Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Finish Carpentry
Old 10-27-2009, 06:24 AM   #1
framerman's Avatar
Trade: Framing, Custom Carpentry, Architectural Design
Stacked window problem
I hav a window configuration of 3x3. The extension jambs are not anywhere close to alignment in some places. As far as plane goes, some about 1/2" off but most are flush. Up and down, side to side acceptable and workable.
The big opening is a problem also. Extension jamb on one side is 1" narrower than the other. If it was my place, I'd rip the windows apart but I can't. They only want forward progress.
Outside is already sided. Big windows too. Opening is 11' x 20'
is there any possible way to make this look good? I can't taper some extension jamb extensions. This is going to look like crap.
Sorry I can't post any pics yet.
If one advances confidently in the direction of one's dreams,
and endeavors to live the life which one has imagined,
one will meet with a success unexpected in common hours
~Henry David Thoreau
framerman is offline   Reply With Quote
Old 10-27-2009, 06:54 AM   #2
Chief hand holder
bert0168's Avatar
Trade: Residential Remodeling
Tough to say without pictures. There is usually a way to fix them but with out seeing it it's hard to tell.
bert0168 is offline   Reply With Quote
Old 10-27-2009, 07:07 AM   #3
genecarp's Avatar
Always a way to make it look pretty, ext jams and wide mull casing between the units come to mind, but a picture is worth 1000 words. GMOD.
genecarp is offline   Reply With Quote
Old 10-27-2009, 07:10 AM   #4
Chief hand holder
bert0168's Avatar
OK, I can't stand it anymore. Maybe I am dumb but what the heck does this stand for?
It's driving me nuts every time I see it.
Old 10-27-2009, 07:21 AM   #5
genecarp's Avatar
Bert, come on GENECARP THE NEW MODERATOR OF CT, its an EGO THING.GMOD
ALSO IT KIND OF FUNNY, BECAUSE IF YOU DROP THE M, WHAT DO YOU GET------GmOD
Old 10-27-2009, 07:29 AM   #6
Chief hand holder
bert0168's Avatar
Thanks Gene, I suspected as much.
I can stop kicking my cat now
Old 10-27-2009, 07:39 AM   #7
Trade: GC/Remodeling
Doesn't it suck following those framers?
11'x 20' opening?? Damn that's huge If it's 20' tall, you probably wouldn't be able to see if it's off 1/2"
gotta have a pic
Originally Posted by jeremy-lvhm View Post
...just stop it. go sit down and have a lollipop and think about what your saying.
TimelessQuality is offline   Reply With Quote
Old 10-27-2009, 07:55 AM   #8
basswood's Avatar
Trade: trim carpenter
If some of the windows are operable, you may be able to open them and use clamps to pull a window that is not properly seated in the framing. If the windows are foamed in, the foam bead might need to be cut away to free up the window jamb. I use deep jaw clamps and blocks of wood to protect the window from marring, etc. Won't get it perfect, but splitting the difference is better than nothing.
Regards,
Bass
basswood is offline   Reply With Quote
Old 10-27-2009, 08:25 AM   #9
framerman's Avatar
Yeah, this ones a beaut. Non operating windows,
screwed into the steel frame, no foam. I asked if we were putting any foam in and they said "no foam in any of the windows"
extension jambs came with unit. Right now I am taking the close ones and gently belt sanding it flush. The big gaps I am putting tapered extension jambs. I am going to make it look as pretty as possible.
Big damn window, yes. It's 10' off the floor to boot.
I'll see what I can do about pictures. Don't know how to post from my iPhone.
Yeah, framers suck!
Old 10-27-2009, 05:07 PM   #10
Chief hand holder
bert0168's Avatar
Sounds like what you are doing is the best route anyway.
Have had to make my fair share of tapered jambs before.
Sometimes you can hammer the drywall edge near the casing to get the trim to lay flat on a shy jamb (HINT: don't go beyond the outer edge of the casing )
If they were operators, you could also use a clamp to pull the window in and renail thru the jamb to get it where you want it but I see they don't open.
Good luck and as Timless said "Damn framers"
So now you know
Old 10-27-2009, 05:15 PM   #11
I've got this PC 3"x21" belt sander which when paired with a 60 or 80 grit belt will devour the wood in quick order. It's still tedious but manageable.
pictures sure would help
72chevy4x4 is offline   Reply With Quote
Old 10-27-2009, 06:54 PM   #12
loneframer's Avatar
Trade: residential framing/general carpentry
I've gone through several sets of planer blades "faking in" extension jambs on multiple unit window walls. Lots of good tricks will come to you as you go along. Sometimes you have to empty the magic hat on them.
" It's a Jersey thing, you wouldn't understand"
loneframer is online now   Reply With Quote
Old 10-27-2009, 07:21 PM   #13
Carpenter
WNYcarpenter's Avatar
Trade: custom homebuilding/remodeling/restoration
Ganged windows are always tough...I especially hate ganged skylights.
You didn't mention if the trim is painted. From your post I'm assuming not...if painted, screw it let the painters fix the mess
Looking forward to the pics!
WNYcarpenter is offline   Reply With Quote
Old 10-27-2009, 07:21 PM   #14
framerman's Avatar
Well, I made it through that mess. Not too bad after I tweaked things here and there. I have one bad part I will need to work on, but overall it's decent. I feel like I wasted a whole day. One window took all day. 3 extension jambs and 3 pieces of casing. One big ass window though as you can see.
Sorry, all I have is my iPhone for pics and it's trashed. Not a very good inside camera.
You can see where I have these mullions coming together and the extension jambs in these areas are messed up.
Old 10-27-2009, 07:25 PM   #15
loneframer's Avatar
Might want to consider changing your username to Jamberman.
Old 10-27-2009, 07:37 PM   #16
Maker of fine kindleing
Gus Dering's Avatar
Trade: cabinet maker
Thank god for the I-phone then. Looks good in that picture.
Originally Posted by WarnerConstInc. View Post
Gus is right.
Gus Dering is offline   Reply With Quote
Old 10-27-2009, 08:05 PM   #17
framerman's Avatar
Soon it's going to be baseboard boy
Old 10-27-2009, 08:16 PM   #18
loneframer's Avatar
SOoooooooo........... cope or miter?
Old 10-27-2009, 08:17 PM   #19
framerman's Avatar
I cope for the most part.
Old 10-27-2009, 08:21 PM   #20
loneframer's Avatar
You're gonna make a fine Trimmerman.
Basement Window Leaking DanTheMan9727 Construction 3 10-24-2008 01:29 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 9 09-10-2008 07:01 AM
Replacing double window w slider 1st time dvlscapes Carpentry 5 09-03-2008 01:26 PM
How to fix this? Window problem mattp Windows, Siding and Doors 1 06-09-2008 07:13 PM
Problem: Window replacement/restoration in 1905 house. hipgrrrrl Windows, Siding and Doors 7 10-03-2006 09:29 AM
