle, then screw down through the back of the tread where the riser will sit. This will hide all the fastners. Simply finish nail the risers after and fill with putty. Some guys glue and screw down plywood to the stringers first for more support but its up to you.
DrewD is offline
Old 07-13-2007, 06:00 PM   #13
wink's Avatar
Trade: carpentry
be glad to build you that set of stairs for a large fee and all expenses , sure do miss my old home state
wink is offline
Stair Jig RISENRUN Tools & Equipment 7 02-08-2010 08:30 PM
Stair Designer hatchet Carpentry 10 01-18-2009 08:14 AM
Stair Tread Pricing? THE HOUSE DR. Finish Carpentry 19 12-12-2008 08:35 AM
question for you stair guys JPhelps Finish Carpentry 5 08-29-2007 05:58 PM
Stair Line Xact Tread tool Ted W Finish Carpentry 0 05-21-2007 09:00 PM
