08-20-2009, 05:28 PM
#1
Trade:
carpentry
Scarf Joint
Question: When installing baseboard, crown, etc., why is a scarf joint cut at 22.5 degrees and not 45 degrees? Is there a specific reason for this, or is it more of a local tradition? Does anyone do it at 45?
Thanks.
08-20-2009, 05:40 PM
#2
I do that too!
Trade:
80% junk,jokes or stupid comments
08-20-2009, 06:22 PM
#3
Trade:
carpentry/remodeling/"Yes M'am we do"
08-20-2009, 06:35 PM
#4
Trade:
Residential Contractor
Everybody that I know uses 45*. It's the set stop on most trim saws.
Albert Einstein
#5
Pompass Ass
Trade:
Certified Building and Certified A/C Contractor
Thanks.
Because it looks better to have a smaller joint, if it is cut at a 45 it will be longer.
Homeowners will scarf a joint at 45 because they don't know any better.
08-20-2009, 06:54 PM
#6
Trade:
trim carpenter
I like a 45* scarf on base... larger area for a glue bond and better cross nailing (larger overlap). Also the bigger the angle the more edge grain you have for a strong glue joint (22.5* and smaller angles mean you are essentially glueing endgrain to endgrain).
Or you can butt and biscuit.
08-20-2009, 06:59 PM
#7
Maker of fine kindleing
Trade:
cabinet maker
Whats a scarf joint anyway?
Originally Posted by WarnerConstInc.
Gus is right.
08-20-2009, 07:47 PM
#8
finish carpenter
Trade:
finish Carpenter/ renovations
45 degrees does provide more gluing surface but more prone to shrinking in the pool. therefore i use 22.5 sometimes 30
cutting some wood
08-20-2009, 08:15 PM
#9
Trade:
carpentry
It's when two lengths of lumber are joined so poorly you just drop a scarf in front of it and pretend it's not there. Similar to a "couch joint."
08-20-2009, 08:23 PM
#10
Trade:
Painting - Restoration
did someone say joint?
08-20-2009, 09:54 PM
#11
Fentoozler
Trade:
Professional Pie and Pastry Taster
It's what hobos pass around in the winter...
08-21-2009, 08:06 AM
#12
Trade:
trim carpentry
I use a 45* for the same reasons as Bass, its also the way I was taught
08-21-2009, 09:14 AM
#13
Trade:
carpenter/ handyman
Ahem, the politically correct police are watching you Celtic.
Steve
08-21-2009, 09:57 AM
#14
General Contractor
Trade:
General Contractor
I must be out of touch. I've never even seen 22.5. Besides, isn't it a whole lot quicker to just butt them and use a lot of caulking?
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
08-21-2009, 10:19 AM
#15
Trade:
Finish Carpenter
I was taught using 45 but i like 22.5 now. Seems like it's easier to me - especially when making crown scarf joints on the ground. The pieces seem to want to "slip past" each other more with a 45 - especially with a bunch of glue on it - making it difficult to line 'em up.
I like the but joint sometimes with domino's if possible - now that's a tight joint!
08-21-2009, 03:10 PM
#16
Trade:
Carpentry & Remodeling
I use a 33.5 degree joint
Do what you would do, as if i won't Do anything after you Did It!
08-21-2009, 04:27 PM
#17
Super Genius
Trade:
No trades, no CCs. Cash or check, please.
It seems to be a regional thing, around here scarfs are 22.5. IMO they look better and are easier to work.
Right now I am repairing some 20 year old vertical cedar siding scarfed at 22.5 that has failed at every joint. Western Red Cedar Lumber Association recommends 45 degrees on anything vertical.
Sorry for the drift.
The Following User Says Thank You to davitk For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
