Splicing Handrail
Old 11-27-2006, 01:23 PM   #1
Thom
thom's Avatar
Splicing Handrail
I need to splice a round-with-bottom-flat handrail. I can only get 16'ers and I need a 19' rail.
I've tried both wood glue and gorilla glue with a dowel and the joint breaks.
thom is offline
Old 11-27-2006, 01:30 PM   #2
Patrick's Avatar
Re: Splicing Handrail
they make a special fastener for that It has a special magnetic bit that goes on your drill that makes them tighten up inside the rail
Patrick is offline
Old 11-27-2006, 01:31 PM   #3
carpenter and builder
Nick H's Avatar
Trade: carpenter and builder
I've seen a range of "off the shelf" stair parts that uses a recessed bolt to join the handrails, maybe you could adapt something like that or possibly use a wortop bolt if there is room to fit it in. I think there is also a system using a hidden bolt and a magnet, sound wierd I know but someone else will know what it is.
Dont give me problems, give me solutions.
Nick H is offline
Old 11-27-2006, 05:10 PM   #4
72chevy4x4's Avatar
I've seen the magnetic gizmo in action and it looks slick. Lowes carries some parts which could help you out-would require you to drill a hole in the bottom of one rail and in the end of the rail, then screw the bolt into the other rail. Tightening is achieved by a bolt with just enough room to get a small wrench in the hole on the bottom of the rail. There may be some newer systems out there to help you better line up the rails-nothing like having mis-aligned rails which are easy to pick up when running the hand over it.
72chevy4x4 is offline
Old 11-27-2006, 06:58 PM   #5
Teetorbilt's Avatar
Are you trying to butt-joint endgrain? This will never work.
To join handrail; Cut shiplap (a min. of 6:1), dowel for position, glue and clamp. It will be as strong as the original rail.
Albert Einstein
Teetorbilt is offline
Old 11-27-2006, 07:16 PM   #6
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
yeah, you dont need those magnets or anything like that, just do what teetor said. I dont know what shiplap is, but I assume it is a scarf. Is that right teetor?
Real nice guys
King of Crown is offline
Old 11-27-2006, 07:36 PM   #7
Teetorbilt's Avatar
Same thing only marine, almost.
Albert Einstein
Old 11-27-2006, 09:08 PM   #8
reveivl's Avatar
Trade: Renovations
Also known as a "half-lap"
reveivl is offline
Old 11-27-2006, 10:03 PM   #9
Teetorbilt's Avatar
I tried to find a pic to no avail. The way that I was taught was a long scarf stubbed at each end, it was clamped in both directions. The joint looks like an elongated Z. The end joints were just to maintain position as they were pegged or riveted.
Yes, we used to rivet wood with copper or bronze rivets and washers.
Albert Einstein
Old 11-28-2006, 01:54 AM   #10
Steve Unkie's Avatar
Trade: REMODELING CONTRACTOR
Installation is much easier it you glue up your scarf joint beforehand and let it cure, then install it as one piece. instead of trying to join the handrail as you install it. Likewise with returns.
Steve Unkie.
Steve Unkie is offline
Old 11-28-2006, 10:00 PM   #11
Heavy Weight Champ
teetor, thats interisting.
how do you make the cut?
Real nice guys
Old 11-28-2006, 10:05 PM   #12
Teetorbilt's Avatar
A band or vertical recip is required on big stuff. For standard handrail configs. a good sabre saw and a little hand work can make a tight joint.
Albert Einstein
Old 11-29-2006, 06:47 PM   #13
karma_carpentry's Avatar
Trade: carpenter
Teetor, is it like the one on this page? Except maybe with square stopped ends- like this one.
karma_carpentry is offline
Old 11-29-2006, 07:15 PM   #14
Teetorbilt's Avatar
Karma, you nailed it! The scarfed splice is what we call a 'shiplap'. It is designed to take motion on a continuous cycle. Your average 60-80 ft. boat cycles at about every 6 secs. I have seen the straight scarfs used but only on large timbers such as keels.
Thanks for the help! There don't seem to be a lot of wooden shipbuilders on the web. I know of a few who only use electricity for serious functions such as lighting and firing up the bandsaw.
Albert Einstein
Old 11-29-2006, 07:57 PM   #15
Heavy Weight Champ
The things I learn from you Teetor!
You and Tom R keep me learning.
Real nice guys
Old 12-01-2006, 06:13 PM   #16
Doug M's Avatar
Trade: Kitchen and Bath contractor
I may be off base on this but couldn't you make a scarf cut and use a kreg jig/pocket screw on the bottom then plug the holes.???Seems like it would be pretty strong
Doug M
Doug M is offline
Old 12-01-2006, 06:43 PM   #17
Heavy Weight Champ
i'm sure it would be strong, but people dont realize how strong the glue is. it may sound crazy, but the glue is actually stronger than the wood, so if there is going to be a break, its going to be the weakest part of the wood, and since there is two different peices of wood with different grain being put together, you scarf with glue will be pretty strong.
On the other hand, Your pocket screw will not need time to cure, which is also nice.
Real nice guys
Old 12-01-2006, 07:15 PM   #18
Teetorbilt's Avatar
For glues, you can go to quickset epoxies. I use some that set in 6 mins. and are good to go in 20.
I don't know that I could set up a Kreg jig on a handrail in that amount of time unless they make one specifically for that purpose. Then you have to cut plugs, glue, fair and, in my world, someones still going to see them.
Albert Einstein
Old 12-07-2006, 05:37 PM   #19
MarcM8181's Avatar
Trade: Custom stairbuilding
the magnet idea is great but you need to buy the whole jig in order to do it and that cost about $700. and you can but joint a piece of rail together, just do it just like you are doing a gooseneck or any other type of over the top rail part.use a rail bolt!
MarcM8181 is offline
Old 12-07-2006, 07:51 PM   #20
Teetorbilt's Avatar
A quick search of 'rail bolts' looks like massive holes (1") that will need to be plugged. What about top surface alignment?
Albert Einstein
Handrail for exterior Frankawitz Carpentry 3 06-03-2007 09:34 PM
Oak Handrail BMAN Painting & Finish Work 12 11-28-2006 07:00 PM
Craftsman style handrail Donedat Finish Carpentry 2 08-10-2006 08:57 PM
