Rotten Window Sil Relacement
Old 01-20-2007, 08:40 AM   #1
craker's Avatar
Trade: NC contactor
I'm relpaceing windows for a customer and 2 of the sils are rotten on the exterior of the house. Just wanted to see how others would handle the demo and replacement
thanks
craker is offline
Old 01-20-2007, 03:50 PM   #2
house bldr's Avatar
Trade: general contractor
Re: Rotten Window Sil Relacement
I'm a little confused, if you are replacing the windows why are the rotten sills an issue? Or are you just installing replacement window inserts? How rotten are they? The fix would depend on the situation.
house bldr is offline
Old 01-20-2007, 07:07 PM   #3
troubleseeker's Avatar
Like "house bldr" I'm asssuming that if you are concerned about the sill, you are installing replacement windows in the existing wood window frame. I do one of two choices depending on the replacement window being used. If the new window is thick enough to cover the step up in the old sill where the sash came down, I do not disturb the interior trim, but cut the old sill out along this step using a combination of circular saw and reciprocating saw. Then install a "ledger" for support under the seam, make a new piece to duplicate the old, bed it in polyurethane and slip into place, having also cut some "legs" to support it from below. The replacement unit will hide this seam and also protect it from the elements. If the new unit is not thick enough to cover this seam, I remove the interior apron, cut the entire sill out, and slip in a new duplicate.
troubleseeker is offline
Old 01-20-2007, 07:43 PM   #4
craker's Avatar
Trade: NC contactor
thanks guys. Sorry for the confusion,
yes , i'm talking about inserts
craker is offline
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Rotten window sill replacement jmancan Windows, Siding and Doors 21 10-15-2007 10:47 PM
Condensation Help Patrick Windows, Siding and Doors 10 03-16-2007 09:40 AM
cutting window openings into brick faced house Mr. D Masonry 5 11-14-2006 01:55 PM
Pre Cast Window Don H Drywall 7 09-20-2006 11:01 PM
