Space Below A Door
Old 03-05-2007, 08:50 PM   #1
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Space Below A Door
ok I have a job (finally!) to install a door in a wine cellar. I have the new jamb, and the old door. no problem there- what I am wondering is how much clearance from the bottom of the door to the (concrete) floor. The reason that I as is that the HO wants to install a door sill after the fact (why not now???) anyhow I should probably leave some sort of clearance so that the sill can slide underneath. I am thinking about one inch should do it... what do you all think?
the HO wants to install some weather seal so that the room remains cold- essentially it will be an outside door installation, only inside, so this is the reason for the sill.
Mrmac204 is offline
Old 03-05-2007, 08:58 PM   #2
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Re: Space Below A Door
Look around for the drop down weatherstripping, when the door closes a little button is depressed and the weatherstripping drops. Installing a sill on crecrete after the fact is a pain in the..
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 03-05-2007, 09:15 PM   #3
Dustball's Avatar
There's the seal-o-matic and flex-o-matic door sweeps-
http://www.mdteam.com/products.php?category=196
http://www.mdteam.com/products.php?category=195
I did a search on google for "automatic door sweep" and this one came up- http://www.automaticdoorsweep.com/
Dustball is offline
Old 03-05-2007, 09:28 PM   #4
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
204…you said you landed a job finally, you do not have the proper information to determine how much to cut off the door so leave it as close as you can, that way when YOU go back to install the Threshold for the customer then it will fit perfect…..This could be you second job you landed and it is a referral…The best kind of job…
woodmagman is offline
Old 03-05-2007, 09:34 PM   #5
troubleseeker's Avatar
I would not try to guess the clearance of a sill that is not in hand, unless you just decide on one for him, and cut accordingly. I would just leave enough clearance for the door to operate, and let hin fit it when he adds the sill.
troubleseeker is offline
Old 03-06-2007, 12:55 PM   #6
Finishing Carpenter
Mrmac204's Avatar
thank you all, after deliberating on this overnight, I've decided to just go and buy the sill and install it when I assemble the door/jamb. that way its done right the first time.
Mrmac204 is offline
Old 03-06-2007, 06:16 PM   #7
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
That is exactly what I was going to recommend.
Real nice guys
King of Crown is offline
Old 01-02-2009, 06:35 PM   #8
Kaabi's Avatar
Trade: Cabinets
I know exactly the solution for your problem! This product:
http://www.thehardwarecity.com/?sku=7004385
I have it myself and it works great. Pretty cheap too.
Kaabi is offline
Old 01-03-2009, 12:44 PM   #9
mics_54's Avatar
Trade: contractor
Look on the internet at the website of the most likely place to buy a threshold in your locality. I see a veriety thresholds on the local Lowes. Determine the thickness of those thresholds and then determine what type of astrigal if any you will wish to use on the bottom of the door. I would have probably purchased an exterior door jamb complete with threshold and insulated door since the HO wants a sealed door.
mics_54 is offline
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
commercial door hinges rservices Windows, Siding and Doors 4 12-02-2006 12:46 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
Door hanging Nick H Carpentry 4 02-27-2006 02:22 AM
ADA Entrance door swing Luke's Dad Construction 5 01-01-2006 12:56 PM
