Trade: Carpentry & Remodeling
Shimming An 1 1/2" For Base Cabinets...
Any of you guys have a good method for those old houses with a new kitchen goin in where the floor happens to be an 1 1/2" ( or close to it)out of level... I doubled up some 1x and screwed it to the floor as shims. Also i have stacked shims and siliconed them in place.
Any better ways?
Do what you would do, as if i won't Do anything after you Did It! |
I like Green things
Re: Shimming An 1 1/2" For Base Cabinets...
If I can't take it back to the floor joists and re-level, I rip long tapers out of 2x material.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
| The Following User Says Thank You to WarnerConstInc. For This Useful Post: | D.Foster (03-16-2010) |
Maker of fine kindling
The most important thing to keep in mind when you have a jacked up floor like that is to make sure your dishwasher and range is going to work.
If you get too tall at the DW you can always put a header over the opening but you can't let it go too low. That is baaaad. ![]() The floor is never out in a nice perfect wedge shape. So at each cabinet I screw on pads to the bottom of the toe base that leave enough room for a shim, what ever that may be. At the high end of the floor, we may need to cut some toe off so the DW is good. I cut a little more so I can still use shims. When adding pads I just add small ones where I want shims. I think it's a good idea to at least pin the shims to the floor in the places you may not be screwing through them, like in the center section of the recessed toe. Then the finished toe skin covers the whole mess.
Every parent who has walked barefoot into their child's room late at night hates Legos |
| The Following User Says Thank You to Gus Dering For This Useful Post: | D.Foster (03-16-2010) |
I will either do that, or if it's high like what you're talking about I will use a French Shim.
french shim?
I'm not sure what you guys call it but I've heard it called a "French Shim". Basically lay some scrap 2x on the floor the tall way against the inside of the toe kick and secure that to the floor. You then screw into the 2x and then add additional shims as needed.
#7 | |
Working
Re: Shimming An 1 1/2" For Base Cabinets...Quote:
Cole
Cole's Custom Creations Cedar Rapids, Iowa What is this "work" you speak of? |
Trade: cabinet installer
When I encounter this type of scenario I cut some of the cabinets down on the high side and try and split the difference as to how much I have to shim on the low side .
1 1/2 inches out is really bad . IMO that is just going to be to obvious when you look at the toe kick . I'd love to hear a good solution for when the designer decides to run the cabinet crown up to the ceiling in a 40 year old house and the ceiling is 1 inch out of level in 8 ft . I gave the homeowner 2 options . Keep the crown level and they could have a drywall finsher try and build the ceiling down or let the crown follow the ceiling . They chose the latter . I was not happy with how it looked but as I told them I'm not a magician . Had a long talk with the designer about this issue . Hopefully it won't happen again . It's hard to install $800 worth of cherry crown and have it look totally wacked . Also makes one wonder why someone would go to the expense of gutting a kitchen and not try and level out the ceiling . |
LRG WoodCrafting
Make a staggered countertop. Have a cabinet in the middle of the run that is lower than the rest. Now always an ideal situation and some clients may not go for it. You run about 5 feet of cabinet and then have a 32" tall cabinet and then start the run of 36" again. The two 36" countertops will not be level with each other, but will be 36" off the floor. I had done this in a kitchen that was out 4". The lower section was a bank of drawers and she used it as a dough pounding area, she liked to bake.
Not always an idea fix, but it will take a lot of the stress out of the design.
I had a large patio door job and made shim blocks that were a god send-took a 2x4, stood high on the table saw and ripped it at about 25 degrees, then crosscut them into 4-5" long blocks. My issue was leveling a door with more than 1.5" out of level in 8' and these blocks worked nicely.
another option is to get some scrap plywood in a variety of thicknesses-3/4", 1/2", 1/4" and 1/8" paneling would be nice-rip it into a small 1x4 blocks-the plywood spacers don't split when screwing through but obviously don't allow for fine measurements than the thinnest piece. |
#11 | |
General Contractor
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Is this what you mean?
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Bill Everett - St. Petersburg, FL Last edited by Willie T; 04-02-2010 at 11:00 AM. |
#12 | |
Jeff
Trade: master turd burglar
Damn 4", thats alot. I have a feeling it would feel like a funhouse in there. |
#13 | |
LRG WoodCrafting
Priced In
Trade: Exiled For Life
buy baseless cabinet boxes and build the base to fit. To break up the unevenness Use end panels.
Re: Shimming An 1 1/2" For Base Cabinets... |
#16 | |
A friend stopped by and said he thought his wife would puke from vertigo if she had to deal with that. HO was ecstatic that her floor was level. It had at one time been a porch that was turned into a kitchen
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan |
DN Construction
Trade: Construction
wow I can't even complain about my floors if you guys have done some up to 4". thats insane!!! Just getting repetitive but yes best solution is to cut some off the high end try to split up the whole deal.
#18 |
Some good things here. I have never set cabinets level in a completely unlevel kitchen floor. Level kitchen cab. make walls look goofy as hell. I usually split the difference between level and unlevel to get a happy medium. If the HO is not willing to have the floor leveled then they need to understand that if they want the cabinets level everything else will look goofy. Sometimes its just as well to set the cabinets to what the floor is doing just to keep everything looking uniform. Just dont set anything on the counter tops that could roll off lol.
#19 | |
Trade: Railing
A true crafstman knows how to get the most out of the least. Joe |
| Removing tile that is set under base cabinets.. | bujaly | Flooring | 43 | 03-13-2010 05:15 PM |
| 41" kitchen wall cabinets: 3 shelves? or 2? | Townshiphomes | Finish Carpentry | 14 | 02-26-2010 02:05 PM |
| Fixing Paint on Kitchen Cabinets | fix it man | General Discussion | 20 | 02-13-2010 12:32 PM |
| Imported cabinets (Don't buy it) | Jimmy Cabinet | Kitchens & Baths | 3 | 02-11-2010 04:14 PM |
| Painting/staining cabinets | KG007 | Kitchens & Baths | 7 | 01-09-2010 11:41 AM |
