Spackle Or Bondo?
Old 04-21-2007, 01:24 PM   #1
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Spackle Or Bondo?
seems to be a matter of personal preference. Filling nail holes in trim - some GC's like spackle, some like bondo- I don't really have a preference, they both seem to work fine, other than the bondo is harder to sand. what do you guys use?
Mrmac204 is offline
Old 04-21-2007, 05:17 PM   #2
AtlanticWBConst's Avatar
Re: Spackle Or Bondo?
The main difference is that spackle tends to shrink more than bondo.
The spackle holes will be filled, but you will still see the 'indent' more.
- Build Well -
AtlanticWBConst is offline
Old 04-21-2007, 07:12 PM   #3
Teetorbilt's Avatar
If you like Bondo, it's really easy to make your own that will sand better.
Buy a qt. of polyester resin and a spare can. Pour half into the spare can and seal. Get some glass filler (micro balloons or q-cells) forget the talc. Mix it to the consistancy that you want and kick it off with the Benzoyl Peroxide (Bondo cream hardener).
I buy a lot of stuff here. http://www.glueproducts.com/glueproducts.html
Albert Einstein
Teetorbilt is offline
Old 04-21-2007, 10:01 PM   #4
The Deck Guy
Greg Di's Avatar
Buy a qt. of polyester resin and a spare can. Pour half into the spare can and seal. Get some glass filler (micro balloons or q-cells) forget the talc. Mix it to the consistancy that you want and kick it off with the Benzoyl Peroxide (Bondo cream hardener).]
Holy crap! It's Teetor's own version of "Mr. Wizard"!
Personally, I've been using Muralo (sp?) spackle I bought at paint store. Super easy to sand, no dents, and no hazmat license needed .
Greg Di is offline
Old 04-21-2007, 10:28 PM   #5
Home Repair Specialist.co
hrscammisa's Avatar
Trade: carpentry
We always used bondo on are metal doors works great
hrscammisa is offline
Old 04-21-2007, 10:52 PM   #6
Teetorbilt's Avatar
Doug, I've been working with this stuff since building surfboards and raceboats as a kid. I still do some work for Lockheed Martin.
Albert Einstein
Old 04-22-2007, 09:52 AM   #7
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
This sounds like auto body 101....bondo....is that not a product used for fix minor inperfections in fenders. I can see using it on a surf board or something of that nature, but a catalyst product for nail holes would get you a NFW from me, sorry TEET. There is a light wieght filler by poly that works just fine and the painters we use swear by it.
Filling nail holes is a painters job NO.......?
woodmagman is offline
Old 04-22-2007, 12:47 PM   #8
Finishing Carpenter
Mrmac204's Avatar
woodmagman -what's the name of that filler? I am looking for something that dries fast (1/2 hr?) and is easily sanded.
thanks
Mac.
p.s. what city are you in?
Mrmac204 is offline
Old 04-22-2007, 12:56 PM   #9
woodmagman's Avatar
LePage Poly filler light. I am not the pro but I do like the results. It is best in the tube and we use it instead of latex chaulk when ever we can. Put it on, wipe it with a damp cloth and walk away, no need to sand nail holes or small lines between casing and drywall or on top of baseboards.
I still believe this is the painters job.....
Old 04-22-2007, 01:11 PM   #10
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
It is the painters job!
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 04-22-2007, 04:10 PM   #11
Finishing Carpenter
Mrmac204's Avatar
it may be the painters job, but I am bidding a crown/baseboard job, and I am the one and only employee so that means that I do the caulking and filling, cleaning, begging..
freedom aint glamorous, but its a rush
Mrmac204 is offline
Old 04-23-2007, 03:05 PM   #12
wannabe
WNYcarpenter's Avatar
Trade: carpentry
We use Bondo for patching old hinges, strikes, sometimes large holes needed to be patched...I look at it like durabond or hotmud...it's a pain to sand, but it's solid, won't crack and can fill large voids because of it's curing time. I woudn't consider it a staple, but it works well in a pinch...such as misplaced hinge mortises.
WNYcarpenter is offline
Old 05-15-2007, 02:59 PM   #13
Ben
Ben's Avatar
Trade: Residential Remodeling
I love using bondo for areas that otherwise would not be able to hold spackle or wood filler.
For example I had to install a door knob into a front door that needed the holes located in different areas, so I filled everything with bondo then sanded and re-drilled the holes where I needed them...
Try doing that with spackle....ha!
Spackle is much better for filling nail holes on walls it is quick and fast and doesn't smell and easier to clean up, I couldn't image using bondo ever for that....
www.benspost.org- "a community for homeowners and contractors"
Ben is offline
Old 05-15-2007, 09:11 PM   #14
KentWhitten's Avatar
Now I've heard of bondo in construction, but I thought it was 2 different things. One's auto and ours is wood bondo. Am I mistaken on this? I've never used it either way. I'm a bondo noob.
Salmon Falls Cabinetry
KentWhitten is offline
Old 05-15-2007, 11:07 PM   #15
Tom R's Avatar
Good ole' water putty dries hard and fast and doesn't shrink, - - bondo is way overkill for nailholes, IMO . . .
Spackle shrinks way too much.
Tom R is offline
Old 05-21-2007, 10:14 PM   #16
Yet another carpenter
Ted W's Avatar
Trade: Carpenter Woodworker
Bondo to fill nail holes? Not if it's by the hour. If it's getting painted use a light weight spackle (not the heavy stuff!). Any good quality brand will do - red devil, muralo... if it starts to dry out as your working add just a few drops of water and mix it up.
Bondo is made for auto body work but very popular in home improvement as well. Min-Wax Wood Filler is the same as bondo, but wood color with white hardener.
If the wood is to be varnished, get the first coat of varnish on first so it (the filler) doesn't stain the wood, then fill the nail holes with your preferred filler of a matching color. I like wax sticks or non-drying filler. Sanding before the second coat of varnish will also remove any excess nail hole filler.
And yes, filling nail holes is typically the painter's/finisher's job.
I could write a book on the matter, but I don't like to show off.
Carpentry and Woodworking - Chicago / North Shore - Ted's Carpentry
"I don't know everything but at least I think I do, and that's what really matters."
Ted W is offline
Old 02-11-2008, 09:37 PM   #17
joeb's Avatar
Trade: interior carpentry
anybody use painters putty 53'
joeb is offline
Old 02-12-2008, 08:04 PM   #18
anthonyadam13's Avatar
Trade: Finish Carpenter
The smell of Bondo normally means someone made a booboo......
anthonyadam13 is offline
Old 02-12-2008, 08:43 PM   #19
orson's Avatar
Trade: Kitchen & Bath
As far as I can tell the only difference is in color and price.
www.rubycon.us
Ruby Construction LLC
Lancaster Kitchen Remodeling
Lancaster Bathroom Remodeling
orson is offline
Old 02-12-2008, 08:45 PM   #20
orson's Avatar
Lightweight spackle for nailholes
Bondo for large holes and holes with profiles and corners, missing chunks etc.
Ready Patch for dents in metal, no mixing required.
www.rubycon.us
orson is offline
Bondo and temperature? Kashmir Painting & Finish Work 2 01-26-2007 09:40 PM
using bondo? JohnDucan Painting & Finish Work 4 01-25-2007 08:31 PM
spackle over caulk cynthiann Painting & Finish Work 2 04-08-2006 06:36 PM
How much spackle is enough abmcustoms Painting & Finish Work 20 03-19-2006 08:34 PM
painters putty vs. spackle Zeebo Painting & Finish Work 1 07-09-2005 01:40 PM
