Stair Rail Help - Page 2 - Finish Carpentry - Contractor Talk
Stair Rail Help
Old 09-13-2018, 04:49 PM   #21
GC/carpenter
Californiadecks's Avatar
Rewards Points: 2,814
Re: Stair Rail Help
Case in point. There are applications where There's no wall at all. The stair rail can terminate into itself.
Mike.
_______________
Californiadecks is online now
The Following User Says Thank You to Californiadecks For This Useful Post:
rrk (09-13-2018)
Old 09-13-2018, 04:56 PM   #22
TimNJ's Avatar
Rewards Points: 3,164
Re: Stair Rail Help
Mike.
_______________
Example of that:
http://www.wagnercompanies.com/handr...-requirements/
TimNJ is offline
Old 09-13-2018, 05:00 PM   #23
GC/carpenter
Re: Stair Rail Help
These rails are custom made I install often on homes that have never failed an inspection.
Mike.
_______________
Old 09-13-2018, 05:01 PM   #24
GC/carpenter
Re: Stair Rail Help
Returning into itself is no different.
Nowhere in the code foes it require a handrail to terminate into anything. It just needs to be returned. It says returned or terminated.
Mike.
_______________
Old 09-13-2018, 05:09 PM   #25
GC/carpenter
Re: Stair Rail Help
Originally Posted by TimNJ View Post
Show me the code. I need it in writing from the IRC. That's all that counts.
And my railing returns around to itself. It does a complete 180. Makes it legal.
Return and terminate aren't the same.
Mike.
_______________
Wile E Coyote (09-14-2018)
Old 09-13-2018, 05:13 PM   #26
GC/carpenter
Re: Stair Rail Help
That little word "or" counts.
Mike.
_______________
Old 09-13-2018, 05:35 PM   #27
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,470
Re: Stair Rail Help
the point of the railing return at the top is so clothing does not catch on it .a sleeve ,purse or coat catching could drop someone down the stairs .
JFM constr is offline
Old 09-13-2018, 05:41 PM   #28
GC/carpenter
Re: Stair Rail Help
Returned doesn't mean terminated to the wall. That's all I'm saying. Terminated and returned aren't the same.
Mike.
_______________
Old 09-13-2018, 05:41 PM   #29
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 4,756
Re: Stair Rail Help
Those stairs only need to meet code at the time the home was built. 1976
Mike.
_______________
I think upgrading the other guard and handrails might put that into a gray area.
Big Johnson is offline
Old 09-13-2018, 05:44 PM   #30
GC/carpenter
Re: Stair Rail Help
No it doesn't. The only time your need to bring something into current code is if you take it out of code first. The only thing I took out of code was when I removed the handrail. I brought it into current code because it's returned. That's per IRC.
Mike.
_______________
Old 09-13-2018, 05:58 PM   #31
JFM constr's Avatar
Re: Stair Rail Help
thanks all .talking this out helped . I "believe " I found the handrail type/brand .more measuring is needed before i order but my thinking is i just change out the cap piece then continue it down and around .
The Following User Says Thank You to JFM constr For This Useful Post:
rrk (09-13-2018)
Old 09-13-2018, 06:51 PM   #32
rrk's Avatar
Rewards Points: 2,770
Re: Stair Rail Help
don't forget a gooseneck may be needed
rrk is online now
Old 09-13-2018, 07:19 PM   #33
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,021
Re: Stair Rail Help
Originally Posted by rrk View Post
does not need to be continuous, it is even with the top nosing. It has to terminate to something ( newel, wall ) or a termination easing
Mikes railing does not matter as long as it met code in 1976
Just pointing to an option and some pics.
I'm a bit curious what the other wall offers. Am I the only one?
MarkJames is offline
Old 09-13-2018, 09:19 PM   #34
rrk's Avatar
Re: Stair Rail Help
It can't be worse
rrk is online now
Old 09-13-2018, 10:05 PM   #35
JFM constr's Avatar
Re: Stair Rail Help
the other wall is the same only different . same railing detail on top and an open stair below with the railing pattern as infill . both sides have the same design on top .
Old 09-14-2018, 06:21 AM   #36
TimNJ's Avatar
Re: Stair Rail Help
Mike.
_______________
That is different than your house rail. It is closed, your house is open.
If it's ok with your inspector fine. I'm pointing out the inspector here failed me for an "open" rail. Problem being at the top of the step and falling down the stairs vs falling up the stairs from the bottom.
I can easily see the code wording as being interpretive by the inspector.
TimNJ is offline
Old 09-14-2018, 07:00 AM   #37
Re: Stair Rail Help
Inspectors should ban windows and stairs and mandate padding on all walls.
BattleBornNV (09-14-2018)
Old 09-14-2018, 08:13 AM   #38
rrk's Avatar
Re: Stair Rail Help
From what I was told by an inspector the railing return rule was started by an inspector whose mother flipped down the stairs when her housecoat pocket got caught on the railing. It took him almost 2 years for it get into the book.
Banning stairs is next
rrk is online now
Old 09-14-2018, 11:18 AM   #39
GC/carpenter
Re: Stair Rail Help
But you can't show me a return is required to be closed in the IRC. Closed is terminated. They aren't the same. I can't tell you how many times I've known more about that code book than the inspector.
Mike.
_______________
Old 09-14-2018, 11:20 AM   #40
GC/carpenter
Re: Stair Rail Help
Funny, because nowhere in the code book does it mention clothing. Albeit I understand the concept and agree with it. It's not anywhere in the IRC. From what I've read.
Mike.
_______________
Learning Stair Rail 5280carpenter Finish Carpentry 14 09-18-2018 04:28 PM
Stair Rail Help Needed philcav7 Carpentry 15 10-03-2014 12:28 PM
stair rail quickie Driftweed Carpentry Picture Post 5 12-24-2012 06:59 PM
Makita tracksaw and rail 4 sale Californiadecks Contractor Swap 3 11-10-2012 07:48 AM
Rail or stair gauge Tim the toolman Finish Carpentry 1 11-06-2010 01:09 PM
