Trade: Remodeling contractor
Square Edged Casing Connections
Our current finish project uses 1x4 squared edge pine with 3/4" backband around the perimeter.
In the past, I used to biscuit join them, but they would never "lock" in. The head casing would roll back and create a gap in the jamb casing or they never stayed flush. Lately I've been pocket screwing the joint on my bench, flipping it over, sanding smooth and then putting the whole thing up as an assembly. That's fine until you start running 12' windows and multiple sash assemblies. Any tips?
Back in Maine Dubbin' Around Doin' good stuff ...... |
Trade: Finish Carpentry
Re: Square Edged Casing Connections
I've always just scewed miters together from the top or bottom with 1 5/8 self tapping screws. With glue and screws, you can't go wrong.
Trade: custom home building
I glued & doweled a lot of window casing, then finished it, then nailed it up.
Next time, again with rosettes in the corners, I prefinished everything, even the sides of the rosettes where they would be glued. I didn't finish the ends of the head/sill and jambs. Anyway, then I doweled and glued everything up and nailed it on the window. I wanted to do it this way because it was easier to finish with the pieces separate. I had my doubts about glueing the prefinished rosettes, but I had no problems. Probably the glue in the dowels holes and the dowels would go a long way towards holding everything together anyway. And once it was mounted, it wasn't going anywhere. These are 9 years old now. 3 coats of poly. |
#4 | |
The Remodeler
Trade: Home Remodeler
Re: Square Edged Casing ConnectionsQuote:
To the OP- pocket screw joints are great, arent they? |
I like Green things
Domino, it is made for that. You could pre-assemble all casings with gule and Domino's and pre-finish. Hang as one unit. I have done that with my cabinet maker on several large houses where he made all the trim.
It was super easy once on site. |
The Remodeler
I forgot about that... Good suggestion. You are the Festool guy arent you?
Carpenter/Finisher
Is there a festool solution for everything?
1st Gen tradesman My summer job in college became my profession |
Trade: siding
probably not suppose to do this but ive used biscuts and pocket screws together in the same joint makes it alittle easier for me to get the joints lined up
I like Green things
Re: Square Edged Casing Connections |
| Survey: Window Casing Installation | Journeyman T | Finish Carpentry | 4 | 03-16-2009 12:02 AM |
| Domino casing mitres | CarpenterMatt | Finish Carpentry | 20 | 03-07-2009 08:40 PM |
| here's a painting price list...... | Jer44 | General Discussion | 9 | 02-17-2009 08:30 AM |
| Help! How much a square? | Sliverbush | General Discussion | 260 | 02-05-2009 09:17 PM |
| Square adapters for bullnose | Kiwiman | Drywall | 2 | 12-07-2008 12:41 PM |
