Trade: Flooring
Stair Help
Hi,
I am new to forum and good to see tons of useful information. I plan to install hardwood on my stair after removing the carpet. I need the stair guys expertise advice on how to overcome my stair issue. 1) As you can see in the pic, the tread is cupped. I believe its construction grade pin of sort. The stair is very squeeky and you can feel the tread move as you climb. What is the best solution to remedy this ? Would installing a full tread resolve the noise ? what about the cupping, if i fill with PL glue..would that help ? 2) How do i resolve the difference in riser height as i will be installing the 1" thick treads directly over the existing one ? 3) I would really like to to cut the stringer and exposed the treads on the right side of this stair to get a side return look...but i guess that would make the whole stair structurally unsound due to its box/mortised tread design...correct ? 4) where should i look to buy treads in NJ ? HD has pine for $10 a piece. One mill shop quoted me $8.50 /LF for maple. Still contemplating whether to use pine/oak/maple. Maple because the flooring will be engineering select maple. Oak because i could stain it mahogony with white riser...should contrast good with maple floor. And pine because its cheep and just apply coats of poly. BTW, I am on tight budget. |
Trade: Licensed Home Improvement Contractor
Re: Stair Help
Your a flooring contractor??????
Money Changer
Trade: Residential Remodeling
Re: Stair Help
1........
Money Changer
Re: Stair Help
....2.......
I used to think so.......
Re: Stair Help
You have to take off all of your treads. You can't just add new wood on top of them. If you do that, you will be out of the allowable riser tolerance allowed by probably ALL stair codes in the US.
You are allowed a total accumulated amount of rise difference of 3/8" over the entire run of the stringer...in no more than 1/8" changes per riser. You have some big decisions ahead. Dismantling stairs in a way that preserves them is challenging, but do-able. |
Re: Stair Help
I'm sure you don't want to hear this,
but there isn't a good fix for that. A guy who really knows stairs might be able to do a fix, and it would still be better, cheaper, faster to rip it out and build new. If you have access underneath, you could shim and PL the treads to retighten them, or do some toe screws. Then re-carpet. Finished wood overlays are not going to make you happy here.
Re: Stair Help
I'd say put the carpet back on them
![]() Dave |
Trade: Flooring
Re: Stair Help
Thanks guys...i will just re-sand, stain and polyU. Than finish off with a carpet runner. May even looking into putting those false treads/riser kits. Again thanks for the advice.
Trade: Carpentry & Remodeling
Re: Stair Help
If you have access to the bottom of the stairs you can screw in glue blocks at all the riser to tread connections to try and stop the squeaks.But i think those yellow pine treads and risers will look beautiful once they are resurfaced, and finished. Try some small cove moulding under the bullnose to dress it up, and it may alleviate the squeak if it is glued too.
Administrator
Trade: Admin
Re: Stair Help
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed.
Nathan "He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot |
| Looking for stair design software | StairJunkie | Drafting & CAD Forum | 13 | 03-14-2010 06:24 PM |
| Stair Jig | RISENRUN | Tools & Equipment | 7 | 02-08-2010 08:30 PM |
| Stair Designer | hatchet | Carpentry | 10 | 01-18-2009 08:14 AM |
| minimum stair requirement, broken back | te12c02w | Carpentry | 12 | 04-28-2008 07:32 PM |
| master stair carpenters(i need your advice) | mmike032 | Finish Carpentry | 11 | 01-02-2008 09:32 AM |
